Old 03-03-2008, 01:07 AM   #1
e30cabrio
e30cabrio has a spectacular aura aboute30cabrio has a spectacular aura aboute30cabrio has a spectacular aura aboute30cabrio has a spectacular aura aboute30cabrio has a spectacular aura aboute30cabrio has a spectacular aura about
Drilling wheel hub/rotor to change bolt pattern?
I hope this is the correct place to post this.
As the title states, I was wondering if anyone has ever redrilled their hubs/rotors in order to change their bolt pattern before?
I have seen one or two instances of this before, but there wasn't much feedback on it, since they were very old threads on another forum.
It is basically the same idea/concept as redrilling wheels to a new bolt pattern, but instead doing it to the car.
Any insight on this method?
thanks.
e30cabrio is offline   Reply With Quote
Old 03-03-2008, 02:02 AM   #2
slider2828
slider2828's Avatar
hubs and rotors are different. You can redrill rotors at a machine shop to accomodate your hubs. Your hubs cannot be redrilled because there simply isn't enough room. If you custom a whole hub to have solid round surface then ok maybe, but it would probably be cheap to by conversion. Hubs and Rotors are different things... YOu might want to be more clear
Turn and Burn!
Old 03-03-2008, 02:10 AM   #3
DarkPhoenix
DarkPhoenix's Avatar
DarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to beholdDarkPhoenix is a splendid one to behold
Send a message via ICQ to DarkPhoenix Send a message via AIM to DarkPhoenix
I think there is someone one who did a "ghetto 5 lug conversion" using the stock 4 lug hubs. It was either here or on s-chassis.com
1990 Nissan 240SX SE FB-KA24ET in progress!
Lotsa people with sandy holes on the interwebs!!
DarkPhoenix is offline   Reply With Quote
Old 03-03-2008, 02:14 AM   #4
Matej
Matej's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
It's possible, the studs usually have to be welded in, but as long as it's done right there shouldn't be a problem with it. You could also look into bolt-on spacers that change bolt pattern. I'm thinking about getting some 4 to 5-lug 25mm spacers, that way it'll be really easy to switch between 4-lug and 5-lug wheels whenever I want.
Irony.cc
Old 03-03-2008, 02:23 AM   #5
slider2828
slider2828's Avatar
Are you serious welded? That is crazy... There is hardly enough room for 4 let alone 5. I would worry about rotational inbalance...
Turn and Burn!
Old 03-03-2008, 02:34 AM   #6
Matej
Matej's Avatar
Trader Rating: (39)
Well it's the cheap way to go 5-lug, I've heard of people doing it. The main downside is that if you break a stud, you'll most likely have to replace the entire hub.
Irony.cc
Old 03-03-2008, 02:38 AM   #7
racepar1
racepar1's Avatar
Trader Rating: (103)
Feedback Score: 103 reviews
Imbalance would be very minimal, probably absolutely un-noticeable. If you are really extra anal-retentive then you can get them balanced. If you drill the holes the right size the studs will just press in like normal, you only have to weld them if you screw up or just plain don't know what you are doing. As far as safety goes they should be 100% fine. I don't see any reason why the hub would break just from a few extra holes. Search for the DIY thread, this exact procedure is outlined in there.
Old 03-03-2008, 02:58 AM   #8
cdlong
cdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud of
Send a message via AIM to cdlong
i wouldn't say it would be 100%, the hub is thicker right around the stud. one of the studs would land completely in the thinner part, and the other two would probably be half in and half out. i'd be worried the studs would sit crooked, not have enough surface area for the knurl to grip, or possibly crack the hub. it might work, but i'd rather not find out the hard way.
cdlong is offline   Reply With Quote
Old 03-03-2008, 10:58 AM   #9
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253 Send a message via Skype™ to EJ253
4 lug hubs cost pocket change.
pick up another set of hubs. if you mess up, swap on the other 4 lug hubs.
whatever
thats what i was thinking about doing
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 03-03-2008, 12:14 PM   #10
e30cabrio
I know they are different things, and you would have to drill both technically, if you were to try and convert it over to a different bolt pattern. Can't just drill the hubs, and not the rotors, and vice versa.
Old 03-03-2008, 12:16 PM   #11
e30cabrio
Yea, the only thing is, I am trying to get my fitment closer. With the 20-25mm adapter I am using right now, it is making the wheel/tire sit out way too far for me. This is more for a "race" car, so I don't want to have to be stretching and poking so much like most guys.
That is also what I think, imbalance would be minimal. Since the rotational mass is so close to the center of the wheels, it will be almost negligible. Plus, the weight that is being removed from the hub isn't very much either.
I would also only assume that if any place can drill a wheel for a new bolt pattern, then they can drill hubs into a new bolt pattern as well.
I didn't realize there was a DIY thread, I will try to search for it.
This is something I don't understand. I noticed when people drill new bolt patterns into the wheels, they don't do it so that the holes are more equally spaced out. This could partially be due to the indents on the back of the wheel's mounting surface. However, if doing it to a hub, I wouldn't have to worry about that. So I figure I could get them to space out the bolt pattern as evenly as possible, so it looks almost like a truck's hub, with 10 holes.
thanks for the input guys.
Old 03-03-2008, 12:31 PM   #12
HyperTek
is this Jon? hit me up this is austin.. ill let u know how to do it.. i did it to my old s13.. drilled the front hubs from 4 to 5lug..
Use a drill press.. I used a 5lug rotor that i previously drilled for for lug use, i used it as a guide since it was already perfect alignment..
Keep it Classy
Old 03-03-2008, 12:31 PM   #13
Rob's S14
Rob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfection
Send a message via AIM to Rob's S14
why risk the drilling being done wrong. doing a 5 lug swap is simple and cheap. with 2 people you could do it in a couple hours, then you could get whatever spacer you need.
Rob's S14 is offline   Reply With Quote
Old 03-03-2008, 12:33 PM   #14
e30cabrio
This is Jon's account, but I am posting under his name on here. My name is Don though. If you still want to help me out though, let me know My AIM is AirborneDEN
I am not going from a honda bolt pattern to a honda bolt pattern. It is for a BMW to Honda bolt pattern.
Old 03-03-2008, 12:36 PM   #15
HyperTek
hmm ur sn sounds familur i might have talked to you about something before.. was it bbs rims? i had a 190e..
Keep it Classy
Old 03-03-2008, 12:41 PM   #16
e30cabrio
Do you live in OC? I have a BMW, so if you are bimmerforums or something, I might have talked to you. Maybe I've met you in person before? Either way, if you can help me out, that'd be great.
Let me know.
thanks.
Old 03-03-2008, 01:09 PM   #17
racepar1
racepar1's Avatar
On an s-13 a 5-lug swap is ANYTHING but cheap. The rear hubs can be bought for cheap (non-turbo z-32) but a good set of front conversion hubs costs around $400-$500. You can swap the s-14 front knuckles and hubs, but you would need to change your tie rod ends, ball joints, and front struts at well. All that would probably run you more than $500.
Old 03-03-2008, 01:20 PM   #18
Matej
Matej's Avatar
Trader Rating: (39)
In Japan some company made 9-lug hubs for the S-chassis, but I'm guessing they're hard to find.
Irony.cc
Old 03-03-2008, 01:29 PM   #19
Mr.James
Mr.James's Avatar
Mr.James is making a name for him/her selfMr.James is making a name for him/her self
you can use the R32 front hubs tho right?
Mr.James is offline   Reply With Quote
Old 03-03-2008, 01:44 PM   #20
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
hypertek,
Didn't you do this already? It's in your "DIY thread"
Details?
Shoot To Thrill
ilovecoupes is offline   Reply With Quote
Old 03-03-2008, 08:49 PM   #21
e30cabrio
Seems like even Porsche guys have done it:
http://www.pelicanparts.com/techarti...conversion.htm
Old 03-04-2008, 01:26 AM   #22
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
LoL, what the hell is "Deep Offset".
projekt_s13 is offline   Reply With Quote
Old 03-04-2008, 01:29 AM   #23
racepar1
racepar1's Avatar
As far as I know there is NO bolt-on 5-lug hub swap for s-13 front hubs.
Old 03-04-2008, 01:31 AM   #24
e30cabrio
Porsche offsets are comparable to s2k offsets, they are very high from the factory.
Old 03-04-2008, 02:01 AM   #25
LFOabuse
LFOabuse's Avatar
LFOabuse is making a name for him/her selfLFOabuse is making a name for him/her self
Ummm how bout...
Ichiba
http://www.ichibausa.com/5lugconversion1.html
Peak performance
http://www.peak-performance.net/content/view/127/96/
$250 / set..... cheap enough considering they include new OEM bearings.
LFOabuse is offline   Reply With Quote
Old 03-04-2008, 02:07 AM   #26
racepar1
racepar1's Avatar
Ok, let me be a little more specific. NO stock nissan hub will bolt onto the s-13 spindle, and actually work correctly, other than the OE s-13 one. Your BEST option is conversion hubs. Did that clear it up with you LFOabuse?
Old 03-04-2008, 02:08 AM   #27
LFOabuse
LFOabuse's Avatar
Crystal.
LOL.
Old 04-25-2008, 08:25 AM   #28
supergoob
supergoob will become famous soon enoughsupergoob will become famous soon enoughsupergoob will become famous soon enoughsupergoob will become famous soon enough
old thread i know..but if you are fortunate enough to have a set of 9 hole rims then its love...just bolt in the 4x114.3 pattern and drill out the remaining holes...voi la....For instance, we have some Impul Silhouettes that are 4x114 and 5x114..instant easy....anybody know exactly what size drill bit to use?
supergoob is offline   Reply With Quote
Old 04-25-2008, 08:41 AM   #29
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
Imabalance is not a big factor at all because the remaining holes are at such a small distance from the center of rotation / axis.
if you wanted to be gung ho about balancing the hubs you can just drill a hole 180degrees away from each of the THREE leftover open holes from the old 4 lug pattern.
its an easy thing to do and if you use wheels that are HUBcentric then I'm surprised more people dont go this route.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold
300hp owen is offline   Reply With Quote
Old 04-25-2008, 08:46 AM   #30
300hp owen
300hp owen's Avatar
thats the right idea.
remove 3 of the 4 lugstuds from the old hub.
place 5lug rotor over hub and remainig lugstud.
push it down flush so it centers itself on the hub-register and seats all nicey nice and hubcentric.
now you can see where to drill the 4 holes to finish up the 5lug.
you better drill nice and carefully easy peasy.
keep the hole size correct so you have a small enough hole to fit the knurled lugstuds just right and so they have enough material to grip and not spin out / strip out when you tighten or loosen the lugnuts.
its easy to drill up in sizes bit by bit until so you only remove a little material each pass, its time consuming but works out better in the end.
