Old 09-12-2006, 09:02 AM   #1
Cashizslick
Cashizslick can only hope to improve
Will an aftermarket diff for S13/S14 fit a J30 (R200V)???
Hey all,
I have not been able to get a straight answer on this issue.
Would a Kaaz/Quaife/OBX aftermarket diff designed for a 240sx (as a replacement for the OEM Open Slip unit) fit a J30 diff setup?
The reason I am asking is because right now i have a J30 installed on my S14 . . . its totally shot and I want to replace it as cost effectively as possible.
I could go out and buy an open slip stock diff setup and have the aftermarket piece istalled into that, but I want to know if it is possible to retain the J30 pumpkin, gearing, and casing and use them with the aftermarket unit.
Thanks in advance,
Cash
Cashizslick is offline   Reply With Quote
Old 09-12-2006, 09:38 AM   #2
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
I don't know the answer to that but there are a bunch of 240sx open diffs around being used as doorstops. You could probably get one for next to nothing and it might be worth it to get your gearing back.
I'm in the same boat btw.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 09-12-2006, 09:55 AM   #3
Cashizslick
Ya, although the J30's gearing is so nice on the highway, its easy enough to go back to a stock diff and swap in an aftermarket unit.
Maybe ill just ditch the J30 and go aftermarket/OEM Open diff.
Old 09-12-2006, 09:59 AM   #4
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I picked up and open for $45. They are pretty much everywhere. You can always call KAAZ. Talk to Ray and ask him. He is a really nice guy and I recommend them.
Jung918 is offline   Reply With Quote
Old 09-12-2006, 10:42 AM   #5
orion::S14
orion::S14's Avatar
orion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to behold
The short answer: YES.
A R&P set might not fit, sinc eht eJ30 has a longer pinion..but KAAZ and the like just replace the center section (the open diff unit, or the VLSD)...
...so as long as the aftermarket diff you buy is intended to be installed into an R200 VLSD (different outut shafts as compared to open diff models of aftermarket diffs)...then you're set.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 09-12-2006, 10:51 AM   #6
Cashizslick
So then an LSD that fits an R200 wont necessarily fit an R200V?
If its the center unit does it matter?
Thanks for the replies - rep given.
Old 09-12-2006, 11:07 AM   #7
MOUNTAINGARAGE
MOUNTAINGARAGE's Avatar
MOUNTAINGARAGE is making a name for him/her selfMOUNTAINGARAGE is making a name for him/her self
no it won't fit. if you have a factory r200v, you will need to replace the center lsd with one made for a factory installed vlsd/diff/r&p.
for example:
Kaaz lsd for factory Vlsd: DBN2625
Kaaz lsd for Factory open: DBN2620
hope I helped.
MOUNTAINGARAGE is offline   Reply With Quote
Old 09-12-2006, 12:37 PM   #8
Cashizslick
cool.
So just to clarify: Any diff made for a factory VLSD will fit the J30 & 240sx VLSD modles?
Good info BTW
Old 09-12-2006, 01:26 PM   #9
MOUNTAINGARAGE
cool.
Good info BTW
pretty much, when you get an lsd, just ask for one that fits a vlsd...a good shop will make sure you get the correct fitment.
Old 09-12-2006, 11:32 PM   #10
lonedrifter
lonedrifter is an unknown quantity at this point
s13
Hey all,
Thanks in advance,
Cash
the only thing i know to do in order to keep ur j30 is to have it rebuilt, but kaaz makes a lim/slip dif just for 240's 89-98 it;s a direct bolt on, no fab needed, but it's about $1190 + shipping,
lonedrifter is offline   Reply With Quote
