Old 10-27-2008, 07:26 PM   #1
gippy87
gippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-known
Best way to clean head gasket residue off the block?
Im replacing the head gasket on my sr tommorrow. If the block is straight, what will be the best method to removing the old gasket residue other then resurfacing.
This is what it looked like after a razor blade
You can see it was still very dirty.
gippy87 is offline   Reply With Quote
Old 10-27-2008, 07:34 PM   #2
jr_ss
Trader Rating: (33)
jr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the rough
Feedback Score: 33 reviews
Acetone or laquer thinner should take most of it off... You can also use a very fine steel wool or sand paper, 1000 grit or higher..
My SR20VET
Old 10-27-2008, 08:14 PM   #3
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
I was going to use liquor and sand paper. Tell me how it goes, I plan to do the same thing soon.
moses is offline   Reply With Quote
Old 10-27-2008, 08:16 PM   #4
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
I've used a green scothbright pad on that area, the area where the upper oil pan bolts, and the front of the block also w/ good results.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 10-27-2008, 08:26 PM   #5
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
you can pick up gasket remover from advance auto parts, that works really well if you use a green scuff pad with it
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 10-27-2008, 08:31 PM   #6
Sileighty_85
Sileighty_85's Avatar
Yeah Razor blade, carb cleaner and a brillow pad
Id refrain from using Sand paper or steel wool Metal shavings or sand in your oil system = Bad Ju Ju
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-27-2008, 08:38 PM   #7
silpena
silpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to beholdsilpena is a splendid one to behold
yeah that steel wool can leave fine hair in there. When we use it to clean windows after a cars been painted we never wash the car we allways blow em off with air to avoid scratching the paint..anyways i would use a gasket scraper and some gasket remover to get it off clean.
silpena is offline   Reply With Quote
Old 10-27-2008, 08:51 PM   #8
moses
looks like ill be using a scuff pad and gasket remover
Old 10-27-2008, 09:15 PM   #9
silpena
be carefull with the scuff pad. Put some lint free towls or paper on top the pistons and walls to avoid getting fine dirt or hairs from the scuffing pad.
Old 10-27-2008, 09:34 PM   #10
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
aircraft paint remover ftw
smurfgcr is offline   Reply With Quote
Old 10-27-2008, 11:28 PM   #11
steve shadows
steve shadows's Avatar
high girt sand paper, steady hands and permatex gasket remover, worked for me about 20 times now for metal and composite gaskets, motor blowing more than 30 psi at times
Like Me on FaceBook !
Old 10-28-2008, 01:38 AM   #12
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
I used a razor blade to get most of the paper off, sandpaper to clean it up, and brake cleaner to clean off
JRas is offline   Reply With Quote
Old 10-28-2008, 05:55 AM   #13
jr_ss
Trader Rating: (33)
I'd go with the really fine sandpaper, I forgot about steel wool, scuff pads and what not breaking apart... Haven't used them in a long time. Get 1.5k sandpaper and a sanding block to keep it level...
My SR20VET
Old 10-28-2008, 07:23 AM   #14
oneviaman
oneviaman's Avatar
oneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond repute
they make these things called bristle disks. looks like a wire wheel made out of a hard plastic. takes off the material without removing metal. i love them.
look like this
oneviaman is offline   Reply With Quote
Old 10-28-2008, 07:53 AM   #15
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is making a name for him/her selfjapslapsilvia is making a name for him/her self
i used synthetic steel wool ultra fine (like a scotch bright but not as abrasive) soaked in engine oil worked out pretty good, and leaves a very shinny sruface. then i cleaned out the oil residue with brake cleaner.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 10-28-2008, 08:01 AM   #16
smelly240
smelly240's Avatar
nylon bristle rol-loc for winnage... use them all th etime.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 10-28-2008, 05:23 PM   #17
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
a 4" angle grinder with a metal cutting disc, the biggest hammar you can find along with the most gnarly flat head punch you have...then go ballistic...lol jk i usually use a razor blade, verrrrrry lightly(you can shave aluminum easier than most people think) then sometimes very lightly with a scuff pad and brake/carb clean
mxsx25 is offline   Reply With Quote
Old 10-28-2008, 09:51 PM   #18
jquest
jquest is an unknown quantity at this point
what oneviaman suggested is what you would usually use in a mech shop. just make sure you get the right one. i can't quite remember but i think the yellow one is for alum. and the blue one is for steel or cast iron. or other way around. use the steel one on alum. and u will start removing material that you want to keep. and i usaully spray brake cleaner on first and then hit it with the brush. the gasket remover does burn the flesh. so i don't use it if i can help it. dude that stuff hurts. stay away from the cutting disc muahahahaha
john
jquest is offline   Reply With Quote
Old 10-28-2008, 10:11 PM   #19
gippy87
seems like alot of different answers now i have to choose.. hmmm.
Old 10-28-2008, 10:18 PM   #20
Fries
Fries's Avatar
Why not call your local machine shop if you're really worried. Any of the answers in this thread will work though. Just do what you feel most comfortable with.
Old 10-28-2008, 10:21 PM   #21
nissanpwnsvtec
nissanpwnsvtec's Avatar
nissanpwnsvtec is an unknown quantity at this point
Send a message via AIM to nissanpwnsvtec
just go for what seems easiest to get your hands on
wait for the ricer flyby, then gun it.
nissanpwnsvtec is offline   Reply With Quote
Old 10-28-2008, 10:24 PM   #22
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
[QUOTE=mxsx25;2414951]a 4" angle grinder with a metal cutting disc, the biggest hammar you can find along with the most gnarly flat head punch you have...then go ballistic.../QUOTE]
This is probably the best way to do it
n240sxfnatic is offline   Reply With Quote
Old 10-29-2008, 06:35 PM   #23
gippy87
i went with the angle grinder method since a couple people seemed to agree it was the best way. it wasnt exactly the finish i was looking for i hope it didnt shave to much off the block...
lol jk
Old 10-29-2008, 06:45 PM   #24
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
use an ice scraper
It's what everyone at my dealership uses and it's what my instructor's making us use
initial_drifter is offline   Reply With Quote
Old 10-30-2008, 10:32 AM   #25
jim1234664
jim1234664's Avatar
jim1234664 is an unknown quantity at this point
Originally Posted by initial_drifter View Post
use an ice scraper
yeah use this and a solvent, 0 chance of scoring the block
jim1234664 is offline   Reply With Quote
Old 10-30-2008, 12:58 PM   #26
CrazyKoukiS14
CrazyKoukiS14 is an unknown quantity at this point
Send a message via AIM to CrazyKoukiS14
heres what i do, soak it with brake cleaner or carb cleaner, then take a razor blade and scrape it off and just repeat this cycle over and over again and once youve done that take a sheet of sandpaper 1000 grade or higher and sand for about 2 or 3 minutes
CrazyKoukiS14 is offline   Reply With Quote
Old 10-30-2008, 11:07 PM   #27
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
Just use a drill with a wire wheel on it and it will take you a few minutes. It won't remove metal either. I did it with my rebuild and I even used it to remove all the carbon build up on the pistons too.
mxexux is offline   Reply With Quote
Old 10-30-2008, 11:45 PM   #28
n240sxfnatic
Thats a bad idea, and yes, it will remove metal
Old 10-31-2008, 07:31 AM   #29
remi
remi's Avatar
remi is an unknown quantity at this point
A wire wheel brush will not damage a cast iron block. Most mechanics shops will use a die grinder with a wire wheel attached. This wont damage a cast iron block, yes it'll harm an aluminum block or other aluminum pieces but you'd have to sit there for hours and wear that wire wheel to nothing in order to hurt cast iron. And yes, I'm speaking from experience. I've been a technician for 5 years now and done my share of this type of work. A die grinder with a wire wheel attachment is by far the fastest and easiest method for removing head gasket material. Also, just as mxexux stated, you can also clean the piston tops with it as well, it won't harm them either.
remi is offline   Reply With Quote
Old 10-31-2008, 08:24 AM   #30
jmac636
jmac636's Avatar
jmac636 is an unknown quantity at this point
I build motocross race engines and what I do is razor blade the big stuff, use the RED scotch brite and some brake or carb cleaner. Scotch brite pads come in different abrasives gray-fine,red-medium and green is rough. I never use the green on anything aluminum only on steel. Hope this helps someone.
S14 Turbo LS1/t56 http://www.playloudclothing.com/
jmac636 is offline   Reply With Quote
