Old 10-14-2018, 10:55 PM   #1
Smithwick
Smithwick is an unknown quantity at this point
FS: S13 / SR20DET / Universal Yard Sale
Alright guys, here goes. Got a list of parts that I need to part with in no particular order. Some stock stuff, some aftermarket stuff. Located in Somerville, MA (Boston, basically). Shipping is extra. If you buy multiple things, we can probably work out a deal. Prices are slightly negotiable but I feel like I'm being fair, so don't expect go get things for 50% lower.
As always, please message me when you have cash ready to go (or Paypal in this case) - not gonna hold things for anyone, sorry!
I *should* have pics for everything, but just post if I'm missing anything.
Update 7/19/2019 - New items added, pics that were not displaying correctly have been fixed, also cleaned out some redundant/old pics. More pics available if needed. Feel free to message me with offers - will do discounts for multiple items! Thanks
$20 Sparco Dead Pedal Kit NEW
$15 Dragon Digital Oil Temp Gauge 52mm NEW
$10 Passive Car Audio Subwoofer Control NEW (volume and cutoff frequency controls. does not need to be wired to power)
$10 Black Metal Triple 52mm Gauge Pod - has top mounting slots - NEW
$85 Prosport EVO 52mm Water Temp Gauge NEW
$15 50MM Black Addco Steering Spacer - NEW
$5 Black Billet Aluminum Oil Filler Cap - Fits Nissan / Honda. Had this on my car for a couple of months before I finally located the elusive HKS one I was looking for
$30 Supermassive 10" Intake Filter NEW - 76mm mounting ID (fits 76mm OD pipe). Clamp included
$20 'Billion' Intake duct+ducting NEW - one of these already sold, found another one
$8 SR20DET Redtop Valve Cover Keychain NEW. Found them at the bottom of a box that we got forever ago when I was cleaning out the shop. New in bags, couldn't really get them to photograph well, so I just got a pic online that was close - the ones I have look a little better but don't have the black dots (that are supposed to be the coilpack cover bolts). One left now
$75 Oil Filter Relocation Kit NEW - Circuit-sports type, 1-meter AN10 lines, straight fittings on one side and 90-deg on the other, uses M20x1.5 (S14 SR20DET) filters
$40 Chase Bays Fenderwell Front Brake Lines for Z32 Brakes on S13/S14 - NEW
$5 Red Oil Breather Filter 12mm ID, NEW
$20 Universal catch can (with whatever fittings pictured) NEW, just shelf wear
$20 S13 Megan Racing RUCAs. Well used. Ran fine on my car, just pulled them off to upgrade. One side seems stuck, haven't tried to un-stick it though, may be easy. The ball on one seems sloppy as well. Priced accordingly
$20 S13 Stock Exhaust Manifold, used
$10 S13 OEM shift knob, used
$90 S13 Apexi Front Strut Tower Bar - used, shows wear where the nuts went in, but obviously that will be covered when you install
$5 Misc Modified Downpipe, looks like this was ported and then welded, ran fine on my car but don't really know what's up with it
$40 ProSport Water Temp Gauge 60mm TEST MOUNTED AND WIRED not actually run, thing is basically new
$5 Spectre 76mm (3in) Cone Air Filter, used
$30 S14 Passenger (right side) seat with bracket/slider - good used condition
Pics:
SOLD Carbon RHD Center Console Surround NEW
SOLD Z32 Set of Rear Ceramic Brake Pads NEW
SOLD Silver shift knob, NEW. Comes with multiple threading adapters for different cars, one is Nissan
SOLD S13 RHD Brake Pedal, used
SOLD eBay Screamer Pipe for SR20DET, not sure what the brand is (does it matter if it's ebay?)
SOLD S13 SR20DET Lightweight Alu Power Steering Pump Pulley, not sure on brand
SOLD S13 Front Air Diversion Panel - Allows for better airflow to the radiator. I threw it on my car and didn't like how it looked, so I took it back off and here it is
SOLD Chase Bays Fenderwell Front Brake Lines for Z32 Brakes on S13/S14 - Brand New
SOLD S13 Tie Rods + Boots, really nice shape
SOLD SR20DET Redtop ECU, worked great, just put a PowerFC in
SOLD SR20DET Redtop MAF + 4-bolt adapter (so that you can fit a 3"/76mm air filter)
SOLD Omori Mechanical Water Temp Gauge w/sensor, vintage!
SOLD Omori Mechanical Oil Temp Gauge w/sensor, vintage!
SOLD Generic 3" red cone air filter. 5" tall cone, solid end NEW
SOLD used left / USDM driver side blinker+cover no bulb
SOLD Q45 (1995-1996) front rotors, for S-chassis Q45 front brake swap. Used but in good shape with tons of life left
SOLD Z32 MAF kit NEW (silicone coupler plus aluminum joiner, goes 2.5" to 3" for fitting a Z32 MAF to your SR20DET turbo
SOLD 2" Carbon-style Air Intake + Ducting
SOLD Tomei Exhaust wrap NEW
SOLD SR20DET Redtop OEM Fuel Rail w/ OEM injectors, rail in good shape, injectors ran fine on my engine but the plastic on the injectors looks rough so I'd say they're iffy
SOLD Eparts License Plate Relocation Kit NEW
SOLD Stock Redtop T25 Turbo + some lines/hardware
SOLD ProSport Mechanical Boost Gauge 52mm
SOLD SR20DET Brake Master Cylinder Stopper RHD only NEW
SOLD S13 Manual Left/Right Mirrors manual style
SOLD Megan Brake Heat Shield NEW (LHD cars only - found that out the hard way LOL)
SOLD Double 52mm Gauge Adapter for Center S13 Vent ONLY TEST MOUNTED, never actually run
SOLD Walbro 255 Fuel Pump, pulled a few weeks ago to go to a bigger setup, worked fine when pulled
SOLD S14 front seatbelts, no receivers
SOLD Wink mirror, has hole drilled in it (see pic) but works fine. no additional hardware included
SOLD S13 Rear Ashtray USDM LHD
SOLD Innovate 52mm Mechanical Boost Gauge
SOLD 3" / 76mm Universal Catch Can Mount NEW
Smithwick is offline   Reply With Quote
Old 10-14-2018, 11:21 PM   #2
Cas240sx
Cas240sx is an unknown quantity at this point
PM sent...
Cas240sx is offline   Reply With Quote
Old 10-15-2018, 12:10 AM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
PM sent lemme know PayPal ready
S-Nation S13 is offline   Reply With Quote
Old 10-15-2018, 09:47 AM   #4
Smithwick
Ashtray and S14 seat belts sold.
Old 10-15-2018, 11:04 AM   #5
astonmartian
astonmartian is an unknown quantity at this point
I will take BMCS pm'd
astonmartian is offline   Reply With Quote
Old 10-15-2018, 11:15 AM   #6
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
How much for the catch can?
Old 10-15-2018, 11:36 AM   #7
Smithwick
How's $20 for the catch can? I'll add that to the main post too, good catch.
Old 10-15-2018, 11:50 AM   #8
Smithwick
Vent gauge pod, Walbro 255, and Prosport boost gauge SOLD
Old 10-15-2018, 12:32 PM   #9
RalliartRsX
Trader Rating: (32)
Sounds good.
Are those -10AN fittings? Know who makes it??
Old 10-15-2018, 12:36 PM   #10
Smithwick
Sounds good.
They are. Not sure who makes it.
Old 10-15-2018, 01:05 PM   #11
Smithwick
As requested, more pics of the carbon trim piece. The actual one for sale is still in the plastic wrap.
Old 10-15-2018, 02:51 PM   #12
Smithwick
Megan heat shield, Tomei exhaust wrap SOLD
Old 10-17-2018, 07:14 AM   #13
Smithwick
A few people have asked for more details on the mirrors - here is a better pic showing the mounting surfaces. I don't have any parts that aren't on them now, so it's a what-you-see-is-what-you-get situation. I feel that $20 is a reasonable ask for the condition that they're in.
Thanks for all the interest!
Item sold, pic removed.
Old 10-17-2018, 10:18 AM   #14
Smithwick
Mirrors are SOLD thanks
Old 10-17-2018, 09:13 PM   #15
Smithwick
Brake master cylinder stopper sold
Old 10-18-2018, 10:58 AM   #16
averyglass
averyglass's Avatar
averyglass is an unknown quantity at this point
Interested in that ecu!
averyglass is offline   Reply With Quote
Old 10-19-2018, 08:33 AM   #17
Smithwick
Still here shoot me a message with your address and we'll go from there.
Also, fuel rail + innovate boost gauge have been sold.
Old 10-21-2018, 03:29 PM   #18
Smithwick
Razo shift knob sold
Old 10-25-2018, 10:38 PM   #19
Smithwick
License plate relocation kit SOLD
Also, went through and cleaned up the post - got rid of images of stuff that's already been sold to this point so that it's easier to find what you're looking for and doesn't take 5 years to load. I'm also a little more open to offers now so that I can keep this stuff moving...
Old 10-27-2018, 02:02 AM   #20
Smithwick
Billion carbon duct + ducting sold
Couple new items added for Z32 / Q45 brake swaps on S13/S14
Old 10-27-2018, 07:51 PM   #21
nicoshiro79
nicoshiro79 is an unknown quantity at this point
interested in the z32 maf kit. PM sent!
nicoshiro79 is offline   Reply With Quote
Old 10-30-2018, 01:38 AM   #22
Smithwick
Z32 MAF kit SOLD
Old 11-08-2018, 07:55 PM   #23
Smithwick
Q45 rotors sold. Added Oil Filter Relocation kit for SR20DET, wound up going with a thermostatic setup instead
Old 11-19-2018, 12:39 AM   #24
Smithwick
Blinker is SOLD. A couple people have asked, so just to clarify - I'm keeping this list up-to-date, so anything that's still listed for sale is for sale
Thanks for helping me clear all this stuff out guys! I'm going to leave this on for another few weeks (maaaaaaaybe through the holidays, not sure yet) and then take to evilBay with the rest. Don't let that stuff go over there! Make some offers - willing to take the price down and/or help out with shipping if you're getting multiple items.
Old 11-19-2018, 03:23 PM   #25
Mike - E
Mike - E's Avatar
Trader Rating: (40)
Mike - E is an unknown quantity at this point
Feedback Score: 40 reviews
pm'd about reservoir sir!
IG: PICTUREMIKEYROLLIN
Mike - E is offline   Reply With Quote
Old 11-26-2018, 05:28 PM   #26
Smithwick
3" Intake piping sold, 5" Red Cone filter SOLD
2.5"-to-3" silicone coupler as well.
The whole list is Up To Date so feel free to shoot me offers. If you'd rather text, just ask for my number. Thanks!
Old 11-27-2018, 04:45 PM   #27
Smithwick
Omori gauges sold
Old 12-01-2018, 08:58 AM   #28
Smithwick
SR20DET Redtop ECU + MAF Sold
Old 12-07-2018, 02:48 PM   #29
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
PM sent...
mewantkouki is offline   Reply With Quote
Old 03-04-2019, 10:30 PM   #30
Smithwick
Chase Bays front brake lines for Z32 brakes are SOLD. Rear Chase Bays lines are still here and for sale
