01-24-2012, 05:17 PM | #1 |
FS 1991 Mazda Miata Greddy CARB Turbo kit HARDTOP, CLEAN TITLE *SOLD*
Up for sale is a 1991 Maza Miata with a Greddy CARB legal turbo kit on it. Car has ~169,XXX miles on it. Currently running about 10psi of boost dead reliably. ***CLEAN TITLE IN HAND***
Specs: Drivetrain: 169,XXX Miles on Chasis ~45,000 on Replaced 1.6 Motor / Transmission BRAND NEW CLUTCH, just had a FlyinMiata Happy meal installed (stage 1 clutch and new lightweight flywheel, about 1500 miles on it since install) Interior: Stock Interior Panasonic Deck and Speakers Harddog Single Diagonal Roll Bar Exterior: New Soft top with Plastic Window 1999-2002 Miata 5-spoke Wheels ( 15x6 +40) BRAND NEW! Yokohama S. Drive Tires (All 4) Poly Garage Vary Front Lip White OEM Mazda Hardtop Turbo: Greddy TD04-15g Turbo w/ Carb Sticker Greddy Manifold Greddy Oil Feed Recently had the Oil line re-tapped with new fittings and lines by Erik from RoadsterTuner AEM UEGO Wideband AutoMeter Boost Gauge Front Mount Intercooler with 2.5" Pipings (this was not part of the Greddy kit it was put in after the fact) Greddy Type-RS Blow Off Valve NXS Boost Controller 2.5 Inch Custom Exhaust all the way from Down pipe - 22" Muffler (No Cat) 22" Magnaflow muffler to muffle down the exhaust sound 440cc RC Engineering Injectors BMW TPS Sensor ECU: Megasquirt 1 Suspension: Raceland Coilovers with 400lbs Spring rates in front and 250lbs in rear LSD: 1.8 Torsen Limited Slip Differential (LSD) from a 94+ Miata MISC: New Spark Plugs Recent oil/fluid changes Major Maintenance done ~10k ago Just had the Tranny serviced when the clutch was replaced Switch inside of the car to control headlight motors ("Lazy-eyes") RoadsterTuner Poly Motor Mounts. New Alarm system (tilt and bash alert) with two controllers (3 keyes are included with start immobilizer). Also has a nifty Turbo Timer set-up wired in Also included with sale are misc parts to put the car back to stock. Injectors, stock ECU, various interior body panels and others as well. I am asking $SOLD!!!!!. I can take more pictures of specific things, just let me know what you want to see! Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Last edited by lc_socal; 03-13-2012 at 08:04 PM.. Reason: Super low price! |
01-24-2012, 08:42 PM | #3 |
With the current cat less system, Smog will be an issue. The turbo kit does have the CARB certification sticker, but since some modifications have been made after the kit Smog in cali will require a friend or stock parts. ***I am willing to help arrange the smoging of the car***
01-25-2012, 09:05 AM | #5 |
01-26-2012, 11:12 AM | #7 |
Only problem with those sites it that the get political with who you have had work on your car. So some people will shit in the thread since EriK at Roadster Tuner worked on it Some of the roadster people are loons
02-05-2012, 01:57 PM | #18 |
02-19-2012, 07:56 PM | #21 |
03-09-2012, 01:37 PM | #26 | |
NO REASONABLE OFFER REFUSED! |
autocross, drift, greddy, miata, track |
