Old 10-30-2009, 01:41 PM   #1
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
Head Gasket Installation - SR20DET
Since it seems there is limited, and sometimes contradicting, information regarding a head gasket installation; I felt I would share my pictures and experiences in hopes of constructing a helpful/resourceful thread.
Since head gasket removal was covered quite well by an individual on NICOclub, I will just provide the link to that thread.
DIY: SR20DET Head Removal by Mrzabala: SR20DET Forum (rear-drive): Nissan Forums / Infiniti Forums - NICOclub
Depending on what your needs are for your particular project, your repairs or upgrades, may differ from mine. As some of you may know, and for the ones who don't http://zilvia.net/f/engine-tech/2777...ur-screws.html , my engine recently ate a throttle body screw and so needed some repairs. I had the head decked, cleaned, JWT valve guides installed, new seals, compression zones checked, head assembled, and a missing cam cap replaced/fitted.
Before you get started, its a good idea to go ahead and bleed your hydraulic lifters; its very easy and only takes a minute. The lifter removes just by pulling on the exposed end and is located under the outside leg of the rocker arm.
Submerge the lifter in a container of new oil and depress the check valve located inside, at the base, the lifter. the FSM lists the use of a "suitable tool" so I used an appropriate sized allen wrench. with the check valve depressed go ahead and compress the top of the lifter until you feel it bottom out; you can release the check valve at this point. You should see air bubbles if its needed and once you're done, the lifter shouldn't compress anymore. Repeat if necessary.
Next you want to go a head and clean the block surface as well as you can. I used a window scrapper with a new razor to remove the majority and then a dremal with a some what nonabrasive wheel, you don't want to create low spots. Use good judgment and just clean it. After its clean go ahead and apply a continuous bead of gray liquid gasket to the front timing cover area. Remember that a little goes a long way, so don't get carried away with a 0.250" bead.
Install head gasket. This step is somewhat debated, I choose to use Copper Spray for added tack on the two surfaces but I know that you don't necessary have too. As it was explained to me, it can't hurt but could help and I have no experience to argue otherwise.
Next apply another continuous bead on top of the gasket around the front timing cover area. My understanding for this is only to prevent weeping from the front cover.
After you drop the head on, its now time to install the head studs. I am using ARP hardware so here is the information to know. If you are reusing head studs, its important to verify that they have not stretched. The area of stretch is usually in the threaded area of the stud its self, so look for differences in diameter. The O.A. length should be 6.600" +/- 0.010". Replace them if it exceeds this tolerance.
To install them, you use a standard (not metric) allen wrench and thread them all the way down into the block. You need only to snug them down, no torque spec's req'd. DO NOT USE bolt smoothing compound on block threads!
Install all 12pt nuts and washers with bolt smoothing compound. From my research, it seems there are two versions of head studs. Apparently, ARP has redone the kit for the SR20DET and now requires 105ft/lbs. I have an older kit which requires 80ft/lbs; this will be the 3rd time I've reused these. Refer to the FSM for exact torque sequence, or just remember: tighten from the inside out and loosen from the outside in. Tighten them in stages and let your last torque set be your biggest jump. I did...
25ft/lbs - 55ft/lbs - 80ft/lbs
Don't forget to reinstall the 4 remaining, 10mm socket, screws shown removed in the thread listed above.
The next step is to reinstall your mechanical timing assembly, set your timing chain tensioner and reinstall your CAS @ 15deg BTDC. The FSM calls for you to separate the cam sprockets from their corresponding shafts but its not necessary to install them. Make sure you have the dots at the silver links and the crank still at the second mark from the left.
After all of this is done, and after rotating the assembly nothing binds, reinstall your intake manifold and associate components and the same for the exhaust side. I hope this was helpful...
Please add your experiences or comments. I'll let you know if something doesn't work out right...
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 10-30-2009, 02:28 PM   #2
Tearlessj
Tearlessj's Avatar
OK, now I have always heard that you HAVE to get your head and blocked decked to use a metal headgasket. Anyone know this for sure?
Good write up for sure though. +1!
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 10-30-2009, 02:31 PM   #3
s14unimog
s14unimog's Avatar
Trader Rating: (22)
I would say for sure on the head, especially since it usually warps long before the block does. Mine was merely surfaced, it was within FSM tolerances. You can always do the straight edge and shim pack test to be sure.
Old 10-30-2009, 02:46 PM   #4
240sxfamily
240sxfamily is an unknown quantity at this point
yeah same. people have been telling me that but im using the copper spray for an extra seal.
240sxfamily is offline   Reply With Quote
Old 10-30-2009, 02:52 PM   #5
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
Nice writeup!
The head generally seals to the block just fine (I do recommend resurface/deck) providing everything is very clean and stright. ARP hardware is highly recommended when using a MLS Type HeadGasket. Stock old SR head bolts will stretch... PERIOD. The problem with improper MLS HG installations are typically found at the front cover mating surfaces. Watch for leaks...
~mario
edit:
Why not...
Old Time Engine Builders used to spray a light coat of paint onto the headgasket to help promote sealing of water/oil passages.
~m
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 10-30-2009, 02:54 PM   #6
s14unimog
s14unimog's Avatar
Trader Rating: (22)
^ yeah that is a concern of mine, I have another SR powered car I picked up from a guy and its weeping from the front cover...what a bitch. This is my first head gasket install so I hope everything works out.
Old 10-30-2009, 03:00 PM   #7
Pure_JDM
Pure_JDM is an unknown quantity at this point
ditto^... mine's weeping there as well, so a new looks in the near future for me.
Pure_JDM is offline   Reply With Quote
Old 10-30-2009, 03:01 PM   #8
240sxfamily
So then the spray does seal it more properly? My head is decked and stuff but the block isn't.
Old 10-30-2009, 03:05 PM   #9
s14unimog
s14unimog's Avatar
Trader Rating: (22)
The Copper spray is ONLY a tack spray for the head gasket its self. The Grey Silicone is for the front seal and prevents the oil weeping
I have talked to a number of different professional engine builders and the consensus is to USE copper spray.
Old 10-30-2009, 03:09 PM   #10
let5l1de
let5l1de's Avatar
Trader Rating: (30)
The copper spray will help seal the inconsistencies or very slight imperfections that a metal gasket will not.
MLS type HG's are exceptional for hi boost apps but are unforgiving. Use a high performance Fel-Pro HG when you can, epically for beginners...
~m
Old 10-30-2009, 03:11 PM   #11
let5l1de
let5l1de's Avatar
Trader Rating: (30)
The tack spray is to seal as well... I am an engine builder.
~m
Old 10-30-2009, 03:15 PM   #12
s14unimog
s14unimog's Avatar
Trader Rating: (22)
^ Right, only to help the head gasket seal not prevent oil weeping from the front cover. I am using the Cosworth MLS b/c I run low boost @ 15psi and high boost @ 25psi . I dyno'd 394rwhp @ ~17psi, it ran great until the screw was eaten; that was about 300 miles after tunning.
Old 10-30-2009, 03:18 PM   #13
240sxfamily
so shall i use RTV on the front cover piece? so it will seal that as well?
Old 10-30-2009, 03:19 PM   #14
let5l1de
let5l1de's Avatar
Trader Rating: (30)
Did you use any sealant on the headgasket between the timing chain cover & head? If so, what did you use.
~m
EDIT:
looked at the pics... It's grey sealant with no copper spray.
This is good for most novice builders since it does seal larger imperfections much better. I may or may not use the grey sealant (always use coppers spay) between the front cover & head depending on machine work performed and type of build. If you slap a MLS HG on without kissing the block and cover, you will almost certainly need a thicker grey sealant because of imperfections at the cover to block mating surface
~m
Last edited by let5l1de; 10-30-2009 at 03:39 PM.. Reason: Fixed front cover: Thinking KA, Remainder of post remains VALID
Old 10-30-2009, 03:22 PM   #15
s14unimog
s14unimog's Avatar
Trader Rating: (22)
yeah, see the pictures? there is only one timing chain cover, we're talking SR20 here (noticing your avatar)
Old 10-30-2009, 03:32 PM   #16
let5l1de
let5l1de's Avatar
Trader Rating: (30)
Sry for my lost train of thought... Cover and head... One more reason why less leaks should be prominent for SR front cover/head....
The area I'm concerned with on either KA or SR is the squareness of the top of the timing cover and block.
Old 10-30-2009, 03:47 PM   #17
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Just some FYI:
I used VW ARP head studs sold by frsport.com. The reason they gave me was, it's slightly longer and will make up for thicker head gaskets. It fits and holding fine on my SR. Tip, when lubing the head studs, don't get any on the ends that go into the block. If you do, the lube will not compress and you'll get inaccurate torques. Meaning keep the lube on the threads.
VNG704 is offline   Reply With Quote
Old 10-30-2009, 03:49 PM   #18
s14unimog
s14unimog's Avatar
Trader Rating: (22)
^ good point! I only used it on the top. Bolt smoothing compound should ONLY be used on threads that are NOT blind projection.
Old 10-30-2009, 03:54 PM   #19
let5l1de
let5l1de's Avatar
Trader Rating: (30)
Originally Posted by VNG704 View Post
Just some FYI:
VW as in 1.8L, available in a few different diameters as well.
~m
Old 10-30-2009, 06:41 PM   #20
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK Send a message via Skype™ to HYPNOTIK
Someone mentioned a Fel Pro HG and I've been considering using one as well. Does anyone have any first hand experience with a fel pro on a SR? Good, bad?
HYPNOTIK is offline   Reply With Quote
Old 10-30-2009, 11:04 PM   #21
ericb382
ericb382 is an unknown quantity at this point
I called apexi (since I was using an apexi HG) before I installed mine and asked if they recomend copper spray/RTV. They said no to both.
The way I look at it, the only time you need RTV around the front cover is if you haven't had the block and front cover decked together. If both your block and head have been resurfaced, no need for copper spray. If you've taken a straight edge to them (not freshly machined) and they are good, copper spray.
I also heard contradicting stories as to whether or not it was necessary to retorque head studs after heat cycling a metal HG. I called ARP for this (as I was using their studs,) they said yes. After your first heat cycle go through, break each headstud loose, and retorque. One at a time.
I'm sure some people will disagree with me on my outlook on copper spray and whether it's worth re-torquing, but I like to get my recomendations directly from the manufacturers. Yes, I know, many people get away without retorquing, but it takes maybe an hour. Why not have the added security.
ericb382 is offline   Reply With Quote
Old 10-31-2009, 01:23 AM   #22
let5l1de
let5l1de's Avatar
Trader Rating: (30)
Many MLS HG Manufactures actually recommend no spray or rtv due to possibly hindering the ability to seal properly. Another example is Cometic. Cometic Gasket Inc. also recommends a dry install due to the fact that a .001" thick viton rubber seal is bonded to the outer metal layers.
I generally support this theory. So many people just buy the MLS type HeadGaskets and install without reading or ignoring the proper procedures for installation.
I also generally agree with re-torquing the bolts or studs after the initial full heat cycle. Again, people disregard instructions or they are too lazy to perform this re-torque procedure.This can be an engine saving step that doesn't take very long to perform.
Factory recommendations is where I start as well, but all too often we run into situations the factory respectfully have never fully addressed. Seek advice from quality engine builders familiar with your build combined with MFG recommendations and your best judgment.
~m
Old 11-02-2009, 08:03 AM   #23
s14unimog
s14unimog's Avatar
Trader Rating: (22)
I think there are a few different ways to complete a head gasket installation and I think they change based on what kind of gasket you use. I was also advised from one of my information sources to re-torque them. He also recommended I paint the 12pt nut and stud so that I can see how many rotations I actually pick up; its not necessary to paint them, but it shows you the difference.
As for the discrepancy between copper spray and liquid gasket on the timing cover area. I think the copper spray is optional, but as it was explained to me, "it can't hurt but it could help" so I choose to go that route. As for the liquid gasket, I don't think its optional. The FSM clearly indicated that it IS necessary for the installation and we all know, this would have considered perfect parts being installed; enough reason for me.
Old 11-02-2009, 10:53 AM   #24
ericb382
But the FSM is assuming you are using a stock HG. Once you switch to a metal HG, you should use the specs designated by the mfg of the HG.
Old 11-02-2009, 02:07 PM   #25
s14unimog
s14unimog's Avatar
Trader Rating: (22)
Correct, but consider the differences of the two head gaskets and the specific location in question. Would you honestly put that back together without liquid gasket? Especially when considering the sealing issues associated with a MLS type head gasket when compared to an OEM one.
Old 11-03-2009, 06:47 AM   #26
ericb382
If the block and front cover were decked together like they are supposed to be, yes. I didn't have any problems with mine leaking....
Old 11-04-2009, 10:25 AM   #27
s14unimog
s14unimog's Avatar
Trader Rating: (22)
I can't agree with you. The FSM lists for you to use it and it would have considered a perfect decking surface between the two surfaces. I'm glad yours isn't leaking though.
Old 11-04-2009, 02:32 PM   #28
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
I had my head decked but not my block. Used the copper spray with a apex-i 1.1mm. My leakdown test says i have about 6% leakdown in all cyclinders which is bacially what a brand new engine will read.
So no you don;t have to get the block decked. Just deck the head and use the spray and it should be fine.
rc1honda is offline   Reply With Quote
Old 11-04-2009, 02:56 PM   #29
let5l1de
let5l1de's Avatar
Trader Rating: (30)
Please keep in mind that all engine tolerance/clearance are not all the same form one engine to another. IMO every engine that is receiving the MLS HG upgrade should be check for squareness with a straightedge on both head and block.
Some get away with slapping a MLS HG on, others pay the price with a leaking front cover. They typically seal the cylinders without an issue.
~m
Old 11-04-2009, 05:20 PM   #30
ericb382
The FSM gives procedures for a stock HG. We are talking about aftermarket HG's. I hope you wouldn't use the FSM's torque specs when torquing down ARP head studs.... Same concept.
Like I mentioned earlier, I called Apexi (the manufacturer of my HG) and asked them what they recomend for THEIR HG. They said not to use anything. I didn't and it worked perfect. Like I also mentioned earlier, there are some instances where I would deviate from their recomendations to match a specific application, but in a perfect world (head, block and front cover machined) you don't need it.
