Old 10-13-2009, 08:16 AM   #1
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
Brake pads rubbing against rotor while driving?
First off, my car has been sitting for about 3 months but even before that I've noticed a sound, particularly as im passing something like a wall or a car. It sounds like metal spinning against metal. What's the best process to troubleshoot this? I noticed too that when I was fixing my car as I was pushing it somewhere I could hear the brake pads rubbing against the rotors. I figured it was doing that because it was sitting for so long.
Almost there.
Mangudai is offline   Reply With Quote
Old 10-13-2009, 08:31 AM   #2
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
ok did you even look to see if the brake pads are rubbing the rotors? That the sound is coming from there. possibly the brake shield rubbing against the rotor..?
Maiku240sxS14 is offline   Reply With Quote
Old 10-13-2009, 08:53 AM   #3
Mangudai
Mangudai's Avatar
Of course I did, they're right against the rotors, It didn't occur to me that it could be the brake shield though.
Almost there.
Old 10-13-2009, 08:57 AM   #4
projectRDM
projectRDM's Avatar
The brake pads always sit against the rotor on any car. It's not like when you let the pedal off the piston pulls back in and leaves a gap, otherwise next time you applied the brakes your entire pedal effort would go to just reseating the pads, and you would then either have to press the pedal again or run into the object you're trying to avoid.
How much contact is your question here. Front, or rear? The rear calipers always seize up on an Schassis, so that's a definite possibility. Fronts rarely do but could be frozen from sitting, so instead of guessing, jack the car up and verify which caliper is the issue.
FORMERLY R240NA
Old 10-13-2009, 09:55 AM   #5
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Have you checked how much meat you have left on the pads? lol maybe it's time for new brake pads and they are riding on the squeelers.
DataXUnknown is offline   Reply With Quote
Old 10-13-2009, 10:03 AM   #6
Mangudai
Mangudai's Avatar
I'll inspect each wheel closer and see what's up.
Almost there.
Old 10-13-2009, 10:15 AM   #7
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
on my s14 my rear caliper seized(ebrake wouldnt release) so i got some pb blaster and sprayed the ebrake spring and played with the spring a little bit and got it to work awesome now... there was rust, dirt ect on it...
Ceepo is offline   Reply With Quote
Old 10-13-2009, 10:35 AM   #8
tsx1racer04
tsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to behold
I think you need new brake pads, could be the tabs inside the pads letting you know that you need new ones.
tsx1racer04 is offline   Reply With Quote
Old 10-13-2009, 01:16 PM   #9
RNGWLD
RNGWLD's Avatar
RNGWLD is an unknown quantity at this point
Originally Posted by Mangudai View Post
First off, my car has been sitting for about 3 months but even before that I've noticed a sound, particularly as my passing something like a wall or a car that sounds like metal spinning against metal. What's the best process to troubleshoot this? I noticed too that when I was fixing my car as I was pushing it somewhere I could hear the brake pads rubbing against the rotors. I figured it was doing that because it was sitting for so long.
Something similar happened to me...except the noise was hardcore. Turned out to be the brake shield so check that first. I took off the pads as well and cleaned up the discs to be sure. Noise went away
RNGWLD is offline   Reply With Quote
Old 10-13-2009, 02:19 PM   #10
OBEEWON
OBEEWON's Avatar
Spray I can't believe its not butter on your rotors. Problem solved.
Old 10-13-2009, 04:03 PM   #11
ghost
ghost's Avatar
ghost is on a distinguished road
Check to see if your sliders are seized. I get a lot of customers coming in complaining about their brakes dragging. All it takes is some heat, some vice grips and a wire wheel to clean them up. Then re-grease them.
1993 180sx Type III
219whp, 235ft/lbs tq
ghost is offline   Reply With Quote
Old 10-13-2009, 04:06 PM   #12
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
i lol'ed
slideways2004 is offline   Reply With Quote
Old 10-15-2009, 12:25 AM   #13
David B S12
David B S12 is an unknown quantity at this point
you really started this thread without checking your pads and taking the wheel off?do you like being spoonfed?
David B S12 is offline   Reply With Quote
Old 10-15-2009, 12:39 AM   #14
WakeBHR
WakeBHR's Avatar
WakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud ofWakeBHR has much to be proud of
Send a message via AIM to WakeBHR Send a message via Yahoo to WakeBHR
why yes....
yes he does
S.P.P.S. Member #00
**CoUpe LOve** Member #00
WakeBHR is offline   Reply With Quote
Old 10-15-2009, 02:17 AM   #15
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
Honestly I'd just sell the thing. You always post up threads like this. Always.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 10-15-2009, 08:26 PM   #16
Mangudai
Mangudai's Avatar
Way past that now, had a long list when I got it but just a few more things and everything will be good. Honestly? I didn't initially take my wheels off because I didn't know what I was looking for but like I said I'll check it. Peace.
Almost there.
Old 10-15-2009, 09:10 PM   #17
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
dude,
just give it to me
lol
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 10-16-2009, 04:02 PM   #18
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
warn wheel bearings will cause that. the rotor will move slightly with the hub..
check your bearings. under racing conditions it can be pretty drastic its called knock back
Chrischeezer is offline   Reply With Quote
Old 10-17-2009, 02:57 PM   #19
VG30Drift
VG30Drift's Avatar
VG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymore
I have endless SSS pads w/ drilled/slotted rotors. They make a noise constantly while in motion, and I can hear them especially loud when passing a fence/guardrail etc. Are you running drilled/slotted rotors? It might just be normal noise.
'94 NA Z----------------'90 S13 Base Coupe
VG30Drift is offline   Reply With Quote
Old 10-17-2009, 03:25 PM   #20
kushlivin
kushlivin's Avatar
kushlivin is an unknown quantity at this point
Originally Posted by obeewon View Post
spray i can't believe its not butter on your rotors. Problem solved.
lmao rofl lol hahahaha
HP is for gays.
Girls think stock KA's are fast.
kushlivin is offline   Reply With Quote
Old 10-17-2009, 09:43 PM   #21
Mangudai
Mangudai's Avatar
No but I will be buying slotted rotors very soon. My front pads and rotors need to be replaced.
Almost there.
Old 10-17-2009, 10:09 PM   #22
SR_Vlurs
SR_Vlurs's Avatar
SR_Vlurs is an unknown quantity at this point
Send a message via Yahoo to SR_Vlurs
^^^ lmao i cant stop laughing at ur comment man great stuff
¿$phinx?
SR_Vlurs is offline   Reply With Quote
Old 10-17-2009, 10:50 PM   #23
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
weird, first thing i would have done was i dunno maybe check what was wrong with it, i don't make a thread until i've worked on it for a week straight and i'm so lost that i'm about to set my car on fire and watch it burn, oh and just a little f.f. there is a section for things like this called tech talk
slow40sx is offline   Reply With Quote
Old 10-18-2009, 12:19 AM   #24
tanks13
tanks13's Avatar
tanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of light
Send a message via AIM to tanks13 Send a message via Yahoo to tanks13
try pushing the caliper back in that was my problem
tanks13 is offline   Reply With Quote
