Old 09-21-2006, 02:03 AM   #1
okc240sx
okc240sx is an unknown quantity at this point
Transmission Fluid
I've researched already on what transmission fluid to use. The problem is my sr20det transmission shifts rough. Doesn't really grind just really notchy. I'm wondering what kind of fluid should I use? Something with a heavier weight? I read somewhere that maybe 2 bottles of redline mt-90 and another bottle of their shockproof fluid? Anyone know a good fluid to make shifting smooth again? Thanks.
okc240sx is offline   Reply With Quote
Old 09-21-2006, 02:13 AM   #2
sw20>>s14
sw20>>s14's Avatar
i personally use redline MT-90 in my tranny...no complaints so far except the fact that in cold mornings, it takes a little longer for the tranny fluid to warm up, but its not a big deal...just use anything thats rated at GL-4 (iirc) or above...
95 s14| 03 y34| 07 exige s| 99 nb| 07 600rr| 09 250r| 85 girlfriend
sw20>>s14 is offline   Reply With Quote
Old 09-21-2006, 04:00 AM   #3
vegita319
vegita319's Avatar
vegita319 is an unknown quantity at this point
Send a message via AIM to vegita319
Actually, I wouldnt recommend using GL-5 at all in our trannies. There's a reason that The FSM says use GL-4 in the tranny and GL-5 in the diff. GL-5 has been known to destroy brass syncros and I wouldnt even dare think to run that thing in my car.
Now on topic for MT-90. I love that stuff. Thats makes my tranny shift so smooth. I personnally run 2.5 bottles (quarts) of MT-90 myself. Love that stuff
I've used redline Heavy Shockproof before and man that takes a long time to get warm. My tranny would shift rough for about 5-10 mins but after that, it was the smoothest oil I have ever used in my tranny. Personally thats too extreme for me since by that time, I've already made it to school and the tranny was shifting roughly all during that time. THen again I used 2.5 of shockproof instead of mixing it as you plan to do it.
Also I get my stuff from http://myoilshop.com and use dealer discount code 675421 and get an additional 10% off from the already cheap prices.
+1 for MT-90 though !
vegita319 is offline   Reply With Quote
Old 09-21-2006, 04:23 AM   #4
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
IIRC, you CAN use GL-5 rated oils in the tranny AS LONG AS IT'S ALSO MT-1 RATED. I have a bottle of Valvoline that's GL-4/GL-5 & MT-1. That's okay to use in the tranny and diff.
75w-90 Mobil 1 synthetic gear oil is rated ONLY GL-5. That shit will eat synchros if it gets hot enough.
Ideally, for optimum (by a small margin) performance, you should use a GL-4 only rated oil in your tranny, like MT-90. It's nothing to lose sleep over, using a good MT-1 rated oil won't be noticibly worse than a GL-4 rated oil.
If you want the absolute BEST shit, check out this website:
http://specialtyformulations.netfirms.com/
They forumulate their oils from Group IV and V base oils, not Group III. Group IV and V are TRUE fully synthetic basestocks. From what i've read on BITOG forums (http://theoildrop.server101.com/cgi/ultimatebb.cgi), this oil the the shit.
Anto is offline   Reply With Quote
Old 09-21-2006, 10:47 AM   #5
EndLeSS8
EndLeSS8's Avatar
EndLeSS8 will become famous soon enoughEndLeSS8 will become famous soon enoughEndLeSS8 will become famous soon enough
Redline MT-90 is the best "cheap" thing I've done for my car.
268generation.com
-United for His Renown-
EndLeSS8 is offline   Reply With Quote
Old 09-22-2006, 01:14 PM   #6
LigouriRd
LigouriRd's Avatar
LigouriRd will become famous soon enoughLigouriRd will become famous soon enoughLigouriRd will become famous soon enough
I have been using Pennsoil Synchromesh for the past three years. It cleared up an issue I had with getting into fifth gear. I had a buddy of mine use both redline and the synchromesh and didn't observe any difference except the cost (synchromesh is cheaper).
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk
LigouriRd is offline   Reply With Quote
Old 09-22-2006, 05:57 PM   #7
Anto
Anto's Avatar
waaatch out with synchromesh. It's cSt (viscosity) @ 100 degrees celsius is much lower than 75w-80 gear oil. What does that mean?
Synchromesh is much thinner than the recommended weight oil for your tranny. It's equivalent to something like 5w-30 or 10w-30 oil. Once you start getting into sustained high heat applications, the outcome is pretty nasty :\
Old 09-23-2006, 01:16 AM   #8
MacDrevi0us
MacDrevi0us is on the path to ruinMacDrevi0us is on the path to ruin
so going with redline mt-90 75w90 would be the best?
MacDrevi0us is offline   Reply With Quote
Old 09-23-2006, 11:33 AM   #9
kandyflip445
kandyflip445's Avatar
I've used Penzoil Syncromesh and it's been very good. I've gone on countless trips and it's never gotten bad. I'm probably going to try MT-90 this next change.
My 240 vBgarage
Old 09-23-2006, 11:52 AM   #10
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
i run mobile 1 and shock proof mix in my tranney and h-lsd, i mix them half and half 75/90 M1 with light weight shock proof. my h-lsd is noisey so i drained a half quart of the mix out(wanted to check the magnet any way) and put a 1/2 quart of heavy weight in, didnt change the noise.
my old car went for 3 years with M1 and heavy shock proof and it brought the trans back from the dead, it ground bad 1-2 2-3 until i put the M1/redline mix in.
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 09-23-2006, 12:28 PM   #11
derk
derk is making a name for him/her selfderk is making a name for him/her self
motul gear 300.
owns.
derk is offline   Reply With Quote
Old 09-23-2006, 09:13 PM   #12
Irukandji
redline mt90 in transmission
redline75w90 in the diff (assuming you dont' have open)
Irukandji is offline   Reply With Quote
Old 09-23-2006, 09:57 PM   #13
MacDrevi0us
i bought some redline but its redline MTL 70W80 API GL-4. is this good for a ka tranny or did i buy the wrong thing? i remember someone saying something about GL-5 eating away at synchros. also it says MTL not MT-90 so im confused. i know its prolly a stupid question but better safe than sorry. thanks
Old 09-24-2006, 02:12 AM   #14
kandyflip445
MTL is good also from what I've read.
My 240 vBgarage
Old 09-25-2006, 12:51 AM   #15
Jamison182
Jamison182's Avatar
Jamison182 will become famous soon enoughJamison182 will become famous soon enoughJamison182 will become famous soon enoughJamison182 will become famous soon enough
Im switching to MT-90 also. Sounds like alot of SR owners like it. I've heard from a few DSM ppl MT-90 is the best to run, and those guys know tranny problems the best.
Jamison182 is offline   Reply With Quote
Old 03-05-2011, 02:17 PM   #16
kidbandikoot
kidbandikoot's Avatar
kidbandikoot is making a name for him/her selfkidbandikoot is making a name for him/her self
ive read all ur input.. seems like no really favors just one type
i picked up some mobil 1 75-90w
ill keep u guys posted what i think
CUT AND DRY.
kidbandikoot is offline   Reply With Quote
Old 03-05-2011, 02:28 PM   #17
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
How many times have we gone through this [email protected]? If you searched you would know there is already a thread about this topic. The best thing to had ever happened to my transmission is Amsoil gl-4. Mt-90 takes some time to properly warm up to operating temperature but other than that its OK.
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
