Old 11-25-2013, 08:06 PM   #1
stockonstock
stockonstock's Avatar
Trader Rating: (-1)
stockonstock is an unknown quantity at this point
Feedback Score: -1 reviews
s13 92 S13 Hatch Sr20det T28 2,900 OBO!
FS/FT: 1992 S13 CLEAN TITLE on hand. miles unknown on motor compression test was around 155 across when bought.
*Chassis
-173k og miles
-solid steering column bushing
-Almost new achilles tires, brakes are good, interior decent, pretty bone stock besides motor and fuel pump.
*SR20det
-Transmission and ECU
-T28bb s14 ( minimal shaft play blades look clean )
-Steel braided coolant feed/return line
-Steel braided oil feed line
-Steel braided brake booster line lol
-Ogura Racing Twin plate Clutch w/ light weight flywheel and throwout bearing
( g i joe kung foo grip!)
-AEM 320lph high flow fuel pump almost new
-Custom solid motor mounts
-Power Enterprise super v kevlar belts
-Greddy type R blow off valve
-Greddy rocker arm stoppers
-Greddy elbow w/ fatty o2 sensor bung & sensor
-All turbo, intake manifold, valve cover, oil pan, water pump, t stat gaskets and front main seal and Head gasket look freshly replaced.
-Powered by Max inlet CX Racing couplers & t clamps w/ Spectre air filter.
-Entire conversion harness. Your speedo, brake and reverse lights will work
-Interior dash plug
-Conversion heater core hoses
-And a sick ass custom painted valve cover.
*Cooling System(V-Mount)
-Koyorad radiator
-Radiator hoses are ghetto but seem to have worked just fine this past summer driving daily.
-Evo 9 intercooler
-Cold pipe was given to me with the set up. i made the hot pipe from CX Racing piping all couplers and t clamps also from CX Racing.
-Vacuum bung on coupler for waste gate
**Cons**
-Has small frame damage on front passenger side frame rail. Yes I hit a curb driving with a friend. I replaced lca, tie rod, tension rod bracket, and new adjustable tension rods so all you need is a little frame pulling maybe a bumper to make it look pretty again.
-Correct me if I'm wrong but transmission makes light grinding noise when clutch pedal pressed down, doesn't matter if in gear or not. To what I've read and understood its the release bearing. But still shift and drives perfects no slips or grinds from gearbox also running royal purple gear oil.
Overall very solid and reliable motor! Previous owner said he hot tanked head and block separately new gaskets rebuilt turbo blahh blahh blahh… But head gasket seems to be fairly new all gaskets look good like i said, there is NO LEAKS what so ever motor looked spotless after a quick spit shine. Does not blow white, black, blue smoke no bullshit. Runs very healthy gets about 25mpg pulls hard and spools amazing!
asking 2900$ OBO!!! WILL trade for a daily gas saver +$$$$ ( corolla, civc, sentra ext..) LOWBALLERS WELCOME!!! I need this gone asap to buy my parents a car so throw some offers!!
if you have any further questions txt or call. Rosario (951)213-1541
Located in Riverside CA IE
trail&error. 666.
stockonstock is offline   Reply With Quote
Old 11-26-2013, 12:11 PM   #2
stockonstock
Trader Rating: (-1)
dat young bump
trail&error. 666.
Old 11-26-2013, 05:09 PM   #3
culaphid
culaphid is an unknown quantity at this point
Does it run?
culaphid is offline   Reply With Quote
Old 11-26-2013, 06:05 PM   #4
Mardo
Mardo is an unknown quantity at this point
Originally Posted by culaphid View Post
Does it run?
I think that is a yes.
"...But still shift and drives perfects no slips or grinds from gearbox also running royal purple gear oil."
Mardo is offline   Reply With Quote
Old 11-26-2013, 10:39 PM   #5
stockonstock
Trader Rating: (-1)
Does it run?
yes it runs . you just can't drive because of frame damage
trail&error. 666.
Old 11-27-2013, 02:11 AM   #6
mudafka
mudafka's Avatar
mudafka is an unknown quantity at this point
cant drive it at all?
mudafka is offline   Reply With Quote
Old 11-27-2013, 11:07 AM   #7
stockonstock
Trader Rating: (-1)
you can burn out in my drive way but thats about it
trail&error. 666.
Old 11-27-2013, 10:18 PM   #8
mudafka
mudafka's Avatar
Sell me the motor set
Old 11-28-2013, 01:40 PM   #9
can24
can24's Avatar
can24 is an unknown quantity at this point
trade for 88 cressida
can24 is offline   Reply With Quote
Old 11-30-2013, 01:30 PM   #10
stockonstock
Trader Rating: (-1)
buuuummmmppp obo obo
trail&error. 666.
Old 11-30-2013, 01:37 PM   #11
240o'clock
240o'clock's Avatar
Trader Rating: (31)
240o'clock is an unknown quantity at this point
Feedback Score: 31 reviews
looks like a good price if everythings legit.... Free bump for you my friend
240o'clock is offline   Reply With Quote
Old 12-04-2013, 02:53 PM   #12
stockonstock
Trader Rating: (-1)
obo! runs perfect but can't hit the streets because of damage! your pretty much buying badass swap with a free chassis
trail&error. 666.
Old 12-05-2013, 12:44 PM   #13
stockonstock
Trader Rating: (-1)
bump need sold this week
trail&error. 666.
Old 12-05-2013, 01:29 PM   #14
milto0n
milto0n's Avatar
milto0n is an unknown quantity at this point
I don't know how this hasn't sold yet.
milto0n is offline   Reply With Quote
Old 12-05-2013, 04:00 PM   #15
stockonstock
Trader Rating: (-1)
thats what I'm thinking . maybe because its the holidays …
trail&error. 666.
Old 12-05-2013, 10:26 PM   #16
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
trade you for a 97 tacoma plus $1000 bucks on your end...??
Drift_FX is offline   Reply With Quote
Old 12-06-2013, 01:43 AM   #17
stockonstock
Trader Rating: (-1)
pm sent bro
trail&error. 666.
Old 12-06-2013, 08:44 PM   #18
240o'clock
240o'clock's Avatar
Trader Rating: (31)
damn how is this not sold yet!?!?!?!?
Old 12-08-2013, 04:55 PM   #19
stockonstock
Trader Rating: (-1)
bummmppp… need the cash obo
trail&error. 666.
clean, hatch, s13, sr20det, stock
