Old 08-30-2017, 03:21 PM   #1
Pygmy240sx
Pygmy240sx's Avatar
Pygmy240sx is an unknown quantity at this point
SAFC II wont hot start
Installed SAFC II and everything was good. started right up and street tuned it.
went home turned off the car and when i tried to turn it back on it would crank and flood the engine. it will cold start every time. and wont start after 30 mins of driving.
I can unplug the safc II and it will start right up even when hot. but the car wont idle (idk if this is normal)
s13 Sr20det, 13 psi t25, FMIC, 3 inch Exhaust, 255lph Fuel pump. everything else is stock.
any ideas what i can do? when i unplug the safc 2 the car will not idle or rev pass 2500rpm
Pygmy240sx is offline   Reply With Quote
Old 08-31-2017, 11:59 AM   #2
Juan@Fontananissan
Juan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura about
what are your low throttle settings?
Competition Engines & Dyno Tuning.
(951)708-1648 | [email protected]
Juan@Fontananissan is offline   Reply With Quote
Old 08-31-2017, 08:25 PM   #3
Pygmy240sx
Pygmy240sx's Avatar
low throttle at 800 is set to 2 ( should i bring it down?) goes to 4 being the highest at 7k rpms (even though i shift at 3.5k at low throttle)
Old 08-31-2017, 08:26 PM   #4
Pygmy240sx
Pygmy240sx's Avatar
then throttle sensor is set to low being 35% and 75% being high
Old 08-31-2017, 08:27 PM   #5
Pygmy240sx
Pygmy240sx's Avatar
low throttle at 800 is set to +2 ( should i bring it down?) goes to +4 being the highest at 7k rpms (even though i shift at 3.5k at low throttle)
safc 2, safc ii, sr20det
