Old 04-03-2012, 02:45 PM   #121
Silvia479whp
Silvia479whp's Avatar
Silvia479whp is a well-known jackass
Originally Posted by zurud View Post
1.5 is real good. What's the setting on the agx front and rear. Do you have any launch control or some sort? Nice to video of that run.
soft front n rear
yup 2 step on aem s2
http://youtu.be/rScOarcbyRY
Silvia479whp is offline   Reply With Quote
Old 04-03-2012, 02:47 PM   #122
Silvia479whp
Originally Posted by Vetal View Post
Yes, was going to ask too - is 2-step really necessary? My traction is so dismal that I don't need any boost off the line
yup u do need a 2 step
Old 04-03-2012, 02:54 PM   #123
Vetal
Vetal is an unknown quantity at this point
how does it help?
12.0@121mph 2.0 60ft, CA18 S13
Evo3 16G,XSPower ex mani, Nistune 950cc E85
Vetal is offline   Reply With Quote
Old 04-03-2012, 04:47 PM   #124
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
how does it help?
allows you to have the pedal floored but the motor will not pass its set RPM, also timing is taken away to build boost
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 04-03-2012, 04:55 PM   #125
Vetal
So only kind of "comfort" thing, that makes your life a bit easier?
As I said, I don't need boost off the line yet...
Old 04-03-2012, 05:33 PM   #126
turbociv910
turbociv910 is an unknown quantity at this point
2 step and anti-lag are 2 different things.
timing isn't just taken away, it is decreased into the negatives, somewhere between -5 and -10, to combust when the exhaust valve is open. Thats why you get all the fire along with anti-lag.
2 step is just a early limiter set within your ecu to shut off at a determined rpm or clutch pedal release.
www.carolinadyno.com
s13 LSx turbo drag car- 1.42 60 ft, 6.32 1/8
turbociv910 is offline   Reply With Quote
Old 04-04-2012, 02:31 AM   #127
zurud
zurud is an unknown quantity at this point
I try to launch on stock rev limiter but it doesn't built positive boost at all. I am thinking using rev limiter as cheap way for no lift shifting. I have rush anti lag but I am afraid to use it as I heard horror stories about it.
zurud is offline   Reply With Quote
Old 04-04-2012, 05:06 PM   #128
S@nt0s
S@nt0s's Avatar
comfort? i thin kyou just need to go back to the basics and not worry about anti lag/ 2 steps and work on getting the most out of what you got currently. with all the things in the word if you cant drive it it isnt going to help.
i know that i am putting it in the simplist way possible so he understands it
MunkyW3rkz Racing
Old 04-04-2012, 05:36 PM   #129
2bad240
2bad240's Avatar
2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about
i hope to get my sr s14 out the drag strip soon. i ran a 8.45 in the 1/8th the day i got it with my 26" slicks off my Z on it. and since then i replaced the clutch and raised the boost from 7 to 15 and fixed a bunch of other issues so im hoping for some 11.9-12.2s. but we will see.
i got a 1.74 60' on my 26" m&h dot slicks on a xtd clutch that was in the swap when i got it.
you, its whats for dinner.
2bad240 is offline   Reply With Quote
Old 04-04-2012, 07:03 PM   #130
ditchs14
ditchs14's Avatar
ditchs14 is a well-known jackass
this is my buddys 240. he ran a 11.5. 60 ft was 1.777 on slicks
http://www.youtube.com/watch?v=DKLDx5IlwW0
http://www.youtube.com/watch?v=1j5I0BiyN1s
ditchs14 is offline   Reply With Quote
Old 06-14-2012, 11:42 AM   #131
S@nt0s
S@nt0s's Avatar
lets jump start this back, Saturday I will be doing my first shake down passes
E85 6266 sr20det - YouTube
MunkyW3rkz Racing
Old 06-15-2012, 12:27 AM   #132
zurud
Hey santos good luck saturday. Do you have line lock? It looks like nisssan have 2 line coming out from master cylinder. Most cars have only 1 line that teed into 2 for left and right. Is anybody make line lock for 2 in 2 out?
Old 06-15-2012, 01:28 AM   #133
bftII40
bftII40's Avatar
bftII40 is an unknown quantity at this point
drag racing is ghey, there i said it. / thread
bftII40 is offline   Reply With Quote
Old 06-15-2012, 06:48 AM   #134
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 06-15-2012, 07:19 AM   #135
S@nt0s
S@nt0s's Avatar
thanx, last night i was doing the battery switch.
I have a Line lock just havent installed it yet thats coming within a month.
one is for th efront and the other is rear so you only need to run from the front to th eline lick sileniod then from there to the brakes
MunkyW3rkz Racing
Old 06-15-2012, 08:20 AM   #136
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Great thread!
Question for you guys is what wheel/tire (other than those of you who have posted) setup are most of you guys running?
I have a set of NA supra wheels which are 16 x 9 and I am not sure which tire to go with. I am thinking I will pick up some 26x11.5x16 for the rears and contemplating running 17" GTO spare wheels in the front with like a 17x4.5 tire.
What are you guys using as a setup in the front?
FYI, this is going into an S14 body. Q45 3.69 LSD, 300zx TT axle + Q45 axle, Z32 TT Hubs.
2muchboost is offline   Reply With Quote
Old 06-15-2012, 09:07 AM   #137
S@nt0s
S@nt0s's Avatar
Originally Posted by 2muchboost View Post
Great thread!
M&H and MT both make a 26/11.5 for a 16"
unless you are a big brake front like me then theres no need for the 17" unless you want the look. I am running the 17" alumastars with the M&H Radial 185/55. I needed a spacer to clear my Brembos.
MunkyW3rkz Racing
Old 06-15-2012, 09:40 AM   #138
amberlys13
amberlys13's Avatar
amberlys13 is an unknown quantity at this point
my car s14 ka-t 800hp +
amberlys13 is offline   Reply With Quote
Old 06-15-2012, 09:42 AM   #139
S@nt0s
S@nt0s's Avatar
nice, whats the set up?
et's?
MunkyW3rkz Racing
Old 06-15-2012, 09:53 AM   #140
amberlys13
amberlys13's Avatar
et's?
its a ka-t
Old 06-15-2012, 10:02 AM   #141
S@nt0s
S@nt0s's Avatar
Originally Posted by amberlys13 View Post
its a ka-t
umm ya i got that part, i guess you dont want to put it out there.
this th eone "honey" puts on NWP?
MunkyW3rkz Racing
Old 06-15-2012, 10:44 AM   #142
amberlys13
amberlys13's Avatar
regular junky motor,300zx tranny ,twin disk clutch,aem,m & w ignition lol q45 diff lol may go c4 auto lol i post more pic later
Old 06-15-2012, 10:46 AM   #143
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Is your's the KA-T car thats in alot of the "ThatRacingChannel" Videos?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 06-15-2012, 12:16 PM   #144
amberlys13
amberlys13's Avatar
no there is a white one but its a 95 that's an other guy ,there is a black 98 that race him and beat him that's my buddy's car,my car is not done but should be way faster that the black one and the other white 98 from TRC it has a 2JZ
Old 06-15-2012, 12:18 PM   #145
S@nt0s
S@nt0s's Avatar
so your hoping for 800+ it isnt even running i take it?
MunkyW3rkz Racing
Old 06-15-2012, 02:20 PM   #146
2muchboost
Trader Rating: (33)
I have z32 iron calipers and z33 12.75 rotors up front. I looked at the Alumastar 17's that your running but I found a local junkyard that has 2 GTO's that both have the spare tires for cheap.
I was leaning more toward the MT tires but I am open for suggestions.
Amberly very clean setup.
Old 06-15-2012, 02:43 PM   #147
S@nt0s
S@nt0s's Avatar
ya a lot a domestic guys are running the GTo spares. I seen a S14 running them once
MunkyW3rkz Racing
Old 06-15-2012, 02:58 PM   #148
amberlys13
amberlys13's Avatar
the front is 15 inch wheels and im not hoping lol i know im going to make 800hp some other guy made that already with a different set up than mines, smaller turbo, the black 240sx already made 705hp an is on a auto tranny. ,the black car is my buddy's ,the white one make over 735 hp to the wheels i have a way better set up than both of them so i know i going to make more than 800hp
S14 KA-T 240 auto 700+hp vs S14 KA-T 5 speed 700+hp - YouTube
Old 06-15-2012, 03:47 PM   #149
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
I like the way this thread is going. It is about time there are more people on this forum that do more than drift their 240. Amberlys13 that is a sick setup, is that a borg warner s374? I am going to run a mazworx sr22 motor with a borg warner s366 and I am shooting for 700+whp on e85, and then see how much it can make on c16 race fuel.
Let's keep this thread alive.
Sr22 in the works
slow92 is offline   Reply With Quote
Old 06-15-2012, 08:40 PM   #150
Silvia479whp
@ amberlys13
What wheel do u have up front and offset and what brake setup
