Old 11-08-2016, 09:26 AM   #31
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
good amount of detail...
Old 11-08-2016, 02:25 PM   #32
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
Thanks,
aem ems mounted and cleaned up some wiring. Really need to paint the floor..
bought a 2.5 lb fire extinguisher, hopefully I won't use it.
Quick start up.
battery1882 is offline   Reply With Quote
Old 11-14-2016, 09:44 AM   #33
battery1882
Had the car dynoed at Natural Aspirations over the weekend.
Happy with the dyno result. especially the torque. (Please read below edit)
keep in mind that my car still has a cat so Chris had to pull a lot of timing out. There was too much back pressure.
Mounted a new camera mount I got from ebay lol. super cheap! Can't believe I was using more expensive one that did the worse job.. this one is sturdy.
Edit (4/11/2017) :
I've been battling high exhaust temp and I have opened my engine after running this tune for a few track days.
Bad news : piston edge melted from excessive temp.
Chris @ Natural Aspirations is a nice guy and he is willing to help, but I would not go back to him for another tune.
Last edited by battery1882; 07-06-2017 at 05:23 PM.. Reason: Do not recommend this tuner
Old 11-15-2016, 02:55 PM   #34
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
This pump gas?
Grenade180sx is offline   Reply With Quote
Old 11-17-2016, 12:16 PM   #35
battery1882
Originally Posted by Grenade180sx View Post
This pump gas?
Yes, CA 91 octane.
Old 11-25-2016, 08:43 AM   #36
Quail
Quail's Avatar
Quail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfectionQuail is close to perfection
Send a message via MSN to Quail
I like this build a lot. When are the regas going on?
Quail is offline   Reply With Quote
Old 12-01-2016, 02:55 PM   #37
battery1882
Thanks man.
Unfortunately, had to sell the regas to move up to 18" (going 275s square setup)
bought some wheels and tires. will post pics soon.
Anyone going to 12/3 SOW?
Old 12-01-2016, 04:32 PM   #38
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Disappoint .
Old 12-02-2016, 08:53 AM   #39
battery1882
Disappoint .
haha. me too. I really liked the regas
I think you sold me a set of rpf1s while back. OG
Old 12-05-2016, 04:39 PM   #40
battery1882
Update from SOW CCW event
This time I went with Nexen SUR4 because I've never tried them and heard many good things. They handled great and did not get greasy as quickly as the rs3s.
Arrived at the track and signed up for Nissan Challange.
http://www.youtube.com/watch?v=aDyVrzARztA
All of the work paid off and I had a problem-free day (almost) which is always nice.
Ended up beating my M3 time and also won the nissan challenge class 2.
I'm looking forward to next event! first I need to change my turbo gasket
Old 12-16-2016, 09:18 AM   #41
battery1882
Originally Posted by TheRealSy90 View Post
You'll love the S4 cams, best sr20 cams out there.
I like the safety wire method for the o2 housing. What did you do for the nuts for the turbo to manifold? Is it difficult to drill the bolts for the safety wire?
Originally Posted by battery1882 View Post
yeah I'm tuning the car this Friday so hopefully s4 will perform well.
I used stock nuts and locking plate on the turbo to manifold side. I've had a lot of problems in the past using aftermarket headers where those back out, but with stock manifold, it should be good.
To drill the bolts, you just hold the bolt tight and use drill press.
It's funny that I'm quoting myself.. Well the manifold to turbo bolts, as well as, turbo to elbow bolts all backed out a little (heard from exhaust leak). This was going to be a tough battle against the heat and vibration.
So I decided to have the flanges welded. I wasn't comfortable with welding cast iron to cast steel, so heliarc_hustler handled it!
Also changed out the junk gasket to nissan 4 ply from s14 SR.
Started on the over fenders. Will update once I'm done!
Old 12-16-2016, 09:35 AM   #42
TheRealSy90
TheRealSy90's Avatar
How did the bolts that were safety wired back out?
Such a good signature.
Old 12-16-2016, 09:45 AM   #43
battery1882
Safety wired bolts backed out tiny bit (verified by re-torquing) and obviously couldn't move from that point on.
Out of 5 bolts that are on the turbo to elbow, only 4 were safety wired, one that was not wired backed out good couple turns.
Old 12-16-2016, 11:02 AM   #44
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
why are the bolts popping out like that?
supersayianjim is offline   Reply With Quote
Old 12-16-2016, 11:15 AM   #45
TheRealSy90
I think you might be better off running studs with nuts instead of bolts.
Old 12-16-2016, 02:23 PM   #46
battery1882
Usually daily driving / wide open throttle for 10-20 seconds at a time doesn't really affect the bolt coming loose as much.
With this car, it's always boosting and staying at a higher temp. (around 1000-1500 degrees Fahrenheit and above 4000 rpm for 10-20 mins at a time) On top of that, I'm shaking the car left and right going through the turns. This puts a lot of stress on all of the turbo parts.
My turbo to manifold bolt loosening was actually caused by one of the broken tabs (oem locking tab) that hold the nut in place. I should have safety wired them looking back.
Thanks for the suggestion but I've welded the flanges now so it shouldn't come off. (hopefully) if it does, make sure to tell me "I told you so"
Old 12-16-2016, 03:36 PM   #47
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I'm about to have my turbo welded to my manifold... tired of this shit,.
Old 12-16-2016, 04:06 PM   #48
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
I've never gone through one of the turbo-to-manifold gaskets... I always use new hardware and put everything together off the car though. Usually putting a wrench on it and then hitting that with a hammer to lock it down @ 83 billion ft lbs does the trick.
pacotaco345 is offline   Reply With Quote
Old 12-16-2016, 04:47 PM   #49
tougefactory
tougefactory's Avatar
tougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to all
Good to see another fellow S-Chassis out there going against time! Great job so far, keep it up. Maybe one day I'll take the S14 Time attack car out there.
TF-WORKS
Performance Parts // Track Prep // Fabrication
**Follow us on Instagram @TFWorks
For all the latest TF★ news visit our blog!!
tougefactory is offline   Reply With Quote
Old 12-16-2016, 05:00 PM   #50
TheRealSy90
I got new Inconel studs with Stage8 locking nuts from Flyin' Miata, shit better work for $120 for four studs/nuts..
Old 12-19-2016, 09:13 AM   #51
battery1882
Do it!!!
haha pacotaco, keep in touch! it was nice meeting you.
TF-WORKS
cool man! thanks
Inconel studs!! how much were they? I'm sure they will hold fine.
Installed overs / cheap mirrors and painted them. It was my first time painting alone with a gun; and there are alot of overruns. I'm happy it's one color
Prepping for laguna seca on 26th.. I hope to make it out there..
Old 12-19-2016, 10:24 AM   #52
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
OHLINS!?! How do you like them? I'm really jealous, and i hope your event at Laguna Seca goes well!
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 12-19-2016, 10:25 AM   #53
TheRealSy90
It was $120 for the Inconel studs and Stage8 lock nuts from FlyinMiata. They don't sell the studs separately.
Old 12-20-2016, 08:37 AM   #54
battery1882
I like them alot! From my past experiences, set of good shocks always ride very well (comfortable) on the street and holds up when you are cornering hard. (given that it has adequate spring rates) Thank you!
Man that's some baller hardware. hope it goes well!
Did few things last night.
went to APR and picked up a gurney flap. Hope I can tell the difference.
Also rerouted my intake as I don't think pulling dirty air from the bottom is the smartest thing.
Old 12-20-2016, 09:44 AM   #55
koukimonst3r
koukimonst3r's Avatar
koukimonst3r is an unknown quantity at this point
Let me know how this works out! I was planning on welding my manifold to turbo as well lol
ig : koukimonst3r
koukimonst3r is offline   Reply With Quote
Old 01-03-2017, 09:09 AM   #56
battery1882
Didn't get to go to Laguna seca as the wheel bearing on my 4runner decided to give out..
It would have been nice but I guess there is always next time.
Fixed the wheel bearing and took it off roading. Lots of fun.
Locked the key one day and this happened lol
I wanted to block off unnecessary openings on the front bumper.
I used NACA duct to pull in cold air to the intake
Still need to build a shield around the filter.
some carbon plate and duct tape to cover off rest of the area
started with the splitter. Store that sells allumalite was closed so will be working on that soon.
Happy new year!
Old 01-03-2017, 10:37 AM   #57
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Who are you going through to get the alumilite?
Old 01-04-2017, 08:20 AM   #58
battery1882
I went to denco (http://www.dencosales.com/index.html) yesterday to buy some alumalite / aluminum composite panel but they didn't have anything thicker than 6mm. I am gonna search little more to look for it. worst case scenario, I'll buy plywood.
Old 01-04-2017, 12:24 PM   #59
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I'm following this thread. I need to make a splitter to protect my bumper not so much for performance.
Old 01-04-2017, 07:17 PM   #60
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
Hi, I just wanted to let you know im your new biggest fan. I could have warned you about the 4 turbo to manifold nuts being the #1 issue. After years of troubleshooting my only option was to safety wire, but when I had my turbo out last time I didnt even want to try to figure it out I decided I will just weld them together next time they come apart. I cant wait to see you at the next Nissan Challenge event. I saw your car up close at SOW but I had not seen your build thread til now. Woooo. I love 240 time attack builds done well.
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
