Old 03-18-2003, 12:31 PM   #1
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
Car wobbles at high speed
I have balanced the tires, and the tech told me that when he spins the wheels on the machine that he would be able to tell if they were bent. I hit a huge pothole and ever since the car has been wobbling at about 70mph+ (as if driving in wind). I have gotten the wheels balanced and the problem is still not fixed....all I can think of is that maybe one of my bearings are bad; would this be able to cause a wobbling effect and how can I check for bad bearings up front?
rancid240 is offline   Reply With Quote
Old 03-18-2003, 12:37 PM   #2
Dousan_PG
Dousan_PG's Avatar
you tires might have a bald spot!
checking bearings. grab wheel firmly when its on car (on the ground) pull left and right hard a few times, any play in the bearings? also bearings youll notice at ALL speeds.
i think its bald spot if they checked the wheel already and no bends.
Aaron
Pink GodziRa
Old 03-18-2003, 12:50 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
or you busted a TC rod bushing.
sykikchimp is offline   Reply With Quote
Old 03-18-2003, 02:03 PM   #4
rancid240
Trader Rating: (72)
how do i check for a busted bushing? Will i see the "ooze" dripping off one of the rod ends?
Old 03-18-2003, 02:11 PM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
yeah. the bushing will have visable cracks, and there will probably be a good bit f nasty looking ooze...
Old 03-18-2003, 02:17 PM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
Old 03-18-2003, 02:25 PM   #7
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
mrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfectionmrmephistopheles is close to perfection
Actually, you check bearing play by pulling/pushing at the top & bottom of the wheel. Doing the left/right deal will only produce wobble from the steering components. It won't be much, but if it moves at all, your bearings are worn. You should also hear a noise associated with the bearings being worn, but it may not be prevalent until they are more severely worn.
-Kevin
Old 03-18-2003, 02:42 PM   #8
AKADriver
AKADriver's Avatar
AKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura about
Definitely sounds like a TC rod bushing...
...because that's the way my car always drives hahaha
2000 Miata
When changing your brake fluid, remember to dispose of any excess fluid properly. It might be inconvenient, but there's no excuse for not drinking it all.
Old 03-18-2003, 03:37 PM   #9
RomperStomper
RomperStomper is an unknown quantity at this point
it is probably the TC rod bushing but i had the same problem and it ended up being a combo of thrashed tires and warped rotors.
RomperStomper is offline   Reply With Quote
