Old 02-03-2009, 03:18 PM   #1
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
When a brake pad job goes bad... help please!
This part is frozen on my 240's rear brakes. I dont know what its called, or where I can get a new one (or if I can fix this one). Not trying to buy a whole new caliper if i can avoid it. Any advice would be GREATLY appreciated! I'm doing these brakes outside, and its snowing!
sirfallsalot243 is offline   Reply With Quote
Old 02-03-2009, 03:24 PM   #2
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Not sure exactly what you mean by "frozen", but... Pull the pins out and grease them. It'll help if you mean what I think you mean.
-Kyle
Old 02-03-2009, 03:43 PM   #3
sirfallsalot243
The pins are frozen in there. I can barely spin them with a box end wrench, much less remove them. Not sure how I should go about trying to free them... I have an acetylene torch and a Mapp torch... not sure if heating them would be the way to go though.
Old 02-03-2009, 03:48 PM   #4
noname7198
noname7198's Avatar
noname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to behold
Try putting the bracket in a vice and spray some PB blaster around the pins. Use vice grips on the pins to twist/pull them out. Grease them up and put them back in.
noname7198 is offline   Reply With Quote
Old 02-03-2009, 03:49 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (103)
Feedback Score: 103 reviews
Don't heat it. Use a pair of vise grips and a hammer to knock it out. Make sure you rotate it when it moves just to keep it from freezing even worse. There is a rubber grommet on one of the pins and if you heat it it may melt the rubber. Use some WD40 to lube it when you are removing it too. After it is out use a wire bottle brush and some wd40 to scrub inside the bore. Then use a wire brush and some more WD40 to scrub the pin. Clean it all up with some brake cleaner and use white lithium grease to lube it all back up. If one is frozen you should do this to the pins on at least the rear calipers and check the fronts too. You CANNOT buy the caliper bracket separate from the caliper.
Old 02-03-2009, 03:49 PM   #6
sirfallsalot243
Will do, thanks! I tried doing this with WD40, but Ive been thinking PB would do the trick. I cant seem to find mine... might just have to go buy some.
Old 02-03-2009, 03:54 PM   #7
Phlip
Custom administrator user text
Phlip's Avatar
PB would work better than WD...
I had the same problem in May on my fronts.. I wound up taking it to a machine shop and giving him 10 bucks to get it out, and replaced all the pins.
Originally Posted by Ignignokt
"Getting it is easy... filling it with illegal substances and sending it across the border is not."
And I blog too!
Old 02-03-2009, 05:05 PM   #8
sirfallsalot243
Got em out! Vise grip and PB method did the trick! Thanks a lot guys!!
Old 02-04-2009, 02:52 AM   #9
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
I was gonna say some penitrating oil would do the job lol, but you got em out
Ceepo is offline   Reply With Quote
Old 02-04-2009, 03:00 AM   #10
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
nice sig ceepo
97 240sx se
0wn3r is offline   Reply With Quote
Old 02-04-2009, 04:04 AM   #11
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
I had the same problem with one of my rears. The pin wouldn't come out even when placed in a vice. I just tried to source another one on the auctions. best of luck
MisawaJason is offline   Reply With Quote
