Old 03-22-2010, 06:52 AM   #1
thelrgkid
thelrgkid's Avatar
thelrgkid is an unknown quantity at this point
Ka24de intake backfire..
So here's the thing, I'm running a completly stock ka24de and ti was running fine besides noises of the loose timing chain. So I redid the upper and lower chains and started it up and timed it with the light it runs smooth now. But when I give it gas it backfires through the intake. And if you put your hand infront of the hole on the air box when giving it gas, it sucks super hard like it's getting lots of air. Any suggestions on how I can six this?
thelrgkid is offline   Reply With Quote
Old 03-22-2010, 07:00 AM   #2
murda-c
murda-c's Avatar
You must have timed it wrong. Intake backfire is caused by the plugs firing before the intake valve is closed, so your ignition or cam timing are probably off.
Old 03-22-2010, 09:07 AM   #3
thelrgkid
thelrgkid's Avatar
Before posting this I pulled covers twice. I just pulled the top cover and cams and it was perfect I re did it anyways and put it all back properly. It still backfires. Any more ideas?? Thanks
Old 03-22-2010, 03:01 PM   #4
kujacks
kujacks's Avatar
kujacks is an unknown quantity at this point
take it to a shop
kujacks is offline   Reply With Quote
Old 03-22-2010, 03:55 PM   #5
thelrgkid
thelrgkid's Avatar
Originally Posted by kujacks View Post
take it to a shop
I would if I had the money to.. That's why I'm asking for help on a forum!!! Your comment was no help...
Old 03-22-2010, 10:08 PM   #6
modulation
modulation is an unknown quantity at this point
Double check you got your cams right, if that's it then you are probably a tooth off on the distributor. Have you pulled your TPS harness and verified your timing with a timing gun?
modulation is offline   Reply With Quote
Old 03-23-2010, 12:53 AM   #7
thelrgkid
thelrgkid's Avatar
Thanks. I pulled the tps before and timed it but I was just on the wring mark. After fixing it it runs like new!! Thanks
