Old 09-18-2018, 11:00 AM   #1
xtahoex
xtahoex is an unknown quantity at this point
Fuel Pressure issue related to stalling?
Hi everyone... Did some searching and could find anything definitive, so here it goes.
I have a Datsun with S15 SR20DET swapped. The ECU was tuned by Enthalpy and I have been working with them to solve this issue. But, I might be at a stalemate right now.
The issue I am having is the car is stalling on deceleration. Enthalpy has told me that my fuel pressure should never dip below 45 psi, under deceleration I am at 40 psi.
I am using a stock FPR. With vacuum disconnected it jumps to 51 psi, with vacuum connect it sit at 45 psi at idle. At 9lbs of boost I show 60 psi of fuel.
Bottom line Enthalpy tells me that fuel pressure should be set at 45 psi with the vacuum disconnected.
Could any of this be related to my stalling issues?
Thanks
xtahoex is offline   Reply With Quote
Old 09-18-2018, 01:19 PM   #2
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
There's a vac leak somewhere, built a vac leak tester. It's PITA to track down, but that what it sound like to me.
also,
See if you can test with known good FPR.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 09-18-2018, 09:12 PM   #3
xtahoex
I guess I should have added that I have done the following trying to chase down the problem...
New coolant temperature sensor
Verified that the Z32 MAF and TPS were within spec and that TPS was adjusted
Cleaned and adjusted IACV
Lengthened intake tube in between MAF and Turbo
New fuel pump and added Prosport electronic fuel pressure gauge
Completed boost and vacuum leak tests and repaired several leaks
Thats why I am down to either an issue with the FPR or a tuning issue? Can anyone think of anything else?
The car starts and idles like a champ, it accelerates good, it's only on deceleration with the clutch in is when fuel pressure drops to 40 PSI and the car stalls out.
Can anyone verify what their fuel pressure is in a similar situation under deceleration with clutch in?
Ryan
Old 09-19-2018, 08:27 AM   #4
Datsun freak
Datsun freak is an unknown quantity at this point
Bad blow off Valve unless you’re not running one now
Datsun freak is offline   Reply With Quote
Old 09-19-2018, 08:54 AM   #5
xtahoex
I removed the too. Running no BOV right now.
Old 09-19-2018, 09:01 AM   #6
Datsun freak
Now that I remember I had similar issue with my Jim wolf ecu , I was able to get rid of the stall at decel by changing settings in my safc , cant recall what settings I had to play with I just went off What I got from searching safc tuning , safc has air deceleration setting you can adjust to compensate enough to keep her in under decel
http://forums.nicoclub.com/afc-air-d...p-t312068.html
Old 09-19-2018, 09:06 AM   #7
Datsun freak
Old 09-19-2018, 09:30 AM   #8
5280VertDET
Which ECU do you have?
Old 09-19-2018, 11:15 AM   #9
xtahoex
Stock S15 ECU tuned by Enthalpy.
Old 09-19-2018, 11:30 AM   #10
Datsun freak
Get an afc and adjust air decrease settings
Search safc air deceleration settings on google
Old 09-19-2018, 11:48 AM   #11
5280VertDET
Yea, thanks, I mean what is the code of the ECU?
If it's an auto ECU deceleration is different.
Old 09-19-2018, 11:54 AM   #12
xtahoex
It's a 6 speed ECU... I don't have the code for it right now.
Enthalpy is going to send me a new ROM. Hopefully they can make the adjustments to the tables because I don't want to run piggyback.
Old 09-19-2018, 12:37 PM   #13
Datsun freak
How long has the tune turn around been from enthalpy? I might have to get one sounds like you get pretty fast turn around
Old 09-19-2018, 01:19 PM   #14
xtahoex
The turn around was good. About a week and I live in California and they are in Florida. I decided on enthalpy vs a piggyback and although there have been a few issues (most of them are on my end) Martin has been very helpful and is reachable by phone or email.
Are you currently driving in a Datsun? If so, what type?
Old 09-19-2018, 01:28 PM   #15
Datsun freak
I’m running a 67 1600 with a KAT setup , I’m on a Jim wolf ecu now but have been waiting about 3 weeks for them to send me back my distributor for a reclock .
I’m looking for other ways to get it done now I have a feeling something is wrong . I went on the enthalpy site I’ll give him a call and get a tune from him.
I bet if I order a tune today it’ll get here before Jim wolfs reclocked distributor does .
Old 09-20-2018, 12:54 PM   #16
xtahoex
Very cool. I'm running a 71 Datsun 1200 Sedan with a 510 independent rear swap.
Old 09-20-2018, 04:28 PM   #17
Kingtal0n
Kingtal0n's Avatar
1. pressure test
2. Run a Recirculated Bypass
fixed
gota watch the wideband to see where it goes when you lift for diagnosis. Chances are that air is moving backwards through the compressor and interfering with the maf signal.
It isn't common on sr20 because the manual trans ecu have a fuel cut when TPS goes to 0%. So maybe your tps is not adjusted correctly for this.
Like someone said, SAFC has a minimum decel air function that people can use on MAF cars to limit max airflow during low throttle percentage%.
The question is, is this the cause of your symptom, and why. It could be plumbing related, turbo related, (maf tube) etc... Or it could be something else of course we can't see from here.That is why wideband diag is necessary.
