Old 09-09-2018, 06:04 AM   #1
a13x.
a13x.'s Avatar
a13x. is an unknown quantity at this point
180SX - S14 tranny = same? Strange noises after swap
Hey guys,
I swapped out my worn 5gear tranny on my 1996 180SX (SR20DET) and replaced it with a S14 SR20DET transmisson.
They look basically the same and should be pnp am I right? Now I've got a weird noise when I engage the clutch. I thought the release bearing is fucked, so I ordered a new S14 release bearing and put that in. I noticed that the S14 bearing is slightly thinner than S13 SR.
Unfortunately nothing has changed. The noise only comes when engage the clutch. I can put in gears etc.
Any suggestions?
Thanks !
https://www.youtube.com/watch?v=TgoFbLZ8scM#
a13x. is offline   Reply With Quote
Old 09-13-2018, 10:19 AM   #2
gaz_moose
gaz_moose is an unknown quantity at this point
is the release bearing riding on the clutch 'fingers' all the time?
looks like a lot of wear on them in your picture? you should have a gap/ free play between the bearing and the pressure plate.
there are different length release bearing carriers.
gaz_moose is offline   Reply With Quote
Old 09-19-2018, 08:33 AM   #3
Datsun freak
Datsun freak is an unknown quantity at this point
The clutch has not been properly aligned or missing a pilot bushing in the engine
Datsun freak is offline   Reply With Quote
Old 09-19-2018, 03:29 PM   #4
a13x.
a13x.'s Avatar
We swapped another gearbox in and its fine now.
