Old 03-19-2003, 03:42 PM   #1
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
[turbo] running coolant lines...
Ok, just want to hear some advices.... I'm planning on tapping the throttle body line and run the coolant line from there to the turbo, and then return it to the upper radiator hose... anyone has a better path in mind? Thanx
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 03-19-2003, 07:08 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
how about from the TB to the turbo back to the TB's coolant return line??
or.... get a turbo timer and save your coolant system the extra stress
AceInHole is offline   Reply With Quote
Old 03-19-2003, 07:11 PM   #3
Kreator
Kreator's Avatar
Yeah, i was thinking about it for a while... then i found out that the sr uses water cooling and is fine... and plus i thought if i just splice it somewhere, and return right bfore the radiator, it shouldn't be affecting anything much....
As for returning back to tb line.... if you are talking parallel... i was just thinking, if both lines have same psi, wouldn't the water/coolant just stall and not move through the turbo?
Old 03-21-2003, 06:16 PM   #4
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
Typically there are connections for water lines for a turbo engine. It is a matter of getting the correct lines for it or making your own with steel braid and 'AN fittings'. Both the feed and return lines come from the engine block/ head area on the exhaust side of the engine.
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 03-21-2003, 07:07 PM   #5
Kreator
Kreator's Avatar
uhhh, 1 thing though... it's not a turbo engine to start with ..... so i think i'll stick with the TB.... except could someone with and FSM or something tell me which of the lines is the one leaving the TB? Also. is the TB the last link in the coolant's path before it hits the thermo?
(I'm thinking of doing it inline <- since i'm runnign low psi)
Old 03-21-2003, 07:11 PM   #6
N1ceDrgn
N1ceDrgn's Avatar
That would change things... Sorry, I'm not sure what lines you would use for in n' out lines for the coolant. An FSM would be your best bet then, sorry I couldn't be of more help.
Old 03-21-2003, 10:42 PM   #7
240racer
240racer's Avatar
240racer is an unknown quantity at this point
there is a U-shaped rubber hose right below the throttle body. I replaced that hose with two hoses going out to the turbo and back. It doesn't matter which way the coolant flows, it just goes out to the center section and back anyway. I didn't have any problems with the setup last year.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 03-23-2003, 08:25 AM   #8
Kreator
Kreator's Avatar
Thanx a lot.
240Racer, you're talking about the one on the left righ? This is where i originally started messing with. I'm now done with setuping the coolant lines (well almost... just need to wait for my plumbing stuff to get here).
Old 03-23-2003, 10:18 AM   #9
drifties151
drifties151's Avatar
drifties151 is an unknown quantity at this point
Send a message via AIM to drifties151
i have a water cooled t3 turbo off a saab. im putting a kit together to go on a Ka24de. can i weld up the coolant holes on the turbo and be OK? or do i absolutely have to run coolant lines? I saw that ace had said something about a turbo timer?
drifties151 is offline   Reply With Quote
Old 03-23-2003, 01:49 PM   #10
Kreator
Kreator's Avatar
Yeah, you can do that. Basicly 2 things you are trading between are:
with water lines: Cooler turbo, but generally hotter coolant (*might want* a better radiator or fan)
w/o water lines: Hotter turbo <- should get exhaust wrap and cover everything around to protect from the heat.
Another thing, with the water lines, you turbo needs less time before you turn of the engine, but it still needs some of it.
Old 03-24-2003, 12:15 AM   #11
240racer
240racer's Avatar
I think it is 3/8" diameter or so. one end of the tube is left and below the throttle body and the other is kinda back under the intake, pretty hard to get at.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
