Old 03-01-2010, 10:36 AM   #1
slider2828
slider2828's Avatar
Using Water Temp Gauge as Oil Temp
Hey Guys,
I had an extra water temp gauge laying around that reads from 100F to 250F...
Do you think I can use it as an oil temp gauge?
Turn and Burn!
Old 03-01-2010, 11:50 AM   #2
g6civcx
g6civcx's Avatar
Originally Posted by slider2828 View Post
Hey Guys,
You did not say what manufacturer or what kind of design. Mechanical or electronic sender?
The only thing I can say is call the manufacturer and ask them.
Old 03-01-2010, 04:38 PM   #3
slider2828
slider2828's Avatar
Woops sorry, its an autometer... Its a eletronic sender. Thanks!
**EDIT: Oh wellz its probably fine to use if it is electronic. Now I am wonder where the best place is to measure oil temperature... I was thinking where the stock oil pressure sensor is the best place, as the pan might be too cool.... Anyone?***
Turn and Burn!
Old 03-01-2010, 04:51 PM   #4
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
if its autometer id say it should work, most lower model gauges use the same temp sensor for both water and oil, like they use same press sensor for fuel and oil...I.E. STRi
sometimes even on the instructions itll say "for oil and water temp gauge use" on it...
though calling the manufacturer would be ideal.
PSN
& XBL GT : Wh0pp3r68
Old 03-01-2010, 05:19 PM   #5
g6civcx
g6civcx's Avatar
Oil temp is not as crucial as water temp and oil pressure.
Put it wherever convenient for you.
