Old 06-17-2017, 01:23 AM   #1
JettNebulis
JettNebulis is an unknown quantity at this point
KA Possible Bad MAF? Help me please.
I have a infamous 240sx idle issue. Im bogging something awful and a horrid shake under load till around 2k then after that it's nearly normal. The weird thing is if i spray some b12 carb cleaner directly on my pod filter it seems to idle normally. I have dumped around 4k into my engine bay just trying to not make it 4.5k. I guess a silver lining is that everything is new but, realistically could have just sr swapped it.
I have replaced the tps twice (first one was faulty), injectors, fuel pump, spark plugs and wires, cap and rotor, ignition coil, engine (yes a new engine), fuel filters like 1 month old, o2 sensors pretty new, clutch, flywheel, battery is 5 months old, alternators tested, water pump, oil pump, etc.
basically everything but iacv, maf, knock sensor, and i guess ecu.
JettNebulis is offline   Reply With Quote
Old 06-17-2017, 07:19 AM   #2
drb5721
drb5721 is an unknown quantity at this point
Unplug the MAF and see how it runs. The fact sparying a combustible chemical in the intake stream make it idle better points more towards fuel. Possibly bad gas? Or a bad replacement fuel pump? Have you checked fuel pressure? Maybe a bad fuel pressure regulator?
drb5721 is offline   Reply With Quote
Old 06-21-2017, 04:05 PM   #3
JettNebulis
It's a maf based issue I unplug it and it runs great. I have a different issue now bought a new maf and it's doin the same thing. Could​ it be my pod?
Old 06-21-2017, 07:30 PM   #4
drb5721
It is possible you got a faulty maf. Ask me how i know lol. If you bought it from a parts store it will have a warranty. Clear ecu codes and start the car with the maf plugged in. Let it run for a minute or so. Restarting is ok. Then check codes again. See if you get a maf code.. Make sure the screw on the ecu is turned all the way clockwise before running the car so it actually picks up on issues.
Also, if you think its a filter issue, you could just take the filter off for one quick start and see what happens.
Old 06-21-2017, 08:07 PM   #5
JettNebulis
I just bought a new pod because my old one was pretty thrashed anyways it didn't help. I never got a cel code. In going to return it and say it's faulty.
bogging, help ka24de problem, idle problems, ka24de, shakes
