Old 05-10-2009, 02:32 AM   #1
hpipro4
hpipro4's Avatar
Trader Rating: (71)
hpipro4 is an unknown quantity at this point
Feedback Score: 71 reviews
s13 s13 wire tuck+fuse & relay boxes re-location
anyone done it? im currently doing this and somewhat stuck where to mount my fuse panels & relays!!! any other ideas would be great....
my ideas:
passenger floor beneath glove box
inside glove box
behind the deck but too little room
heres some pics:
heres where i re-located my ignition coil
engine harness is done!
battery plate is a bitch to get out!
hpipro4 is offline   Reply With Quote
Old 05-10-2009, 03:09 AM   #2
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
relocating the fuse boxes and battery make the engine bay look a hell of a lot cleaner, heres a pic of mine
just relocate everything under the passanger side dash behind the glovebox.
redsx13 is offline   Reply With Quote
Old 05-10-2009, 08:51 AM   #3
jr_ss
Trader Rating: (33)
jr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the rough
Feedback Score: 33 reviews
Next time do alittle searching.... There's a post dedicated strictly to this topic...
And why didn't you just upgrade to an S14 distributor? That would've done away with the external coil and made your setup that much easier/cleaner.
My SR20VET
Old 05-10-2009, 09:01 AM   #4
screaminfast
screaminfast's Avatar
screaminfast is an unknown quantity at this point
Send a message via AIM to screaminfast
that looks good! do you have to extend the wiring harnesses for that?
screaminfast is offline   Reply With Quote
Old 05-10-2009, 12:34 PM   #5
hpipro4
hpipro4's Avatar
Trader Rating: (71)
woops!
never thought about the s14 distributor! what would i need?
thnx
Old 05-10-2009, 12:35 PM   #6
hpipro4
hpipro4's Avatar
Trader Rating: (71)
engine harness you dont but relocating the fuse/relay boxes some wires i will have to.
Old 05-10-2009, 12:57 PM   #7
dondochaka
Banned from the Marketplace
dondochaka is an unknown quantity at this point
i tried hiding the fuseboxes and failed miserably.
i bought a entire enginebay harness + fuseboxes because of this.
i don't see where you can relocate the boxes to.. if you take the entire harness from the SMJ to the fusebox, it's literally 5-6ft long.
even if you cut and solder all those connections.. it's still gonna be pretty damn long.
then there's wires that split off into two different sections and crap.. it's just really annoying to do the boxes.
you should just put them under the battery tray and waterproof it or something.
that'd be a good location to relocate the fusebox and for the relay box, do it the same on the drivers side.
dondochaka is offline   Reply With Quote
Old 05-10-2009, 08:04 PM   #8
redsx13
redsx13's Avatar
im pretty sure upgrading to a s14 CAS requires a s14 ecu, its not really worth the money.
Old 05-10-2009, 09:35 PM   #9
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
he was talking to the OP with the KA.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 05-10-2009, 09:37 PM   #10
littledevil661
littledevil661 is an unknown quantity at this point
Send a message via AIM to littledevil661
im doing the same to my car once i get some money and time..
Need parts or your car sprayed, PM me for Details
littledevil661 is offline   Reply With Quote
Old 05-10-2009, 11:25 PM   #11
hpipro4
hpipro4's Avatar
Trader Rating: (71)
that too and im not gonna keep the ka will swap to sr someday....just did my tuck for the heck of it..lol
Old 05-10-2009, 11:33 PM   #12
hpipro4
hpipro4's Avatar
Trader Rating: (71)
heres some update...
Old 05-10-2009, 11:49 PM   #13
redsx13
redsx13's Avatar
lookin good, what is the purpose of this car? track, show, street?
Old 05-10-2009, 11:51 PM   #14
redsx13
redsx13's Avatar
and btw, you seem like your pretty far along, but it helps to pull the whole harness to wrap the wires, i wouldn't tr to do it while the harness is still installed.
Old 05-10-2009, 11:55 PM   #15
Om1kron
Om1kron's Avatar
Om1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant futureOm1kron has a brilliant future
There is?
mine is for s14 fusebox relocation... not s13... S13 has MULTIPLE fuse boxes scattered throughout the chassis.
Buy my car : http://zilvia.net/f/showthread.php?t=620537
Old 05-10-2009, 11:59 PM   #16
whyrun?
whyrun? is an unknown quantity at this point
cool to see this. tried it on mine and failed badly.
whyrun? is offline   Reply With Quote
Old 05-11-2009, 12:32 AM   #17
redsx13
redsx13's Avatar
i thought i screwed mine up, but it ended up being something non wire related. I did my SR swap at the same time i did the tuck, and it turns out my motor was all messed up, bad sensors all over the place.
you can be the best technician in the world, but it will always be a little scary starting the car for the first time after somthing like this.
Old 05-11-2009, 12:49 AM   #18
hpipro4
hpipro4's Avatar
Trader Rating: (71)
woops..forgot about the multi quote!
Old 05-11-2009, 12:56 AM   #19
hpipro4
hpipro4's Avatar
Trader Rating: (71)
i did for the engine harness and wires going outside but decided not to sleeve the wires inside cause im lazy...lol
Originally Posted by Om1kron View Post
There is?
been following your blog and skim thru out ur s14 fusebox relocation thread!
oh yea you bet hope mine will fire right up! cross fingers...
oh and this was my daily driver and will be my daily driver!
Old 05-11-2009, 01:25 AM   #20
Jdotsturn
Jdotsturn's Avatar
Jdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond repute
Send a message via AIM to Jdotsturn
Yea i just put my fuse box in my glove box. I messed up somewhere though cuz everything works but my tail lights... kinda bummed but i never drive on the streets nor at night so I havent fixed it yet.
Jdotsturn is offline   Reply With Quote
Old 05-11-2009, 08:47 AM   #21
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
I admire your determination!
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 05-12-2009, 12:27 AM   #22
hpipro4
hpipro4's Avatar
Trader Rating: (71)
heres the fuse panels im going to use!
Old 05-12-2009, 02:13 AM   #23
Om1kron
Om1kron's Avatar
quite interesting with the fusebox setup, but again everything on the s13 seems different. But why the 80amp fuse bridge between the two boxes?
Old 05-12-2009, 03:07 AM   #24
redsx13
redsx13's Avatar
is that all you plan on using? how are you going to narrow it down to just 12 fuses?
Old 05-12-2009, 03:51 AM   #25
GSXRJJordan
GSXRJJordan's Avatar
Lol I chuckle at these threads, because most of them crash and burn. HPIPro's legit though.
When I do standalone wiring, I start with the systems I want, and work backwards - towards the fuse box, to the battery. I used a bunch of OEM wire when I did my S14, but pulled absolutely everything out first, and just put back in what I needed - much easier to check your work this way, and you get to use all the OEM connectors if you're smart.
I'll be doing a standalone harness Thursday for Ernie @ DTC ("Pinky" build), I'll try and take some pics.
12 Fuses is PLENTY, btw.
Old 05-12-2009, 01:09 PM   #26
hpipro4
hpipro4's Avatar
Trader Rating: (71)
the 80amp fuse simulate the 75amp fusible link between the wire going to alternator and starter. im basiclly copying the oem wiring harness cept i will be using monster cable power wires. im using 80amp cause i cant find any 75amp anl mini fuse!
im not changing the inside fusebox just the one found under the hood!
haha thanks hope everything goes well with my build!
Old 05-12-2009, 01:35 PM   #27
hpipro4
hpipro4's Avatar
Trader Rating: (71)
will be installing all this too.....
greddy mss
s13 digital cluster for the heck of it...
last but not least dcc
Old 05-12-2009, 01:37 PM   #28
hpipro4
hpipro4's Avatar
Trader Rating: (71)
since i took out the dash, decided to clean the a/c & heater/blower motor assembly....replacing all the worn out foam sealings
if anyone wondering what i use to replace the foam seals
i use this got it from findtape.com
Old 05-22-2009, 12:35 AM   #29
hpipro4
hpipro4's Avatar
Trader Rating: (71)
heres some update.....cleaned all the a/c & heater stuff n got them all back!
Old 05-22-2009, 01:42 AM   #30
jserman
jserman's Avatar
jserman is an unknown quantity at this point
i did a mild tuck on my 89 s13 when i put the motor back in.. since I have the Silvia front end i had lots of extra room so we relocated the driver side fuse box under the front fender and the passenger side one we tucked up in the corner i will get some pics up for yea tomorrow
jserman is offline   Reply With Quote
