01-18-2010, 08:54 AM | #331 |
Mode door motor is going bad. It is located under the dash on drivers side. often time the "linkage" can get stuck and it wont move. take a look at it have have someone change the "mode" (foot or face, or both) and see if it moves at all.
01-18-2010, 11:05 AM | #333 | |
@UpshiftEngineering |
01-18-2010, 07:32 PM | #336 | |
01-19-2010, 06:54 AM | #341 | |
Future Moderator
I would say yes that is pretty decent. To be sure check to see what other people are selling fenders.
01-19-2010, 11:44 PM | #343 |
95 s14 will 17x9.5 +12 clear the strut/spring
https://www.linkedin.com/in/hassanbakar |
01-20-2010, 08:21 AM | #349 | |
Future Moderator
After searching the googles, seems your best bet for that is to pony up and go to Nissan.
01-20-2010, 10:41 AM | #351 |
if not maybe take a look at it and find something similar at a lowes/homedepot. if you're really worried about it maybe use black silicone that comes in a squeezable tube. it bonds to metal and is flexible but its just a quick fix that might not last long just an idea
**CoUpe LOve** #3 |
01-20-2010, 10:57 AM | #352 |
its not only that. the drivers window is wopply cuz is doesnt have the molding.
I'm just gonna take it to the dealership and see whats up. I also have to do the front window redone or get it sealed properly lol. bad time of the month to rain in cali haha. I was driving home in my 240sx when it started pouring, fucking water started leaking through the front window -___-. its kewl tho. I still love her hehe. |
01-20-2010, 11:06 AM | #353 | |
The driver/passenger window slides up and down on two rails. one of the rails is motorized and the other just guides it up. The window has two metal plates that bolt onto the rails. and the rails are bolted to the door.in the picture below you can see the two plates that secure the window that are next to the railings. one is at the top left and the other is next to one of the gears. if you say its wobbly then it may be loose and as for your windshield i got mine installed at a junkyard and the molding later crapped on me so i used the black silicone from a squeezable tube and it bonded well enough for rain not get in.
**CoUpe LOve** #3 |
01-20-2010, 11:34 AM | #356 |
yessssir you know how?
oh and before doing this either make your window go all the way down to reach the bolts , or if you want to pull off whole assembly for inspection (i would recommend if you got some spare time)then leave it all the way up take off door panel by unsrewing your door handle, gently pry off switches/control panel and take off harness, pry off door lever, pry off the tabs that cover the screws on the door panel and everything else i can't remember take off door panel, once it is off you'll notice a protective film, peel that off the window sits on two rails (one which is powered to move the window up and down) ------if you want to pull the whole window assembly take off the metal trim outside of door on top of door where the window is that can be removed by taken off a screw or two i believe and prying that off as well to give you a good clearance for what comes next unbolt the two rails and basically have someone help you wiggle/pull it out and watch for the window's round metal stoppers then set it somewhere clean (i.e. cardboard) as there is grease along side the rails and you can reset the height of the window for your needs and just work in reverse order afterward
**CoUpe LOve** #3 |
01-20-2010, 11:36 AM | #357 |
kinda, saw a instruction on how to do it on nico haha.
but I'm not sure which plates to tighten. can u circle it in the pic, that would be really great. but thanks for the help so far. |
01-20-2010, 11:37 AM | #358 |
small question: do all gauge sensors/senders have the same threading? IE for my greddy oil pan, can i buy defi, stri, greddy, blitz gauges and have them all work the same without needing adapters?
01-20-2010, 11:46 AM | #359 | |
if you dont know how we can roll to jedis13 house to pull it off quick (he's done it countless times) and see how it reacts when you use your climate control i've got nothing to do today haha
**CoUpe LOve** #3 |
01-20-2010, 12:10 PM | #360 | |
i took out my climate control already is there anything i should look for? or do i have to pull the dash out
J.SUN |
