Old 02-06-2010, 08:01 PM   #1
grks13kat
grks13kat's Avatar
grks13kat is an unknown quantity at this point
Send a message via AIM to grks13kat
KA 91 s13 blinking Check Engine Light Problem
Hey guys. I have a 91 240sx with stock ka24de. I went for smog today, and the curse of smog struck me and the Check Engine Light turned on in the middle of the test. Its not a solid light, and blinks on and off randomly. It could be as random as me touching the gas pedal and it turns on, to hitting a bump and also having it turn on. It comes and goes as it pleases. Also with the car on ACC, the lights in the lower left of the instrument panel dont come as they should. Any input? thanks in advance.
chris
grks13kat is offline   Reply With Quote
Old 02-07-2010, 11:37 PM   #2
grks13kat
grks13kat's Avatar
No thoughts?
Old 02-08-2010, 12:02 AM   #3
lou's40sx
Trader Rating: (54)
lou's40sx is an unknown quantity at this point
Feedback Score: 54 reviews
EGR. System. 100%
PM me if you want a long and tedious explanation.
lou's40sx is offline   Reply With Quote
Old 02-08-2010, 12:21 AM   #4
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
um no, knock sensor, as soon as you rev or do anything itll vibrate it and make the check engine light pretty much brink on and off to the vibration.
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline   Reply With Quote
Old 02-08-2010, 12:29 AM   #5
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Seriously? Dude first check the ecu to see if it ACTUALLY throwing a code instead of replacing shit everyone else is guessing about. Post up the code if it is throwing one and we will go from there.
LayNLow is offline   Reply With Quote
Old 02-08-2010, 12:35 AM   #6
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
only if it throws a code 34 but usually when it does that the ecu retards the timing.
my car did the same thing. your motor mounts good? mine were shot there for sending a ping to the sensor everytime i hit the gas.
repda916 is offline   Reply With Quote
Old 02-09-2010, 05:09 PM   #7
grks13kat
grks13kat's Avatar
No theres no code. Just the 55 code, which im pretty sure means no errors. As for engine mounts, they need to be replaced. another problem i ran into, was when i was taking apart the dash, my screwdriver crossed two terminals behing the ignition. Where you put the key in, behind the unit there are a series of terminals and the screwdriver touched 2 together and now my tach and speedometer dont work. I know something obviously shorted out, as i did see a giant ass spark, any thoughts? I swapped in a new cluster and still the same problem. Maybe the ECU?
Old 02-10-2010, 05:31 PM   #8
grks13kat
grks13kat's Avatar
Im pretty sure it shorted something out in the computer.
