Old 04-26-2017, 10:34 PM   #1
SlidewayZenki
SlidewayZenki is an unknown quantity at this point
Part Out! Unfinished S14 Project - Lots of NEW Parts
I sold my S14 and have a ton of leftover parts.
Please PM me with your zip code for shipping quotes. All prices are OBO!
- ACT Street Performance Sprung Clutch (both were removed from the box and balanced together by a local machine shop - comes with new throw out bearing snap ring from Nissan) $550
- AEM Wideband O2 Failsafe $200 (sale pending)
- ARP Flywheel Bolts $55 SOLD
- ARP Head Studs $65 SOLD
- ATI Super Damper SR20 (with power steering) $400 (sale pending)
- Cometic StreetPro Gasket Set (valve seals are missing, otherwise it's a complete gasket set) $20
- Mazworx SR20 Timing Chain Tensioner $70 SOLD
- NEW Nissan SR20 Timing Chain $45 (sale pending)
- NEW Nissan SR20 Timing Chain Guide (slack side - comes with new OEM bolts) $30 (sale pending)
- NEW Nissan SR20 Timing Chain Guide (tensioner side - comes with new OEM bolt) $15 (sale pending)
- NEW Nissan SR20 Oil Jet Squirters (x4) $80
- NEW Nissan SR20 Oil Pump Drive Spacer $3 (sale pending)
- NEW Nissan SR20 Oil Block O-Rings (x2) $3
- NEW Nissan SR20 PCV Valve $5
- Tomei SR20 Pistons 86.5mm $900 SOLD
- Tomei SR20 Connecting Rods $400 SOLD
- Tomei Main Bearings (made by ACL) $150
- Tomei Rod Bearings (made by ACL) $100
- Tomei Rocker Arm Stoppers $50
- Samco Sport Radiator Hoses (blue) $65 (sale pending)
USED PARTS
-Timing Components (chain, chain guides, chain tensioner, crankshaft timing sprocket, oil pump spacer) $25
-Block accessory mounting brackets $100
-Oil Pump $50
-Complete S14 Kouki Silvia Harness for NA ECU $100
-S14/15 Coil Harness $25 (sale pending)
-Plug Coils $100
-Oil Pressure Sensor $10
-Cam Sensor $125
-Ignitor Chip $75 (sale pending)
Throttle Body $100
-S14 Kouki Silvia ECU (Black NA) $200 (sale pending)
-S14 Motor Mounts $50
-Stock SR20 Pistons $50 (sale pending)
SlidewayZenki is offline   Reply With Quote
Old 04-28-2017, 11:52 PM   #2
SlidewayZenki
Bump...More parts added!!!
Old 04-29-2017, 09:00 PM   #3
SlidewayZenki
Bump! I need this stuff gone!
Old 04-30-2017, 08:01 AM   #4
SlidewayZenki
Hoping to have the rest of this stuff sold by the end of the day!
All prices are OBO...low ballers welcome!
Old 09-27-2017, 03:36 PM   #5
CalebTaylor
CalebTaylor is an unknown quantity at this point
I need a stock piston if they haven't sold yet? Looking for a 2 rating and 79E 05 weight
Sent from my LGLS992 using Tapatalk
CalebTaylor is offline   Reply With Quote
Old 09-28-2017, 08:39 PM   #6
SidewayzAsFck
SidewayzAsFck can only hope to improve
If super damper falls through, pm ASAP. Cash ready
SidewayzAsFck is offline   Reply With Quote
s13, s14, s15, sr20, sr20det
