Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 03-04-2014, 12:10 PM   #1
WorksCanada
WorksCanada is an unknown quantity at this point
Works Engineering Adjustable Cam Gears
Each gear is adjustable in 1° increments to a maximum +/- 10°. Our engraved timing marks are accurate to within 1 minute of degree! With the simple design our gears end up being lighter than the stock gears they replace.
Our tooth profile matches the OEM spec exactly for each gear we make. The outer cog section of our gears is black hard-anodized, to prevent on/wear from the timing belt. We use black hard coat because of the great contrast it gives against our engraved timing marks. The 5-bolt locking pattern is plenty secure and we use only stainless steel hardware to ensure durability. This design provides a lifetime of worry-free adjustment.
Machining for optimum component fit is critical with adjustable cam gears. Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened. Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions.
Currently in Stock ($200CAD per set)
2JZ
*B-Series
*RB20\25\26
*SR20
*4AGE
* Please allow an extra few days for shipping. Items are located at warehouse location.
PM or Email for shipping quotes.
Works Engineering - Canada
For Inquiries please Email or PM
Email: WorksEngineeringCanada[a t]gmail.com
PM: WorksCanada
WorksCanada is offline   Reply With Quote
Old 03-05-2014, 07:39 AM   #2
richmond82
richmond82's Avatar
Trader Rating: (30)
richmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura aboutrichmond82 has a spectacular aura about
Feedback Score: 30 reviews
hoping to get these very soon for my s15SRDET
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
richmond82 is offline   Reply With Quote
Old 12-02-2017, 09:56 PM   #3
Sergio180sx
Sergio180sx's Avatar
Trader Rating: (24)
Sergio180sx is on the path to ruinSergio180sx is on the path to ruin
Feedback Score: 24 reviews
Anyone running these yet? Thinking of buying these for my built rb25.
S13.4 Rb25 Neo vert
07 g35 coupe
[/B]
Originally Posted by DriftOutlaw View Post
No not at the moment but an easy fix. just swap the motor I have in and take the old one out.
Sergio180sx is offline   Reply With Quote
2jz, rb20, rb25, rb26, sr20
