Old 08-28-2018, 04:05 AM   #1
VStarNinja
VStarNinja is an unknown quantity at this point
Sr20det help, crank but wont start
Chao all, new to the forum, anyway i got abit of an problem starting my car and hope you guys could help, it use to start and run fine befor i went on holidays, 16 months later now iam back home and trying to start her, it starts with starting fluid but doesnt idle, ive change spark plugs, fuel pump, check fuel injectors with noid lights, took the injectors and rails out and gave it a good clean with carby cleaner, flush the tank out and put new fuel in, the car cranks but wont start, pulled a spark plug out and its dry, checked the fuel line just after the fuel filter and can definitely see fuel coming out, maybe theres no fuel pressure???
Silvia s15
VStarNinja is offline   Reply With Quote
Old 08-28-2018, 06:27 AM   #2
gaz_moose
gaz_moose is an unknown quantity at this point
are your fuel lines on the right way?
gaz_moose is offline   Reply With Quote
Old 08-28-2018, 08:24 AM   #3
VStarNinja
Fuel line to injectors or at the fuel tank?
Old 08-29-2018, 03:02 PM   #4
jedi03
its easier to mess up the lines at the injectors than at the tank...but both? do you have fuel coming to the filter?
Old 08-30-2018, 01:35 AM   #5
VStarNinja
Yes theres fuel at the filter, Its definitely connected properly at the fuel rail side, i justed pulled the line out just after the fuel filter, there was pressure, it squirted abit of fuel out, started the motor and fuel is definitely coming out, i just switched the 2 clip on lines at the tank and still wont start
Iam gonna double check all the injectors with noid lights and see whats up
Ive got a 2nd s15 thats running perfect, i can grab stuff from there to test for faulty parts
Old 08-30-2018, 01:47 AM   #6
VStarNinja
Just quickly check injector lines noid lights and its flashing crank so there’s definitely power there, (only checked first 2 plugs)
Old 10-06-2018, 04:58 AM   #7
fitbmx180
fitbmx180 is an unknown quantity at this point
Did you test fuel injector flow? Could be clogged
fitbmx180 is offline   Reply With Quote
Old 10-29-2018, 11:42 AM   #8
240boosted
240boosted has a little shameless behavior in the past
might be clogged injectors make sure lines are correct at the tank happened to me
240boosted is offline   Reply With Quote
