Old 06-10-2016, 08:33 PM   #1
jhollin9
jhollin9's Avatar
jhollin9 is an unknown quantity at this point
KA Single Jingle KA24E help needed
Okay I feel like an idiot here. Got this creamy grey two tone with a single cam that mixed fluids but ran great. Took the whole front off and fixed the mixing fluids but trying to put everything back together I'm having a hard time getting it running right again. I've checked the fuel spray and while cranking all four injectors fire simultaneously. It backfires through the intake and will not idle. Things I've tried: stabbed the oil pump/dizzy shaft 1000 times, bought new distributor, tried different ECU and most recently installed new harness as per forum searches.
Any suggestions or tests to perform are appreciated.
jhollin9 is offline   Reply With Quote
Old 06-10-2016, 08:41 PM   #2
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
Double check your timing. Did you mess with the timing chain?
lunchmeat is offline   Reply With Quote
Old 06-10-2016, 08:52 PM   #3
jhollin9
jhollin9's Avatar
Yes. The original problem of mixing fluids was the timing chain ate the slack side tensioner and ate through the timing cover where water passes through so I replaced all that. Triple checked the mechanical timing, plated links all in the right place when we put in together and checked cam position after turning it over a few times and resetting to TDC.
Old 06-14-2016, 04:13 PM   #4
jhollin9
jhollin9's Avatar
Yes I replaced the timing chain along with the timing cover and tensioners. I am confident in the mechanical timing. Used the plated links when setting it, checked three times and checked the cam position. About 90% confident in the spark timing, its a fucked way to set it in the first place but I can't get it running well enough to put a timing light on it to see if I'm way out. I've tested the fuel spray and maybe thats not the only issue but its wrong regardless. No idea how to fix it though.
Old 06-17-2016, 09:56 PM   #5
Alisaihin
Alisaihin's Avatar
Alisaihin is an unknown quantity at this point
Firing simultaneously, as in AT THE SAME TIME?
Alisaihin is offline   Reply With Quote
Old 06-18-2016, 06:25 AM   #6
jhollin9
jhollin9's Avatar
Yes as far as I know that's the only definition of simultaneously. Same time. All four pulsed together while cranking.
Old 06-18-2016, 07:15 AM   #7
Edixon
Edixon is on a distinguished road
The injector pulse is normal according to the FSM (page EF&EC 17)...I seriously think that your oil pump is stabbed in a tooth off, I know you said you checked it. IIRC, with the distributor removed, the "D" shaped key should be at the 11-11:30 position.
Edixon is offline   Reply With Quote
ka24e, s13
