Old 02-01-2016, 08:26 PM   #31
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
What exactly is in this kit you're selling? The three ground cables in your picture?
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline
Old 02-02-2016, 04:13 PM   #32
dkim1985
dkim1985's Avatar
Trader Rating: (28)
dkim1985 is an unknown quantity at this point
Feedback Score: 28 reviews
Three ground cables and the negative battery connector.
FS: Nismo R-Tune Camshafts for VQ35DE.
dkim1985 is offline
Old 02-09-2016, 01:22 PM   #33
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Have a couple kits ready to ship!
Some info on quality of this kit
- Cables are oversized, top of the line, Oxygen Free Copper(OFC) cables
- Super flexible cables! Not like you typical stiff OEM cables. Easy to route.
- Uses Raychem heatshrink tubing. One of the best in the industry. great protection from high heat and many forms of liquids.
- Copper ring terminals with fitted ring sizes to match OEM bolt/mounting points.
- Red positive cables available upon special orders.
- Customization available! If you need a custom kit made for your unique setup, just send your required specs and we'll figure it out together!
dkim1985 is offline
Old 02-09-2016, 07:41 PM   #34
Konster
Konster's Avatar
Konster is an unknown quantity at this point
Bookmarked for later.
Hyer.
Konster is offline
Old 02-13-2016, 06:02 PM   #35
Konster
Konster's Avatar
I'll take a kit with a positive terminal.
Hyer.
Konster is offline
Old 02-15-2016, 05:47 PM   #36
dkim1985
dkim1985's Avatar
Trader Rating: (28)
PM'ed!
dkim1985 is offline
Old 03-06-2016, 01:22 PM   #37
toguedrifter
toguedrifter's Avatar
toguedrifter is an unknown quantity at this point
After purchasing this kit a while back for my S14 I finally got around to having it installed. It was successful and works great! The only thing is that I was unable to use the positive terminal and cable because of the additional factory connectors that feed off of the same cable that the S13 doesn't seem to have. Anyway, I recommend this grounding kit for a straight forward and clean setup!
toguedrifter is offline
Old 03-06-2016, 04:48 PM   #38
Konster
Konster's Avatar
Haven't got the chance to instal the kit yet, but everything looks quality. Quick shipping as well.
Would recommend.
Hyer.
Konster is offline
Old 03-07-2016, 04:53 PM   #39
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Would recommend.
Glad you guys like it!
The positive terminal does take some modifying the stock harness to make it work. You have to cut off the oem battery connector and crimp the ring terminal connector that I include with the positive battery connector. As for the additional factory connectors that usually mount to the side, you have a couple options you can take..
a) cut off the oem connectors and wire them directly with the main line and then crimp to the supplied ring terminal. or..
b) take the side factory connector adapter, drill the mounting hole 1 size larger, then just mount directly to the side of the new positive terminal connector. (that's what i did)
I've heard from another customer that did option b, they didn't have to drill the hole larger. the side bolt on the new positive terminal connector fit perfectly through the factory connector adapter. I guess Nissan made different sizes..
I did option b, will upload a better picture later.
I also use the covers the battery terminal connectors come with because that's a requirement on the track.
dkim1985 is offline
Old 03-07-2016, 07:07 PM   #40
toguedrifter
Awesome, Thank you!
Old 03-07-2016, 07:45 PM   #41
Rob's S14
Rob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfection
Send a message via AIM to Rob's S14
I'm confused...are modifications needed if you have an S14?
Looks very nice, but I want to be sure before I buy.
Rob's S14 is offline
Old 03-07-2016, 08:00 PM   #42
dkim1985
dkim1985's Avatar
Trader Rating: (28)
To replace the negative grounds? No. Simply remove the factory grounds and bolt this kit in place.
To use the matching positive battery terminal connector, yes. the OEM factory harness has a built-in battery terminal connector which will need to be cut off and you will need to crimp on a copper ring terminal that is supplied with the new positive terminal connector.
And if you notice, there's a couple lines that also connect to the positive terminal where the factory harness uses an adapter with connectors. And as stated in my previous post, you have a couple options...
This is the same for s13 and s14, and all factory unmodified harnesses on KA, SR's, CA, and RB's.
dkim1985 is offline
Old 03-08-2016, 01:12 PM   #43
CZAR
CZAR is an unknown quantity at this point
Ordered one of the kits and got it installed last night. Easy install on a SOHC. Cleaned up all the mounting spots and attached the wires. All of the rings were the correct size. I ordered the matching positive terminal also, just cut the old connector off, crimped the new one on, and then drilled out the accessory connector so the new mounting bolt would fit. Clean set up, easy install. Pictures attached. Thank you.
CZAR is offline
Old 03-08-2016, 01:21 PM   #44
dkim1985
dkim1985's Avatar
Trader Rating: (28)
ohhhhh~ so much awesome in one post~
dkim1985 is offline
Old 03-08-2016, 09:07 PM   #45
Rob's S14
looks great.
thanks for the info dkim.
Old 03-22-2016, 02:32 PM   #46
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Just a quick update..
I've been running time attack with a couple friends so been a little busy with track stuff.
Recently got in a new batch of cables and connectors so going to start pre-making some kits when I get a chance.
Here's some pictures of the first time attack event of our season if anybody wants to check it out.. mines the Cherry Red Pearl s13 hatch..
http://www.socalschassis.com/nissan-...eries-round-1/
We just finished round 2 last weekend, will post pictures when I get those in.
dkim1985 is offline
Old 04-04-2016, 01:05 PM   #47
adicarlo
adicarlo is an unknown quantity at this point
I just received the Engine and Trans cables and I can speak to the quality:
  • Wires are KnuKonceptz which have a 4.5 rating on Amazon with over 800 reviews.
  • Have a little extra length which is perfect for engine movement. Even though I'm running Drift Freaq mounts and my motor doesn't move at all lol
  • Have a light translucent black shielding that makes it a perfect dress up piece, better then the crappy stock ground cables.
  • Cheaper than any quality grounding cables you'll get off Amazon or your local store. Unless your looking to make 25 ft of these things which I was not. I already have enough extra of everything.
  • Ends appear to be crimped and covered in heat shrink. Terminals appear to be quality also as I can't find the standard made in china markers you get on autozone crap.
  • Also the terminals are perfectly sized for mounting. No generic 1 size fits all stuff you get online.
  • A true tailored product.
adicarlo is offline
Old 05-20-2016, 10:32 AM   #48
stricnynel0s
stricnynel0s is an unknown quantity at this point
anything for r chassis, or rb26 ?
stricnynel0s is offline
Old 05-20-2016, 10:39 AM   #49
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
looks nice man.
d_nice is offline
Old 05-20-2016, 03:32 PM   #50
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Not at the moment but if there's enough interest, I can do the research. If you can find atleast a handful of guys interested in purchasing, I'll get started.
Originally Posted by d_nice View Post
looks nice man.
Thanks!
dkim1985 is offline
Old 05-20-2016, 05:02 PM   #51
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
Bookmarking this
S14kouki805 is offline
Old 05-24-2016, 04:57 PM   #52
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Currently have 2 kits ready to ship!
dkim1985 is offline
Old 06-29-2016, 05:29 PM   #53
1Badhatch
1Badhatch is on a distinguished road
Originally Posted by 1slicktwo4oh View Post
Any chance of making battery relocation/grounding kits? I would be interested in one
+1 I would be very interested in a relocation kit if you ever made one make a option for in the trunk and behind the passanger seat option it out!!!
1Badhatch is offline
Old 07-06-2016, 01:23 PM   #54
dkim1985
dkim1985's Avatar
Trader Rating: (28)
currently researching this.
dkim1985 is offline
Old 07-22-2016, 08:50 AM   #55
tsdGrfx
tsdGrfx is an unknown quantity at this point
just ordered a kit I'm located in nor cal how long does it usually take?
tsdGrfx is offline
Old 07-22-2016, 03:04 PM   #56
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Your kit will be made tonight, shipped out priority tomorrow. You'll probably receive it Tuesday.
dkim1985 is offline
Old 09-28-2016, 05:48 PM   #57
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Going to be making a couple kits this weekend! Place your order on the website to be included.
dkim1985 is offline
Old 05-12-2017, 09:31 AM   #58
Nightstylejapan
Nightstylejapan's Avatar
Trader Rating: (22)
Nightstylejapan is an unknown quantity at this point
Feedback Score: 22 reviews
These still available?
WTB all the pivot shift knobs all thread pitch message me!!!!!!!!!!!!!!!!!
Nightstylejapan is offline
Old 05-16-2017, 01:16 PM   #59
dkim1985
dkim1985's Avatar
Trader Rating: (28)
Yes. PM me for your inquiry. I will be making more kits this week.
dkim1985 is offline
Old 11-21-2017, 10:05 PM   #60
1Badhatch
If I give u the lengths i need for my ground and power wires could you supply them?
electrical, grounding, kit
