Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 07-21-2014, 04:37 AM   #1
GKTECH
GKTECH's Avatar
GKTECH is making a name for him/her selfGKTECH is making a name for him/her self
GKTech - SR20 Eccentric Throttle Wheels
S13/180SX SR20DET Eccentric Throttle Wheel
The S13/180sx SR20DET eccentric (ie. off-center) throttle wheel makes the travel of the throttle cable down low in the rev range longer and gives you more control, and makes the travel up high shorter for instant throttle response. Great for drift
or even general street use. Seriously, one of the best cheap mods money can buy.
- Light weight 6061-T6 billet aluminium construction
- Direct bolt on replacement of the standard throttle wheel
NOTE: some S13/180sx's SR20 throttle bodies have a longer spring shaft than others. You may need to trim the shaft down around 3-4mm's if it is touching. When installing ensure that it is not touching and if it is, trim it down with a sanding disc or similar
Price: 36 AUD (approx. 31 USD)
Shipping cost: From 22 AUD (approx. 21 USD)
Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July.
ORDER HERE: http://www.gktech.com/index.php/s13-...tle-wheel.html
V2 S14a/S15 SR20DET Eccentric Throttle Wheel
The S14a/S15 eccentric (ie. off-center) throttle wheel makes the travel of the throttle cable down low in the rev range longer and gives you more control, and makes the travel up high shorter for instant throttle response. Great for drift
- Light weight T6-6061 billet aluminium construction
- Confirmed fitment for VCT SR20's fitted in S14a's and S15's. This wheel will NOT fit non VCT motors or Series 1 S14's.
ORDER HERE: http://www.gktech.com/index.php/v2-s...tle-wheel.html
FAQ
What’s the advantage of the eccentric throttle wheel?
The eccentric throttle wheel makes the travel of the throttle cable down low in the rev range longer and gives you more control, and makes the travel up high shorter for instant throttle response. Don’t believe us? Try it, if you’re not happy with it we’ll gladly refund your money.
Do you make these for other cars?
No, we only sell the products listed on our website. If it's not listed on here, then we don't sell it. Sorry.
I have an aftermarket throttle body, will this fit?
We don't know. Try fit your standard throttle wheel on your aftermarket throttle body, if it fits then this wheel should fit.
Is this hard to install?
No, not at all. Pop your bonnet, unbolt the standard throttle wheel and bolt this one on. It shouldn’t take longer than around 2 minutes.
Will I have to get my car tuned after installing the easy throttle?
No, nothing is changed in terms of the engine. The wheel just alters the feel of the throttle which ultimately gives you more control.
For any inquiries please e-mail us at [email protected].
USA Warehouse now open
www.gktech.com.au
GKTECH is offline   Reply With Quote
Old 07-22-2014, 09:52 PM   #2
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
please do a q45 wheel!
TougeLabs is offline   Reply With Quote
Old 07-22-2014, 10:42 PM   #3
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
You guys make great stuff, but you need a distributor in the US to bring those shipping prices.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 07-23-2014, 01:19 AM   #4
GKTECH
GKTECH's Avatar
There is no plan to manufacture a Q45 wheel at this time. However if a lot of people show interest then we will consider it.
Unfortunately at the moment we have a hard time keeping up with demand based from just 1 location however once we have enough inventory we do intend up setting up our own US warehouse, just don't hold your breath for it as it won't happen overnight. That said we do currently have a $30 discount coupon for orders over $100 using the discount code 'zilvia.net'
Cheers
www.gktech.com.au
Old 07-23-2014, 07:50 AM   #5
5280VertDET
Cheers
THANKS! Keep up the good work!
