Old 06-09-2009, 10:12 PM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
18g and 20g or 25g turbo users
i would like some info and share some info on what could benefit each other. i know that there isnt too many guys who are into these turbos but i've most people go after the garret series of turbos. i would like to see more people who uses mistsubishi turbos and their thoughts
please post your engine specs
1. your motor
2. motor specs
3.turbo size 18g or 20g turbo, etc.......
4.fuel injector size and brand
5. tune or untune
6. engine management system
i'll add more when i can think of more
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-10-2009, 07:27 AM   #2
fliprayzin240sx
No S14 4 the 1st time in 14yrs
fliprayzin240sx's Avatar
When I first got the car, it had a Greddy T518Z turbo on it. S15 Spec R engine with 550cc injectors with a rom tune. Changed the injectors to 850cc SARDs and PFC, figured turbo was pushing close to 350hp. Compared to my GT2871R in the states, setup wasnt smooth compared to it. GT2871Rs has a more linear power band, T518Z was more like an on/off switch.
The beauty of the Mitsubishi turbos are that they're rebuildable. $80 for the rebuild kits.
I know a couple of folks out here who run Mitsu turbos. With the 20G, one guy made about 380-390 hp and 2 guys were running 25Gs. One made 460hp and the other was at 485hp.
CLICK HERE!!!
Old 06-10-2009, 10:51 AM   #3
s13silvia123
thanks for the info dude i would like to see more poeple who has these turbos
Old 06-11-2009, 12:35 PM   #4
deukalionS14
deukalionS14's Avatar
deukalionS14 is an unknown quantity at this point
i was looking into the GReddy varient of the TD-06 20g turbo too...I need info on this thing! lol
want to be in the 500whp club by the end of next year!!!
deukalionS14 is offline   Reply With Quote
Old 07-02-2009, 03:15 PM   #5
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
1. s13/s14 Hybrid SR20DET
2. Engine Spec list:HERE
3. FP TD06SL2 20G
4. Nismo 740cc / 300zxtt fuel pump
5. Tuned
6. Nistune
Due to, what we believe is, a problem with the actuator opening prematurely, my graph looks to be that of an N/A platform. The car spooled slowly and ended up spiking to around 17psi with no boost controller (using the 1bar actuator provided with the turbo). These are the results. I'm currently in the process of figuring out why its spooling so slow...
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 07-05-2009, 05:36 PM   #6
deukalionS14
anyother people have any input on these turbos?
Old 07-06-2009, 08:17 AM   #7
fliprayzin240sx
381 whp with shitty compression with a TD06-20G @1.2bar on Inertial Dynos
S14 Engine, Power FC D-jetro, 850cc's NISMO FP TD-06SH 25G at 1.5 bar Tomei 270 with 12.5mm lift, solid lifters, port&polished, Double vavle springs, Crappy Greddy 2 core FMIC, 60mm throttle body, Greddy Surge tank, Sard FPR
Couldnt find any TD05-18Gs on ZY, I had a Greddy T518Z that was basically an 18G. Comparing it to my GT2871R in the states, they were putting down about the same power (roughly 350whp). Only difference between the 2 was the power delivery. GT2871s, power came in more linear/smoothly. T518Z, it was more like an on/off switch. Nothing before 3.5k-4k, then full boost of fury that I'd loose traction like crazy. I wouldnt recommend it for drifting since itll just make you spin out when the power gets there.
CLICK HERE!!!
Old 09-17-2009, 12:48 AM   #8
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
Evo 9 16G 25psi stock engine just head gascket and studs.
On a dyno dynamics so its real numbers
Slip&Sliden 240 is offline   Reply With Quote
Old 09-17-2009, 02:03 AM   #9
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
No dyno yet....
Engine: s15, NOT BC (secret)270 cams, BC springs, BC retainers, New valve seals, New ring, all new bearings ect ect FULLY REBUILT S15 ENGINE NEW EVERYTHING
Turbo: 16g EVO 8 with twinscroll manifold NO PAIRED RUNNERS. But all equal length
Fuel: 720 nismo, Aeromotive FPR, Power FC
Like I said NO dyno but really fast for 18 psi, feels alot faster then s15 turbo at 18 psi
S14_Kouki is offline   Reply With Quote
Old 10-01-2011, 10:06 AM   #10
TSLegendary
TSLegendary's Avatar
TSLegendary is on the path to ruinTSLegendary is on the path to ruinTSLegendary is on the path to ruin
Send a message via AIM to TSLegendary
will the Greddy T518Z TD05 18G 10CM turbo bolt right on re-using the oil feed and oil return line/pipe from my GT2871R? Or will i have to piece Banjo bolts or fittings to make it work?
True Speed
TSLegendary is offline   Reply With Quote
Old 10-01-2011, 07:14 PM   #11
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
You know what, it makes more sense for people to buy evo8-9 turbo's because you could get the turbo for about $250 bucks on the evolutionm forum and make the same power as a gt2871r for a fraction of the price. just purchase the flanges that are really cheap to get and have some one weld you a kit.
@TS i think you will prolly be better off pieceing it togeather from a hardware store that sells that stuff.
1990 240sx fast back
SR
20det GTXX71R
Sips on E-85
1998 S14 Kouki
KA24de
Bone Stock......
2004 Lancer Evolution
S13 curtis is offline   Reply With Quote
Old 10-03-2011, 03:58 PM   #12
s13silvia123
oil feed fitting is different, i'm using a -3 an fitting i think its been quite a while now but as for the the rest they all fit
Old 10-20-2011, 05:11 PM   #13
TSLegendary
I installed the (rebuilt) turbo, and after being mis informed by the seller of the turbo, the S14/s15 return line didn't work. I ended up having to use the Mitubishi return line, after he insisted that the OEM nissan ones we're compatible. Long story short im stuck with a turbo with no shaft play and but smoking under boost. I used the Gt2871R line but with a 10 x 1.25 banjo bolt and banjo fitting. This is horrible, made me wish i just bought a new GT2871R then would have bought this. By the way thanks for responding guys.
True Speed
Old 10-23-2011, 07:33 PM   #14
s13silvia123
for the oil return line for my turbo i'm using a t25 return line with a rubber hose.
Old 09-11-2013, 02:32 PM   #15
s13silvia123
new info for customization Mitsubishi turbos
read this link
Kinugawa 25g turbo thread - evolutionm.net <-------
Old 09-12-2013, 01:54 AM   #16
!Zar!
6 God
!Zar!'s Avatar
1. S13sr with RAS
2. Pretty stock with circuit sport spark ignition
3. 18g @ 1.2bar
4. 555cc Tomei injectors / walbro 255 fuel pump
5. Tuned...
6. Enthalpy rom tune / bee*r ignition cut
No issues or complaints at all. 105 octane is a must for hot track days. Aside from that, power is awesome and my car has been extremely reliable.
Old 09-12-2013, 07:49 AM   #17
s13silvia123
1. S13sr with RAS
3. 18g @ 1.2bar
5. Tuned...
how much HP did you get out of your 18g? what it a 8 cm or 10 cm?
Old 09-12-2013, 07:04 PM   #18
Tom N
Tom N is an unknown quantity at this point
2.0 ltr
4g63
Evo 3 16g
FIC 850's
Tuned with DSMlink
414hp 430tq
I will be putting a 20g on the Nissan.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 07-22-2014, 01:04 AM   #19
kevinzhou
kevinzhou is an unknown quantity at this point
did any of you guys rebuild your turbo yet and with what kit. i have some shaft pay but my friend said it is normal since its a journal bearing turbo? any input would be greatly appreciated it moves side to side and minimal in and out
intragram: whoiskevinzhou
kevinzhou is offline   Reply With Quote
Old 07-22-2014, 07:18 AM   #20
Tom N
Some side to side play is normal. You shouldn't have any in and out though.
Old 07-22-2014, 01:31 PM   #21
kevinzhou
i think thrust bearings are bad but i might be over reacting any help would be great
https://www.youtube.com/watch?v=HO_shnR7g1E
http://www.youtube.com/watch?v=HO_shnR7g1E
Old 07-22-2014, 03:20 PM   #22
TheRealSy90
Four Lug Swap
TheRealSy90's Avatar
TheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to all
I'm still on the lookout for a 20g turbo with the traingle flanged exhaust housing to put on my Greddy Unequal length octopus manifold...
Originally Posted by dizzariot View Post
So god damn Japanese, your sweat probably smells like udon.
Old 01-28-2015, 09:37 AM   #23
bikerskater
bikerskater is an unknown quantity at this point
Just dyno tuned last night
Stock motor/cams just arp head studs and mls gasket
Greddy td06 20g bottom mounted to stock exhaust manifold
Freddy intake manifold
Power fc d jetro
E85 1000cc injectors stock fuel lines
22.4 psi
bikerskater is offline   Reply With Quote
Old 01-29-2015, 01:06 PM   #24
TheRealSy90
Four Lug Swap
Awesome numbers, can't wait to install my greddy 20g kit.
Old 01-29-2015, 01:10 PM   #25
Tom N
Power fc d jetro
22.4 psi
Nice job. E85 makes such a difference. You must be just about maxing those 1000's out at that power. Time for 1300's and 30psi.
Old 10-27-2016, 09:36 AM   #26
TheRealSy90
Four Lug Swap
Has anybody ever ran a Greddy TD06 20g 8cm on the stock manifold with t2 turbine housing? Thinking of doing this to go back to a stock manifold setup. I hear a rumor that the 20g on a t2 turbine housing would restrict it's capability by about 50hp but idk about that since the stock manifold is proven to support 400+hp, which is the upper limit of a 20g.
Old 10-27-2016, 11:39 AM   #27
RB25GUY
RB25GUY's Avatar
RB25GUY is a jewel in the roughRB25GUY is a jewel in the roughRB25GUY is a jewel in the roughRB25GUY is a jewel in the roughRB25GUY is a jewel in the roughRB25GUY is a jewel in the roughRB25GUY is a jewel in the roughRB25GUY is a jewel in the rough
well there was a guy on here with a fully built KA and a greddy 20g 8cm t3 made 400whp on e85 and 26 psi
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 10-27-2016, 12:50 PM   #28
Tom N
Made 520hp with a T2 20g on 22psi with E30 and alcohol injection.
Old 10-27-2016, 01:37 PM   #29
s13silvia123
made 380hp 18psi on 93 on a Greddy 18g 8cm T2 with custom 38mm external gate megan manifold for a fact i know it should make more on E85
scraped the idea and went twin scroll GTX 3076R after oil seals on 18g went out.
i still have the kit just laying until i rebuild the turbo.
Old 10-27-2016, 01:58 PM   #30
TheRealSy90
Four Lug Swap
Okay cool. So since I don't even want over 400hp it's definitely capable with the T2 housing. Now i'll have a greddy 3 bolt, t3, and t2 housing for the same turbo haha.
