Old 02-07-2009, 11:59 AM   #1
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
Shifter bushing - anyone use this?
Mods, I know this is an ebay link but I'm not at all affiliated with the seller; just curious about the product.
eBay Motors: CUSCO S13 S14 Collar - Shifter Lever NISMO NISSAN (item 120358497943 end time Feb-02-09 14:06:46 PST)
Metal (looks like copper) shifter bushing. I'm wondering if it would fit a B&M shifter, how it feels, and whether it would increase wear on anything. Also wondering if it's removable once it's installed, if you wanted to move it to another shift lever.
TIA.
E36 M3 - new project
1990 240SR - screamed down the road
Rittmeister is offline   Reply With Quote
Old 02-07-2009, 12:11 PM   #2
projectRDM
projectRDM's Avatar
Works fine. Tanabe makes an aluminum one, same effect. You're basically reducing the play and possible wear of the plastic bushing. Fits all shifters but since it's metal it doesn't 'snap' on, it just sits in the lever and the shifter fits into it.
FORMERLY R240NA
Old 02-07-2009, 12:17 PM   #3
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Hmm.. I've never seen this thing. Interesting I've meaning to fix my shifter play. RDM so say I get this would it be good to get the bushing to replace my old one or just use this one??
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 02-07-2009, 12:36 PM   #4
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
What most people don't realize is the slop isn't always caused by that bushing. It is the springs in the transmission that wear out the most. Move your shifter while in neutral to the left, and then to the right. Going to the right is tight.. Left is loose.. the springs need replacement. Buy a $2 bushing from nissan that will sit tight just like your stock one still does, and purchase the HKS shifter spring kit. Or replace shift springs with OEM springs for dirt.
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 02-07-2009, 01:08 PM   #5
BustedS13
BustedS13's Avatar
-Bart
care to elaborate or point to a FAQ? that doesn't sound particularly easy
Old 02-07-2009, 03:00 PM   #6
Def
There are two plugs on each side of the transmission around the shifter area. Just unbolt them and change the springs out. Isn't hard.
Old 02-07-2009, 03:19 PM   #7
MrChow
MrChow's Avatar
From Frsport user install for HKS return spring kit.
Old 02-07-2009, 03:35 PM   #8
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
You can also double up on the OEM springs to make it stiffer, or perhaps pull one spring out, take it to a hobby shop that sells RC car parts, and find an RC car spring of similar size that is stiffer.
Easy shit.
-Kyle
Old 02-07-2009, 05:02 PM   #9
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
How long are the springs? Doesnt look too long and i assume you can replace the springs while tranny is still on car?
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 02-07-2009, 05:09 PM   #10
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
I have the Cusco bushing too.
Works fine.
http://bhworld.wordpress.com/
Old 02-07-2009, 05:25 PM   #11
soreballz
soreballz's Avatar
Trader Rating: (22)
Not sure exactly how long they are, but yes, you can replace them with the tranny mounted on the car.
-Kyle
Old 02-07-2009, 06:21 PM   #12
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
-Bart
Really? I have a B&M shifter with a shifter collar and it has almost no play. It feels sex. Although mine's made of delrin, it's the same sort of stuff. When I first installed my B&M, to me, it felt like the same as stock except shorter throws. When I put in my collar, it felt as tight as everybody said..
Propaganda is offline   Reply With Quote
Old 02-07-2009, 09:06 PM   #13
projectRDM
projectRDM's Avatar
There's only one bushing. Either you replace with the OE plastic or use an aftermarket metal one.
FORMERLY R240NA
Old 02-07-2009, 09:26 PM   #14
Propaganda
Propaganda's Avatar
Actually, there are two.. the shifter collar and the one I have in mine circled in red
The stock one is a flimsy paper-thin circle of metal. The one I have is 2mm thick. Although if you have a B&M shifter, it eliminates this part
Old 02-07-2009, 09:47 PM   #15
racepar1
racepar1's Avatar
Trader Rating: (103)
Feedback Score: 103 reviews
That's NOT a bushing, that's a spring washer to hold tension on the upper pivot bushing. Oftentimes that can also cause slop in the shifter if it is worn/missing.
Old 02-08-2009, 08:03 AM   #16
Propaganda
Propaganda's Avatar
Well.. whatever it is, it causes slop. Thanks for the headsup!
Old 01-27-2013, 11:04 PM   #17
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Any information on how to replace the oem shifter bushing? does the n w one just snap on or are there any tricks to this?
Ilya is offline   Reply With Quote
