Old 03-15-2010, 06:34 PM   #1
lumbo007
lumbo007 is an unknown quantity at this point
s14 Power door lock help
So I have a '95 s14 se with s14 zenki sr swap in it. I think the car may have had a factory alarm (there is a hood sensor, and 4-wire power lock connector) but I accidentally threw away the stock alarm brain so I'm using the JDM one (which didn't have a hood sensor).
Here's my problem:
My drivers side power lock doesn't work but my passenger side works fine. I can use the switch or lock/unlock the drivers door and the passenger side will lock/unlock. I took out the actuator and plugged it into the passenger side and it works so it's not the actuator itself.
Anyone have any ideas what to check? I'm hoping it's just bad stock wiring and not the factory alarm. Any help would be appreciated.
Even in darkness, a keen eye can detect light.
lumbo007 is offline   Reply With Quote
Old 03-15-2010, 06:40 PM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
your 95 s14 has a zenki swap what?
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 03-15-2010, 06:57 PM   #3
lumbo007
zenki s14 sr swap. I must have accidentally erased the SR part.
Old 03-16-2010, 08:07 AM   #4
projectRDM
projectRDM's Avatar
All 1995 SE models were equipped with the OE keyless security.
If you removed the smart entrance control unit (silver metal box above the hood release) then your power locks will no longer work. That unit is also the door lock relays, rear defogger timer, and the key warning buzzer control. If you have a black plastic box in place of it, it's the same unit but does not have the security and keyless control. In any event, it's probably a faulty unit since wiring typically doesn't go bad, but you can check for continuity between the unit and the actuator.
FORMERLY R240NA
Old 03-16-2010, 01:32 PM   #5
lumbo007
So the JDM one I have in there is black so I would lose the keyless control (which I never had the remotes for) and factory alarm, which I don't care about. So would any s14 control unit work, or does it have to be a 95 se?
Old 03-16-2010, 07:43 PM   #6
projectRDM
projectRDM's Avatar
I doubt the pinouts are the same for the base and keyless models. Scan the FSM to verify, if so any 95-98 with power locks will work.
FORMERLY R240NA
Old 05-28-2012, 11:34 AM   #7
gtstwincam
gtstwincam's Avatar
gtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud ofgtstwincam has much to be proud of
Send a message via AIM to gtstwincam Send a message via Yahoo to gtstwincam
lock problem
Did you ever figure out why your driver door lock doesnt work?
Here's my problem:
gtstwincam is offline   Reply With Quote
