Old 01-31-2009, 12:31 AM   #1
AngryPanda
AngryPanda is an unknown quantity at this point
Fiberglass bumper repair
This is a method we use to repair fiberglass bumper.
Finish product
First The fiberglass bumper repair
Items needed
Fiberglass resin (you can buy a repair kit with all the necessary stuff at autozone, kragen ect.)
Sandpaper ( various grits and types read on to find out what)
Various fillers ( Just "bondo" will do but i recommend using stronger stuff if the repair is to last)
tools ( grinder, sanding blocks 6" 18" ect, brushes)
Safety equipment ( gloves, eye protection, dust mask)
BABY POWDER!!!! ( if you ever worked with fiberglass this is a life savor)
this bumper had a Van back into it. Some bumpers are not worth fixing, this one being pretty high priced, it was worth the effort to fix.
First thing is always clean the part off, soap and water then a degreaser, acetone or some type of cleaner, I like autoprep.
Next step is to get the bumper back close to its original shape as possible.
Use tape, vice grips, ect to secure it in place.
This step can be done by hand but I just like using a 90 degree grinder.
Sand all edges flat with each other as possible, Ie get rid off the the frayed edges, use a 40 grit sand paper or below, just get rid of the edges don't worry about the cracks yet.
the next step involves using a fiberglass mat like the one above. The mat is used to reinforce the back of the repair area. Tear off pieces 4"x4" in size, enough to cover the repair area with a 50% overlap in two to three layers.
next lay down the first row of matt fiberglass like so in the bumper, it is very important that there is enough overlap between the pieces to form a solid bond, 25-50% of the individual pieces should over lap each other.
mix a small amount of resin according to your resin brand instructions, only enough to wet out the first layer. For the area shown in the picture, it took about 12 oz of resin. mix about 6 oz of resin and poured it over the fiberglass.
Then using a stiff bristled brush spread out the resin using a jabbing motion. don't worry about getting all the air bubbles out just yet.
Next mix the remaining resin now dip the brush in to the resin and use a jabbing motion to completely wet out the fiberglass, it should look like this when done
Let it set up for about 5-10 mins depending on amount of hardener used. Most fiberglass resin uses a chemical reaction that creates heat. If the fiberglass is built up too fast the heat might warp the bumper of become brittle upon full cure.
After the 5-10 mins are up repeat to add the second layer of fiberglass.
Let the fiberglass completely cure. I like to let it sit over night.
the cured fiberglass
Next flip the bumper over and sand all the broken fiberglass making sure there is no looses pieces left, exposing the fresh layer of mat.
Again use 40 grit or lower sand paper.
This next step is where the material choice comes in. I am using a Kevlar reinforced filler for my initial coats, you can use "bondo" but it wont be strong as the kevlar stuff but it will be easier to sand.
Apply a generous layer of filler to the sanded area. Remember this filler is whats shaping the front of the bumper. Make sure there is enough filler to cover the low spots.
Next shape the filler down to the bumpers original shape.
I used a DA for this step,
but if you don't have access to one hand sanding useing a 6" block and a 18" block will do, again 40 grit or less sand paper.
Finish with the initial sanding
for the final coat of filler I used a high grade plastic filler
Put enough filler on to fill in all the low spots that got missed the first time and sand to shape.
start with a 40 grits then work your self up 80 then finish with 150.
After the final sanding clean the bumper off with some air and post sanding cleaner.
Primer with your choice of primer, I used PCL polyprimer
Have fun.
We do "Awesome"
AngryPanda is offline   Reply With Quote
Old 01-31-2009, 09:54 AM   #2
used240sxparts
Lots-O-Parts
Trader Rating: (34)
used240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond reputeused240sxparts has a reputation beyond repute
Feedback Score: 34 reviews
Send a message via AIM to used240sxparts
wow great write up for someone that doesn't know a thing about fiberglass!:woot:
used240sxparts is offline   Reply With Quote
Old 01-31-2009, 10:12 AM   #3
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
I just got done repairing my rear bumper. It was a trial and error ordeal. Actually turned out not half bad. I followed pretty much the exact same steps that you posted except I used the interlaced matting instead of the fiberglass strands.
MisawaJason is offline   Reply With Quote
Old 01-31-2009, 01:02 PM   #4
fliprayzin240sx
No S14 4 the 1st time in 14yrs
fliprayzin240sx's Avatar
Wow...I dont miss doing that shit once a fucking month on my kouki S14 bumper...
CLICK HERE!!!
Old 01-31-2009, 01:06 PM   #5
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
this write up is AWESOME!
makes me want to try... and i am gonna try soon... i sent you a pm regarding something
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 02-01-2009, 09:38 AM   #6
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (391)
Feedback Score: 391 reviews
Makes me want to buy a messed up bumper just to give it a shot.
Haha.
-Jspec-
Instagram/CrimsonRockett
Old 02-01-2009, 09:45 AM   #7
SleepySR
SleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the roughSleepySR is a jewel in the rough
a little tip dealing with fiberglass, wash up with shaving cream it helps get rid of the itching lather up first no water then rinse with cool water
http://farm4.static.flickr.com/3509/3279342840_de50549412_m.jpg
SleepySR is offline   Reply With Quote
Old 02-01-2009, 10:39 AM   #8
kalypso123
(ノಠ益ಠ)ノ彡
thats dedication
Old 02-01-2009, 03:55 PM   #9
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
Great write up.
I've been doing it that way on all the parts I have fixed.
I'm glad I've been doing it the right way lol
Haha.
Do it!
I just got this bumper for $15
Should cost me like $30 in supplies to fix.
MrMcgarrett is online now   Reply With Quote
Old 10-28-2012, 04:00 PM   #10
240Cali
240Cali's Avatar
240Cali is an unknown quantity at this point
i was almost gonna throw away a bumper lol this makes me wanna try it ne1 in LA/OC wanna give me a hand? lol
240Cali is offline   Reply With Quote
Old 01-12-2014, 01:26 PM   #11
Jrbar89
Jrbar89's Avatar
Jrbar89 is an unknown quantity at this point
wish i found this earlier i tried to fix my bumper came out like poop. Now i know how to do it the correct way i can give my passenger fender a shot.
Jrbar89 is offline   Reply With Quote
