04-21-2014, 03:07 PM | #1 |
s14 ls1 wire harness help!
okay so iv been doing some research online and cant find my answers. So im doing a ls1 swap in my 95 zenki s14 and im looking for a ls1 harness that has connectors for the fuse box and the wind shield wipers but i found this harness http://www.wiringspecialties.com/wsprls1ins14.html and it doesnt have a ecu for it and so my question is what ecu do you use? Next this wiring harness has an option for 5 peed swap and i have a t56 so obviously thus harness wouldnt work right? And so i was looking and i seen this wiring harness http://currentperformance.com/LS2.html. i dont think this has a s14 fuse box connectors and or windshield wiper connector so can anyone tell me what they did and what wire harness did they use? i have a 5.3l ls motor, can only put ls1 ls2 and ls6 parts on it.
04-21-2014, 03:49 PM | #2 | |
Trader Rating: (29)
Feedback Score: 29 reviews
I have just recently ordered this harness my self. The wiring harness is plug and play with your chassis and any compatible LSx ECU, such as the ones listed on the page where you select options before ordering. I too have a 95 S14 that was originally automatic and has been converted to 5 speed. I selected: No ABS, because my car doesn't have it Chassis year, 95-96 F-Body Engine, because of the AEM ECU I am using T56 only, as I will not be using an automatic Auto to manual, as my chassis was converted to manual No A/C, cause I like to sweat No HPTuners, because I am running AEM The harness covers everything in the swap and includes the charge harness and interface at the chassis connector for Cluster operation, fuel pump control, etc. If you have questions/concerns they are generally quite helpful on the phone. Last edited by NISR20MO; 04-21-2014 at 03:52 PM.. Reason: Add more info |
04-21-2014, 03:52 PM | #3 | |
04-21-2014, 04:02 PM | #4 | |
Trader Rating: (29)
The ECU I have is a standalone by AEM that directly replaces the stock factory ECU/PCM. I am building a L33 5.3 truck motor. I suggest you look at silviav8forums.com and ls1tech.com and even performancetrucks.com for some helpful info about the motors. And also to get a good understanding of what is involved in the swap. Last edited by NISR20MO; 04-21-2014 at 04:02 PM.. Reason: kant focking spell |
04-21-2014, 04:04 PM | #5 | |
