Old 06-25-2018, 08:07 PM   #1
Matt.tobey427
Matt.tobey427 is an unknown quantity at this point
240sx won't run please help
My 1997 s14 ka24de is having issues. The car has fuel pressure and spark and cranks but won't start. It only runs for a short time when I spray and prime into the throttle body. I recently changed out the intake manifold but im certain i got everything plugged in correctly. Just curious if anyone has ever had this problem and what it could be. Maybe a distributed or coil pack? Any info appreciated
Matt.tobey427 is offline   Reply With Quote
Old 06-26-2018, 09:59 PM   #2
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
Make sure the connectors near the ecu are plugged in. right under the dash
nissansrdub is offline   Reply With Quote
Old 06-28-2018, 02:18 PM   #3
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
If it runs on starter fluid, then it's a good chance that the issue is fuel related.
Autozone rents a set of NOID Lights you can hook up to your injector plugs to ensure they are firing correctly, if they are then it could be a fuel pressure issue.
Remember when you took the intake manifold off, you had to disconnect your fuel feed and return lines, and your fuel pressure regulator vacuum lines, and i think a harness ground as well, that grounds on the right side of the intake manifold towards the front of the engine. Make sure all of those are hooked up correctly to ensure fuel pressure is getting set and the injectors are indeed firing
5.3 V8 Swap w/ Nitrous
unicoder is offline   Reply With Quote
Old 06-28-2018, 02:49 PM   #4
staying_chuki
staying_chuki's Avatar
staying_chuki is an unknown quantity at this point
You said it starts when you spray into the throttle body. Answered your own question bro, its fuel related you should be able to go from there and fix it easy.
staying_chuki is offline   Reply With Quote
240sx, ka24de, wont start
