Old 08-23-2018, 07:49 PM   #1
dev893
dev893 is a well-known jackass
4 lug brake upgrade
I have a 1990 240SX with an RB20DET that being said I am wanting to upgrade brakes while staying 4 lug, what is the best options for this using parts that can be found at parts stores, I have thought about using the ABS model brakes since they are .4" bigger than none ABS cars but is there a better option?
dev893 is offline   Reply With Quote
Old 08-23-2018, 08:01 PM   #2
apex
apex's Avatar
Trader Rating: (42)
apex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond repute
Feedback Score: 42 reviews
The best option is the search button
Plenty of adaptors for bigger calipers n redirlled rotors around
Here just need to find them
"Illicit Performance "your one-stop speed shop"
apex is offline   Reply With Quote
Old 08-23-2018, 08:02 PM   #3
afishysilvia
V-H8
afishysilvia's Avatar
afishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant futureafishysilvia has a brilliant future
You can stay 4 lug and upgrade to the Z32 calipers running bigger BMC, New lines, and Redrilled rotors.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 08-24-2018, 10:48 AM   #4
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Q45, redrill the disks. Cheap and effective.
S13 Vert | SR | 5-Speed | "OEM+" | PE1420 |
5280VertDET is offline   Reply With Quote
Old 08-24-2018, 11:48 AM   #5
Jefro240
Jefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enough
Z32 26mm Caliper with Altima 22mm Rotor. 4mm difference is small enough to be taken up by the pads/pistons. No re-drilling.
Or Maxima Calipers & Altima Rotors "the 180sx setup". No re-drilling.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 |
Jefro240 is offline   Reply With Quote
Old 08-26-2018, 10:42 AM   #6
dev893
dont the Z32 calipers require a bracket and special lines? what year altima and maximas
Old 08-28-2018, 01:22 PM   #7
Jefro240
Z32 will require conversion flex lines etc. No bracket.
180sx setup is 01 Altma SE-R Rotors & 89-99 Maxima Calipers.
Old 08-28-2018, 06:28 PM   #8
TheRealSy90
TheRealSy90's Avatar
TheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud ofTheRealSy90 has much to be proud of
Z32 brakes is bolt on and can drill the rotors for 4 lug easily in your garage.
Q45 is bolt on and can use S14 4-lug rotors.
Sentra SER Brembos are bolt on and 4 lug.
Such a good signature.
Old 08-28-2018, 06:54 PM   #9
smoked240
smoked240 is making a name for him/her selfsmoked240 is making a name for him/her self
Send a message via MSN to smoked240
I have front z32s on my 4 lug, not quite sure on rotors. I will double check on that, I know they weren't drilled so its either stock s13 or s14 4-lug. my stock s13 brake lines work with them.
Stay with your stock BMC unless you want to change the feel of your brake pedal.
smoked240 is offline   Reply With Quote
Old 08-29-2018, 06:13 PM   #10
TheRealSy90
The stock s13 brake hoses do not work with z32 calipers. Neither do the stock rotors. You either have the appropriate lines and rotors or you don't have z32 calipers.
Many people feel the stock BMC with Z32 calipers results in a spongy brake pedal, some don't mind it.
Old 08-29-2018, 10:00 PM   #11
smoked240
I replaced my brake line with an s13 and it fit...I know for a fact I have z32 calipers. EDIT(Unless Q45s look identical to z32s, that I am not sure on)
Old 08-30-2018, 10:03 AM   #12
5280VertDET
Completely different design.
Q45:
Z32:
Old 08-30-2018, 12:28 PM   #13
TheRealSy90
Then your car probably has Q45 calipers, not Z32.
Old 08-30-2018, 06:02 PM   #14
silverarrow27
silverarrow27 is making his/her stupidity well-knownsilverarrow27 is making his/her stupidity well-knownsilverarrow27 is making his/her stupidity well-knownsilverarrow27 is making his/her stupidity well-known
Q45 calipers w/ Fastbrakes 4 lug rotors...
It's been several years since I bought rotors from fastbrakes.com, but they use to sell a direct bolt-on 12" 4 lug rotor upgrade to go with the Q45 brake upgrades for s13s. Inquire about their front rotors because I don't think I saw it available on their site anymore.
2013 Veloster Turbo Base|2007 Versa SL|1989 240sx XE
silverarrow27 is offline   Reply With Quote
Old 08-30-2018, 11:38 PM   #15
smoked240
Nope, I checked last night and they are Z32's. 5280vertDET confirmed with pictures. Been almost 9 years since I've had to touch my brakes and after checking it over I have hardlines in the front lol.
Like pissing into the wind, It's all coming back to me lol. I had to order the s13 line so I just got a bend-to-spec hard line when my tension rod snapped 7ish years ago just to get home.
I stand corrected!
Old 09-05-2018, 11:31 PM   #16
dev893
is there an upgrade option for the rear that allows you to keep the same style parking brake?
Old 09-09-2018, 02:37 AM   #17
TheRealSy90
Wilwood. Look up the kits on Arizona Z Car.
Old 09-10-2018, 03:15 PM   #18
dev893
I've looked at those just cant afford a grand on brakes right now
Old 09-11-2018, 09:31 AM   #19
jedi03
I would suggest q45 and redrill some rotors then! autozone usually has good prices!
Old 09-11-2018, 03:20 PM   #20
apex
apex's Avatar
Trader Rating: (42)
the best bang for the buck are brakes from an infin j30
Same calipers as q45 just smaller better wheel options
Uses same s13 brake booster, bmc, and lines
Just drill them to four lug
Old 09-11-2018, 03:51 PM   #21
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (72)
Feedback Score: 72 reviews
It's 2018 and we're seriously unable to find 4 lug brake upgrades? You def did not search.
Old 09-13-2018, 12:22 AM   #22
dev893
should've been clear that I was looking for best bang for the buck upgrade like junkyard hunting
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
