02-09-2010, 10:32 PM | #1 |
DZ's "Nobody likes z31's" build
This is a brief overview of my build that's been ongoing for about the last 2 years give or take. I stopped counting the amount of cash that's gone into this thing, but I still feel it's all worth it!
We'll start at the beginning. The car was first picked up from Vancouver and driven the 3 hours home. This is my 2nd Z, my first being an 86n/a that was sold in summer of '06. This is one of the very first pics I have of her. Fresh from Vancouver (to Kelowna at the time) What the interior looked like: If your eyes are bleeding, don't worry, it's a natural reaction to that interior. Engine shot, nothing special. After a few modifications here and there. At the time was running about 8.5psi on the stock (itty bitty) t25 turbo. Started to pull apart the shitty red interior piece by piece replacing it with what I could find locally The turbo finally gave up the ghost on a trip to edmonton (leaving me with a $700 tow bill, nice) I got the car home and pulled the engine apart, luckily there was no damage to the lower end at all. I had the heads ported and had a 5angle valve job done. Put on a bunch of other misc goodies and packed it away for the winter again (back to school) After winter was over I finally brought the car to Calgary after I found a place with a garage for it, and did a few suspension mods to start with (polyurethane bushings everywhere) A little paint to make it look nice and clean. I then proceeded to drop the rear subframe to replace the bushings back there, turns out that the control arm bolts like to rust into one solid lump, so that took some doing to get out and proper I then found some of my most favoritest thing in the entire world, Cancer. Made a 3" downpipe out of some 304 food-grade stainless Got the rear end stuff cleaned and painted Screamer pipe |
02-09-2010, 10:33 PM | #2 |
Decided that my stock, busted ass suspension needed some work dearly, so I went ahead and got some custom stuff done up to work with s13 GR+ Stance coilovers. The amount of z31's with a proper ride height is Severely lacking, stance = moar low.
Custom rear upper mount Serialnine weld-on collar adapters installed onto cut down stock strut tubes, powder coated beautifully. Fronts installed with z32 30mm iron calipers Fuel pressure regulator on custom mount. Halfass engine bay shots, sans plenum and piping: Custom made intake plenum. First startup video, ignore the last few seconds :dunno: YouTube - 1988 300zxt first startup in 2 years A very dusty, Very battleshipped Z31. New wheels were planned for before the layoff, now she sits on stock shoes looking silly. I've given the car a very very base tune, taken it about the block a few times, it runs, drives on its own power which it hasn't for 3 years, and sounds mean as hell. The plans now are to take it back to Kelowna where it'll sit for another 3 long years whilst I get my degree in Mechanical engineering. Oh, and the entire interior is all black now, including carpet I'll do my best for a mods list, but I'm sure I'll miss some of stuff. Engine: GT3571 journal bearing turbo 3" thick aluminum radiator 3" thick intercooler 16 row oil cooler 42mm turbonetics racegate custom intake manifold 3" custom downpipe ls1 stainless steel exhaust manifold studs ($$$$) P&P heads 5 angle valve job Colt cams 'stage 2' turbo regrinds SATAN turbo relocation exhaust manifold schneider valve springs 1 5/8" screamer pipe DEI exhaust wrap Fuel/control: Nistune type 1 board Walbro 255lph pump from an s13 550cc SARD injectors (same as fc turboII) A1000-6 FPR AL fuel fittings all around Billet -6 fuel rails Innovate LC-1 wideband w/ G3 afr gauge. Brakes/footwork s13 Stance GR+ coilovers Serialnine weld-on collars custom rear upper and lower coilover mounts MSA anti-sway bar endlinks Prothane total kit polyurethane bushings 1990 z32 30mm 4 pot iron brake calipers z32 front rotors s13 to z32 brake lines from PDM Ebay s13 short shifter Drivetrain: Centerforce dual friction clutch Stock R200 LSD (clutch type) rebuild with 6 clutches (2 stock) custom solid rear differential mount custom solid rear crossmember mounts Polyurethane transmission mount Polyurethane engine mounts. Stock FS5R30A transmission (same guts as z32tt transmissions) Interior: Autometer gauges all around (boost, oil temp, water temp, oil pressure) Pleather racing seats (can't remember brand) custom mounts 2 kicker compvr 10" subs Oldschool kenwood deck oldschool RF amp. Red interior converted to black, every, single, last, piece. lo-tek 3 gauge pod |
02-09-2010, 10:36 PM | #3 |
A few last pics...
Some pics of the shroud between the radiator and intercooler. Ran outta time and material to do between the fascia and intercooler, but that'll be one of the first things on the list when the work starts up again. And one last shot. Needs new wheels badly, one of the first things to do to it before she gets roadworthy. |
02-09-2010, 10:43 PM | #4 |
Trader Rating: (58)
Feedback Score: 58 reviews
Aweosme progress man! Always good to see a true DIY guy on this site...definatly a nice 'break' from the 'lemming march' you see all to often on here.
Keep updated this, great 'rebuild' thread!
02-10-2010, 10:34 AM | #5 |
looks damn good,
always had a soft spot for the Z31's. Keep up the good work, make sure to keep us updated.
02-10-2010, 10:52 AM | #6 |
Nice! Need to see more Z31 love. I've got an Air Force buddy that's looking for 600+whp out of his when it's done, and another guy in Nashville who's slowly but surely making his into a beast as well.
Subscribed. |
02-10-2010, 05:31 PM | #7 | |
i miss my Z. when the motor and tranny blew i had to get rid of it due to the fact it was my daily and i couldnt take on another project car. had a few mods and put on some wheels never had a chance to drop it. heres a pic. gl with build.
02-11-2010, 01:40 AM | #9 |
Thanks for the kind words guys, I'm away from the car right now but am planning to make some adjustable front control arms as my next suspension project to go with the adjustable tension rods that are in the mix right now.
I'd love to be able to just up and buy parts, but there simply isn't a legitimate aftermarket out there for those kinds of modifications. Once I've moved to Vancouver I'm hoping to find a place to store the car that's near me, would be great to have it ready for summer. |
03-24-2010, 03:02 PM | #13 |
Lookin great, where can I get that turbo relocation pipe AND that spiffy intake mani, got anymore to fab and sell?
91 Bmw 318is 90 S13 (sr20det) |
05-05-2010, 08:54 PM | #19 |
this is hella clean!! one day ill be able to post my build just like yours but @ 19 living on your own it kinda sucks and my Z is my daily soo i cant have it down at all ..
btw great z build (kuudoosss) |
05-10-2010, 10:23 PM | #25 |
badass!!! mine is a 88!!! i just put z32 wheels and i had to put a 20mm space up front so the tire dosent rub the strut .. the fronts are 2255016 and the rears are 2455016
05-15-2010, 09:54 AM | #27 |
hehehe I just found this pic kicking around on the pc.
This is why semi-trialing arm suspension fails: not to mention stock wheel fitment epic failure. |
05-24-2010, 01:25 AM | #29 |
lol thanks, got some new rear lower quarters in the mail to replace mine that are totally rusted out. gotta love leaky taillights/rear 1/4 windows. was a long weekend and I really should have brought the z out, but things didn't work out.
07-10-2010, 11:20 PM | #30 |
Yes very good job, guess that engineer school came in handly ha!!! fortunally everyone is not able to do this type of project, like myself did the brushing on front end job on my 87 zx n/t . have to contract some works out. also put the 3" pipe from the caytalat to the rear. bought it from thezstore. sound great. looking forwarding in see you finished this babe up. oh by the way would had stay with the orginal interior but its all good , its ur babe. so hope all is good for you, am in the tacoma area . peace.
