08-19-2018, 01:18 AM | #1 |
1996 OBDII Auto to Manual Swap - ECU Question
I am currently parting together everything for an auto to manual swap on my receny aquired 1996 S14. I’m aiming to keep this car on the street and legal so I had a question regarding the required ECU that I should be sourcing. I’ve done plenty of S13 auto/manual swaps (while keeping the auto ECU and vice versus), but I’m a little concerned with the 96’ OBD2 system and I’m trying to avoid throwing any CELs. Let’s get to my question...
While doing my research, I noticed that there are multiple 1996 240sx MT ECU part numbers/ECU codes. How can identify which unit I need to avoid any codes? My car is a 1996 S14 S/E w/ ABS and VLSD. I actually received the window sticker from the original owner and it had pretty much all the available add-on options. Please review the below chart and let me know if I can use any 96’ MT ECU part number or does the SE trim and/or ABS factor require a specific unit (I understand that the ABS system has its own control module, but I’m not sure if that would effect the engine ECU)? I plan on removing the ABS system in the near future, but I want to avoid CELs at all cost (before I’m required to pull cluster bulbs). If I can’t find any help here, maybe I could call Nissan and explain my story, but hopefully someone has experience in these situations. Thank you in advance!!
P.A.T.T. Last edited by duballstar37; 08-19-2018 at 02:35 PM.. |
08-19-2018, 02:48 PM | #3 | |
PS. It was not my intention to start a ABS vs. non-ABS debate. Again, to each their own. End topic. Back on topic... So you are saying that all 96’ MT ECUs share the same wiring pinout and I don’t need to worry about the different variations? Are there any differences between the various 96’ MT ECU parts numbers? Thanks again for your help!!
P.A.T.T. |
08-19-2018, 05:00 PM | #4 |
AFC #1
Any of them should work. There was even a 2371M-72F05RE that came out to replace them all. Do you have working AC?
A18-E27 G49 (07/95 - 12/95) A18-E27 G46 (12/95 - 02/96) A18-E27 G76 (02/96 - 07/96) A18-J29 GB3
08-19-2018, 09:10 PM | #6 | |
A18-E27 G46 (12/95 - 02/96) would be the factory manual computer, but it sounds like any of the above will suffice. Yes, my air conditioning is fully functional and I’d prefer to keep it that way. Why do you ask?
P.A.T.T. |
08-19-2018, 09:11 PM | #7 |
AFC #1
If your AC doesn't work you got the wrong ECU(Usually a 1995). Pin swap is possible but, you want OBDII.
08-19-2018, 09:36 PM | #8 | |
Thanks again for the quality information!
P.A.T.T. |
08-25-2018, 07:40 PM | #9 | |
I ended up purchasing A18-E27 G46 (12/95 - 02/96), but as previously stated... any OBDII manual computer should suffice.
P.A.T.T. |
