Old 04-01-2016, 07:20 PM   #1
sileighty2jz
sileighty2jz is an unknown quantity at this point
Lightbulb 1988 Nissan Cefiro A31
Year: 1988
Make: Nissan
Model: Cefiro A31
Price: $13,995
Mileage: 86,000
Color: pearl white
Private or Dealer Listing: Private Listing
Location (State): Springfield, VA
Transmission: Manual
Drivetrain: Rear Wheel Drive
VA title
call/ text at 7038648176
Description:
Hey guys I'm selling my 1988 Nissan Cefiro that was imported thru Japanese classics llc and is 100% legal. The Cefiro came swapped from japan with an s14 sr20det in Japan but i replaced with a 1JZ vvti. The car runs great with no issues what so ever as its my daily driver. The car is running off the stock ecu. The car does have some rust on the rear fender wells but nothing major for its age. Frame rails are rust free and the paint still shines. The rear seats have been removed to accommodate an aluminium battery box but will be included with the sale.
ENGINE:
1JZ VVTI from a Toyota Chaser
Heat Shielding Gasket - BOTH Upper and Lower Gaskets intake manifold
1JZ/2JZ Mishimoto Thermostat
1JZ Denso Oxygen Sensor
Custom engine and trans mount
Tial 51mm BOV
NGK Iridium IX spark plug 6418 / BKR6EIX
K&N 4 inch Universal Filter, Short Version
Freed Enginering Custom v band downpipe
Freed Enginering Custom midpipe with Greedy axel back
Chase bays fuel lines
Walbro 255 Fuel pump
Alumunium radiator (came with car from japan)
HPS Radiator Hoses - Blue
Greddy R34 Intercooler using 2.75" Intercooler Piping
AEM Wideband
ARC Switch panel
Transmission/Suspension/Wheels:
Dowel Pin For R154 And W58 Flywheel
R154 transmission
R154 OEM flywheel
Marlin Crawler Shifter Socket R154
Marlin Crawler Urethane Shifter Bushing For R154 Transmission
ARP Flywheel bolts 1JZ/2JZ
Spec Stage 2+ clutch
Custom power steering and clutch line
Freed Enginering Custom shifter extension for r154
Freed Enginering Custom driveshaft
Nismo Differential
Front and rear Cusco strut bars
Tiens Coilovers "super drift street coils"
5- lug conversion
New front wheel hubs
Z32 brakes all around with Z32 rear e-brake
New power stop brakes all around and drums
Tien inner and outer tie rods
SIkkY sway bar
Custom s14 steering knuckles from japan
WORK VSXX 18x10.5 +15 4.5" with New lip 18x9.5 +22 3" lip
New tires on the front. not even a month old.
Achilles tires front 225/40R18 100% tire
rear same size but other brand. 50%
Interior:
Defi BF advance "amber"
boost, oil temp, water temp, 80mm 9k rpm tach
Driver side has a replica Bride lowMax seat
Street Faction seat rails
R32 seat for the passenger side
Nardi Steering wheel
Tomei Shift knob
Nismo shifter "Not short shifter"
Xplod CD player
Drift "buttion" for ebrake
New window motor for driver rear door
Aluminium re-locator battery box. back seat "will come with back lower seat"
Exterior:
Car came painted pearl white from japan
Full ORIGIN body kit
Black Plasti dipped door handles
8K HIDs
LED blubs for the corners and lisence plate.
35% tint all around.
carbon fiber trunk vinyl
black vinyl roof. pealing off on the front. sucks i know.
sileighty2jz is offline   Reply With Quote
1jz vvti, nissan, rhd
