Old 10-04-2018, 01:02 AM   #1
Blackmassive2669
Blackmassive2669 is an unknown quantity at this point
Rear Coilover Shock Bushings
I've search and really couldnt find any answers about this
I wanted to get rid of this LOUD squeak on the rear of my 240. Figured it would be worn out bushings so i decided that im going to buy new lca (for rubber bushings) since the previous owner never touched it. (Has upgraded suspension arms though..)
Then i decided, why not change that bottom bushing of the coilover. Currently have Circuit Sports C2 coilovers
I like them and they seem to do the job, but since I'm down there, fuck it right.
Sent a message to Circuit Sports about a replacement bushing but got no reply.(probably asked a dumb question?
Went through search bar and google and nada damn answer.
So i was wondering if a oem shock bushing would fit or is a specific sized bushing?
Is this even possible to do or would i be better off buying new coilovers?
Blackmassive2669 is offline   Reply With Quote
Old 10-04-2018, 01:38 AM   #2
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
Maybe post a pic of what you’re talking about
Red Rocket
apex is offline   Reply With Quote
Old 10-04-2018, 06:45 AM   #3
Blackmassive2669
These fellas.
Sorry, i assume they were called shock bushings if that's not what they're called
Old 10-04-2018, 08:06 AM   #4
tuzzio
tuzzio's Avatar
I'm fairly positive circuit sports had some sort of management change or got shut down a year or so ago. I however, may be very wrong because tons of people still carry CS stuff.
I'd take a measurement and start calling other coilover companies.
Old 10-04-2018, 06:54 PM   #5
Blackmassive2669
Dang that sounds like a plan then. Coilover usually use rubber bushings right? Not trying to use poly cause the often lubing you have to do on them
Old 10-05-2018, 08:07 AM   #6
tuzzio
tuzzio's Avatar
I have poly bushings on my car in certain areas and never lube em.
