01-02-2014, 12:03 AM | #1 |
Help whp capability rb25 !
Hey here it is guys I'm sure you've heard it before. I have done my research and have seen similar threads about the same topic on RB25. But as always people get off topic or start flaming the page so for that being said I don't want any of that so keep rude comments to yourself. I'm asking because I'm unsure of safe power capability and would want advice from people who may have more knowledge/ or have attempted a stock internal high power number rb25 setup. I want to know if my motor can produce this power and keep reliability. I have s14 I'm dropping a rb25det s1 i picked up. My goal is to do 500rwhp reliability is key though this is my daily. I have rb25det with the following in engine:
Rb25det s1 Gasket where replace with oem gasket full kit from Nissan Stock internals beside cometic 1:2 head gasket And cometic exhaust manifold gasket as well as intake gasket ARP head studs Hks timing belt Nismo thermostat Rb26 valve cover with new gasket Isis intake manifold with q45 Have cxracing top mount manifold the new style 600$ one Hx35/hx40 hybrid turbo twin scroll 750cc injectors five0 Walbro 255 fuel pump Z32 ecu tune plan rs enthaply Martin V band 3 inch down pipe Z32 mas airflow 2.75 hks full exhaust Z32 transmission Completion stage 3 clutch Rawbrokerage intercoolerping And fmic from cxracing Hks bov Rawbrokerage radiator hose Extra stuff of my setup McKinney 700hp drive shaft McKinney mount And z32 shift bracket correction plate S14 LSD Greddy e01 boost controller Background on me on driving I daily very we'll had sr20det but sold due to higher horse power goals. Some back ground on motor a family member had owned it before me and was running it stock I purchased it. The car mainly sat in garge's was daily for about 4 months and was then only token out on weekends motor was supplied with royal purple when we got it running and do oil change as we should with royal purple . Then sold to me motor sat for a while was turned on every once and a while till I gather everything that was need for my swap. So would like to make as much power as possible but keeping safety in mind. Please help thanks for you time . TurboS14Kid Ps I'm new to starting threads. |
01-02-2014, 03:52 AM | #2 |
Man w/ CTSV & a Car Seat
All in the tune. If 500hp is your goal, honestly, I wouldnt get a retuned ECU. You're better off getting an aftermarket ECU (Power FC or AEM) and have somebody tune it for you. The only way an enthalpy rom tune is good for you would be if you get it dyno tuned by Martin himself.
01-02-2014, 11:30 AM | #3 |
Well I had a huge novel wrote out and it got erased so since I'm not retyping it here's the shortend version.
Rb25 cons: Pistons&rings only good for 350-400hp reliably Ecu is pure junk. Short oil drive snout. Fix those 3 problems and you can see 600hp reliably. I would get 3"+ exhaust if you want 500hp and a larger fuel pump. Now people have pushed a stock rb25 with larger turbo and supporting mods past 500hp. Yes it can be done but let me ask you this, how long is a piece of string? Sooner or later at those power levels something will give. You're only as strong as your weakest link. I'm swapping in the rb26 rotating assembly to fix my short oil snout and ringlands and plan for a reliable 500hp. Aem standalone to tune it. I could probably push 700hp no problems but at this point I don't think I need that power quite yet. If you have anymore questions just ask.
01-02-2014, 12:04 PM | #4 |
Fliprayzin240sx I under stand would like for it to get dyno tuned by Martin but that won't be possible cause I'm located far from him I have spoke to him was going to get a rom tune mailed he said I could achieve these number easily. And we talked about safety said it all depends in motor life of course. But said he's done 500+ whp with smaller injectors setup doing the power all day on stock internals as he has video posted but dynoed of course.
Smoked240 thanks for the information I was unaware about information on the rings Was think of a power fc but heard their not to great any thought on them? I have a oil crank collar extender just haven't put It in due to funds Thinking about aiming lower. Just try to stay safe |
01-02-2014, 04:21 PM | #5 |
I would recommend having it dyno tuned. Rb's are picky engines when you start building them and tuning is the most crucial(same with any engine)I've seen a lot of freshly built rb's blow because of poor tunes. I trailer mine 5 hours to have dyno tuned. It's worth it in the end.
I haven't dealt with the power FC personally but I've read good reviews. I opted for the aem v2 since it's pretty close to one of the best and has a lot of options.
01-03-2014, 02:02 PM | #6 | |
500whp, rawbrokerage, rb25det, s14, turbos14kid |
