Home | Store | Rules & Guidelines | Register | Member Rides | FAQ | Members List | Social Groups | Calendar | Mark Forums Read |
Common problems on the 240sx?
about to buy a 240sx and my mechanic wont be able to come with me to do the check, so im doing it myself. what things do i have to check for normal things and what are the most common problems on the 240sx. using the search button i found that common things are the timing chain and rust buildup on the rear end wheel and strut towers? let me know as i plan to buy it in 2 days thanks
Zilvia.net GB Vendor
![]() Join Date: Oct 2006
Trader Rating: (52)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 52 reviews
sd as in South Dakota or San Diego? San Diego shouldnt be very rusty, just oxidized from the sea salt...
WWW.JIMMYUP.COM |
#6 |
its a small thing... reverse lights are always busted.
either it be a short or a blown fuse. my reverse dont work, my brothers don't work, not even my buddies work lol.
#8 |
![]() Join Date: Dec 2007
Trader Rating: (226)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 226 reviews
-Check if there any major leak (ask the seller!!!)
-Check power steering line see if there any leak because old car has that problem -Make SURE is straight classis -Check the idl -TEST drive it before you buy it !!! |
#9 |
This really depends on what you are buying.
Is it modified? Stock? If it is stock... get a carfax. Check the vin and see how many accidents. If you cant get a carfax, things to look for. Check the radiator support. Near the ends where it meets the fender, how's the fitment? Does it align perfectly? If it looks like it's tweaked, check the fender tubs. See if it looks crimped. See around the headlights, see if there's any crimple marks. Check the body lines, see if they all match up and are straight. Are the gaps between doors, hood, bumper, fender? Check the trunk, lift up the carpet. Look near the spare tire well, and check to see if it looks straight. If there was an accident, u can see if the floor looks crimpled, bondo, new sealant has been laid down. You can look under the rear bumper too (not on S13 cuz the gastank). Simplest way to check for accident is checking the body lines. If the frame is fucked, you will see it when the body panels are not aligned properly. Fuck the mechanical shit, just rebuild or swap a new motor. lol |
#11 |
IACV maybe...I see alot more engines having this problem nowadays....
Also, bad window seals always annoys me on S14's. I know its not mechanical, but it can be a pain to repair
dmax-us.com |
#12 |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
power-steering leaks are common, mainly because people use power-steering fluid when the FSM calls for ATF fluid.
ask when parts have been changed, spark plugs, spark plug wires, distributor cap, distributor rotor, fluids ( engine oil, tranny fluid, and differential gear oil. ) listen to it run, should sound smooth, timing chain rattles are common, but you can use it to talk the owner down. get underneath the car check the crossmembers make sure they are straight and dent free, check out the suspension arms make sure everything look straight. look in the trunk and battery tray for rust.. check for torn power-steering boots.. see what the exhaust is outputting color, a lot of smoke? what does it smell like? you should post a thread under your area, and see if any experienced 240 owner is willing to check out the car with you. ask the owner questions just to see if he knows what he's talking about... in general check the car out.. take pictures, and post them up here..
#13 |
![]() Join Date: Dec 2003
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
I'm always really concerned about the chassis its self. Like most have said above, the bolt on stuff can be fixed later but chassis problems, or poorly repaired damage, can be a costly fix and a source of many headaches.
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
#18 |
![]() Feedback Score: 8 reviews
water pumps and thermostats usually need replacing. Not hard to do yourself. Make sure you drive it on the freeway or at least freeway speeds, making sure the clutch doesnt slip. Check if it drives straight. If it pulls to one side, could mean previous accident.
#20 |
![]() Join Date: Jan 2004
There has been too much violence, too much pain.
None here are without sin. But I have an honorable compromise. Just walk away. Give me the pump the oil the gasoline and the whole compound, and I'll spare your lives.
#24 |
#25 |
AFC #1
![]() Join Date: Oct 2003
Yeah, like ones that drink to many OTC medications and forget that they asked the same question before under a different screen name. Over and over again...
Troll's got to have a good name yo!
