Old 01-02-2010, 07:38 PM   #121
AE_Racer
AE_Racer is an unknown quantity at this point
looks like they only make 30mm fenders, from that company
Car and truck body kits & parts for mx3, s10, SUV, civic, neon, focus, etc.
http://tougestars.net
AE_Racer is offline   Reply With Quote
Old 01-02-2010, 07:46 PM   #122
TonyToniTuna
TonyToniTuna's Avatar
TonyToniTuna is an unknown quantity at this point
Recently hit a curb in my S13....bent my LCA to hell...replaced the LCA...and the hub was still tilted in positive camber....messed around with the UCA and put the car back on the ground...and the tire still leans out just a bit with some positive camber...did i possibly bend something else? UCA? Spindle? any suggestions? i was thinking about getting an alignment...but i dont want to spend money when something else could be bent...
TonyToniTuna is offline   Reply With Quote
Old 01-02-2010, 07:50 PM   #123
AE_Racer
check your subframe for tweaks. might not be enough to see with the naked eye though...i assume you already checked your hub/knuckle?
Old 01-02-2010, 07:55 PM   #124
TonyToniTuna
Yea i looked over the spindle/hub but didnt look bent...yea its a weird situation....*sigh*
Old 01-02-2010, 09:12 PM   #125
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Originally Posted by XnTroubleX View Post
So as far as what to buy, i just need to get a S13 DOHC gauge cluster?
I am not sure, it is a pretty common thing, you should be able to find it in a search on here.
bdubnyc - check your actual shock tower, if you bent the LCA that bad I wouldn't be surprised if your whole front frame rail was tweaked.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-02-2010, 09:23 PM   #126
TonyToniTuna
Front frame rail? this is the rear lower control arm...i guess i should peep at the subframe...idk if it would be easy to spot out a bend in it....this fucking sucks..
PS: Oh forgot to mention...the driver side is fine and the negative camber is still fine on the driver side ever since i lowered the car...its just the passenger side where i hit the curb that still has the slight positive camber from hitting the curb.
Old 01-02-2010, 11:27 PM   #127
95KA-Turbo
95KA-Turbo's Avatar
My bad, I didn't read your post right then.
Did you check out all of your arms? I'd check the camber arm itself, and check the areas the arms bolt to on the subframe. Compare to your side that didn't hit.
Instagram - SJKnoop
Old 01-03-2010, 05:27 AM   #128
lflkajfj12123
if it were me i'd compare all the arms on that side to the opposite side
check for any major differences, at the very minimum you can source all new stock arms as they aren't worth shit
Old 01-03-2010, 06:08 AM   #129
TonyToniTuna
Yea ive compared all the arms to the driver side and they all look fine...i plan on swapping out the upper control arm with another stock one sometime soon and see if that makes any difference.
Old 01-03-2010, 12:55 PM   #130
drftkng951
drftkng951's Avatar
drftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond repute
i have a small oil leak behind and around the t stat area of my KA, my suspicion is the upper timing cover. can anyone verify
drftkng951 is offline   Reply With Quote
Old 01-03-2010, 02:06 PM   #131
95KA-Turbo
95KA-Turbo's Avatar
Wipe it down, and check it out every day. It's kind of hard to diagnose that over the internet, haha.
Instagram - SJKnoop
Old 01-03-2010, 08:37 PM   #132
lflkajfj12123
or valve cover gasket
Old 01-03-2010, 09:50 PM   #133
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
Originally Posted by KoukiMonsta View Post
can anyone give me info, a video something about AN fittings (oil filter relocation) i cant get these things together!!
Yeah its all on my S13-S14 Intake Manifolds In-Depth & Emissions Removal DVD
JDS Performance is offline   Reply With Quote
Old 01-03-2010, 10:58 PM   #134
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
Originally Posted by DreamN View Post
Good idea for a thread.
Alright, I've got one that I simply just haven't gotten around to really looking into much.
Once in awhile when I switch the wipers on it simply gets stuck in the on position. Not the switch itself, as I'll put it in the off position and the wipers will still keep going.
It's not the switch as I've tried 3. To my knowledge I haven't messed with the wiring concerning the wipers.
Any ideas where I should be checking first to fix this small, but irritating issue.
Yo Jimbo had the same thing happen to me. I thought it was the switch and it wasnt. I checked the hardness that goes from underneath the driver side to the fender well and the wires that are for the windshield wipers were grounding to bare metal. I guess in my case I had just did the hardness tuck because of my car being low it had chewed up the hardness and didnt noticed they were exposed and just did the tuck. So i took the fender off again and check all the wires there and sure enough them wires were exposed and grounding.... fixed it, put everything back on and everything was back to normal.
Not saying this will fix it but hey give it a try
zylvia213 is offline   Reply With Quote
Old 01-03-2010, 11:07 PM   #135
zylvia213
zylvia213's Avatar
Trader Rating: (36)
Im not sure if this qualifies but it is a question.... Is there anyone on here from Socal that specialize in electrical? Im having an electrical issue (short) on my S13 and looking for someone that can help a brotha out.
Old 01-03-2010, 11:16 PM   #136
udon!
udon! is an unknown quantity at this point
Originally Posted by udon! View Post
can a title of a car become salvaged if the odometer does not work for a period of time?
anyone?
come on....
udon! is offline   Reply With Quote
Old 01-03-2010, 11:27 PM   #137
franklin93zx
franklin93zx is an unknown quantity at this point
^ Don't think so, just an electrical problem
franklin93zx is offline   Reply With Quote
Old 01-03-2010, 11:37 PM   #138
Agamemnon
Agamemnon's Avatar
I've never heard of anyone having their title salvaged due to an odo malfunction.
I think you're in the clear.
Old 01-03-2010, 11:45 PM   #139
lflkajfj12123
http://zilvia.net/f/members/gsxrjjordan.html
i believe he knows a good deal about electrical and wiring
Old 01-04-2010, 12:35 PM   #140
Xbroke_kidX
Xbroke_kidX's Avatar
Xbroke_kidX is making a name for him/her selfXbroke_kidX is making a name for him/her self
Send a message via AIM to Xbroke_kidX
I have a Vertex shift knob with nissan thread pitch, but I know have a toyota. Can I buy just a regular heli coil and take the old on out so it will work with my thread pitch?
Xbroke_kidX is offline   Reply With Quote
Old 01-04-2010, 03:47 PM   #141
XnTroubleX
XnTroubleX's Avatar
XnTroubleX is an unknown quantity at this point
Does it matter what kind of exhaust manifold gasket I use, does it depend on the manifold that Im using,
SR
Powerlab manifold
XnTroubleX is offline   Reply With Quote
Old 01-04-2010, 03:50 PM   #142
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
Will Q45 brake calipers and rotors clear my rims?
5x114.3 16x8 +14 Front
FS OEM RB25 PARTS
Smurf_240SX is offline   Reply With Quote
Old 01-04-2010, 04:29 PM   #143
xBtony
xBtony's Avatar
xBtony is an unknown quantity at this point
looking at my distributor on my s13 SOHC. should there be another wire comming off the lil tab? maybe a ground or something? idk
xBtony is offline   Reply With Quote
Old 01-04-2010, 04:38 PM   #144
Dazzla
Dazzla is an unknown quantity at this point
edit nvm...
Dazzla is offline   Reply With Quote
Old 01-04-2010, 06:30 PM   #145
KoukiMonsta
KoukiMonsta's Avatar
ok guys so i took the intake mani of my redtop and in the lower portion(connnected to TB) i found oil. like a decent amount. is this bad/normal? thanks
@UpshiftEngineering
Old 01-04-2010, 06:38 PM   #146
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
my friend wondered the same thing and grounded that tab. his car started fine but was running weird/abnormal. he took it off and his motor was running like it should. i also have a ka24e and that tab isn't hooked up to anything.
WheelsDirty
Old 01-04-2010, 07:21 PM   #147
twopointo
twopointo's Avatar
twopointo is an unknown quantity at this point
hey guys i just need a quick advice on how i should install the roof wing on my coupe. what kinda tape should i use or do i have to bolt it on or is there another method of installing it or any helpful advice will do
thanks guys
twopointo is offline   Reply With Quote
Old 01-04-2010, 07:40 PM   #148
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
3m double sided tape.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 01-04-2010, 07:47 PM   #149
titopr06
titopr06's Avatar
Trader Rating: (68)
titopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nice
Feedback Score: 68 reviews
my question
I have an hks top feed fuel rail
im looking for 660cc top feed injectors but all of which i have found have low impedance and sr20's use high impedance, how could i make these work? i read about dsm resistor from an eclipse but not sure about this.
titopr06 is offline   Reply With Quote
Old 01-04-2010, 08:22 PM   #150
kalypso123
(ノಠ益ಠ)ノ彡
Originally Posted by derek_s13 View Post
wikipedia leverage, specifically the word 'fulcrum' and the result if it's placement on a plane
I understand all of that, but this is more 'car' relevant >>
Originally Posted by rbsilvias13 View Post
Most wheels are made to run in the center of the hub so it doesnt put alot of stress on the bearing and when you change that with spacers or an offset wheel it puts more load/leverage on the bearings.
thank you, makes perfect sense that the bearing will wear away from the added leverage.
