Old 05-28-2018, 09:03 AM   #1
outfronts13
outfronts13 is an unknown quantity at this point
My first SR20
Well I purshased my first SR20 for my pos 240sx and off course the bolts are in bags so I dont know what bolt goes where that always fun. I wanted to know if the intake manifold uses studs or bolts that are 12mm
outfronts13 is offline   Reply With Quote
Old 05-28-2018, 10:23 AM   #2
SlmdCpe
SlmdCpe's Avatar
SlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enough
The Intake Manifold splits in two.
The main bolts for the top part are 2 12mm nuts, (2) 12mm 1” bolts and (1) 12mm long one in the middle.
Then you have some 12mm's that hold clips for wiring and what not.
SlmdCpe is offline   Reply With Quote
Old 05-28-2018, 10:30 AM   #3
outfronts13
The main bolts for the top part are 2 12mm nuts, (2) 12mm 1” bolts and(1) 12mm long one in the middle. 12mm as well.
Then you have some 12mm that hold clips for wiring and what not.
Thank you
Old 05-28-2018, 01:20 PM   #4
outfronts13
Second question, were can I get chain tensior studs from
Old 05-28-2018, 02:42 PM   #5
staying_chuki
staying_chuki's Avatar
staying_chuki is an unknown quantity at this point
My first SR20
It uses two 10mm bolts. Unless your trying to change it up for whatever reason
staying_chuki is offline   Reply With Quote
Old 05-28-2018, 05:13 PM   #6
outfronts13
Mine has studs and one is stripped🤷*♀️
Old 05-28-2018, 07:00 PM   #7
staying_chuki
My first SR20
We are both talking about this piece right? I have worked on like 3 sr20's and they all had bolts for it, they were also all half ass 240's that my friends owned so maybe they use studs.
Just go to an auto parts store nearby and they can match the thread pitch and size. If they only have studs that are longer just give em a lil cut with an angle grinder.
Old 05-29-2018, 06:42 PM   #8
outfronts13
I used a 10mm stud from my old Ka water pump which worked fine.
Old 05-29-2018, 06:44 PM   #9
outfronts13
I have one more question relating to the timing on the crank gear due you go with the large mark in the manufactured crank gear or the small dot? The person I bought engine from had it on the small dot.
Old 05-29-2018, 07:45 PM   #10
Kingtal0n
Kingtal0n's Avatar
what small dot? You mean cam timing?
To time the sr20, I never use the crank to line anything up. I don't think anybody does it that way actually. Its just "common knowledge" that you set the cam lobes facing outwards, and set the cam dots to roughly 10 and 12, you need to look this up Im just glazing it. Then simply count links between dots and its set.
We ignore the timing color links and especially the crankshaft dots or... whatever.
and its a running joke that "once every three summer solstice monsoon, the light shineth through the trees and thine 3 links shall be in harmony..." basically, its a holy symbol on an sr20 if the colorful links ever match the 3 positions simultaneously. It will make sense once you learn the motor.
Old 05-29-2018, 08:02 PM   #11
outfronts13
I have it lined up on the cams were does jt line up on the bottom crank
Old 05-29-2018, 08:09 PM   #12
outfronts13
Old 06-02-2018, 08:42 PM   #13
oLemurs
oLemurs's Avatar
oLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura about
hey well atleast you got bolts, i was missing half of the bolts for everything
oLemurs is offline   Reply With Quote
