Old 10-06-2010, 04:17 PM   #3001
fckillerbee
fckillerbee's Avatar
except your wheel moving around excessively and no way to explain it lol.
haha good one. lol
Old 10-06-2010, 08:56 PM   #3002
Carbon350z
Carbon350z is an unknown quantity at this point
what engine do i want sr or rb to just get 300 whp reliability and cheapest way?
Carbon350z is offline   Reply With Quote
Old 10-06-2010, 09:10 PM   #3003
slidewaysS15R
slidewaysS15R's Avatar
slidewaysS15R is an unknown quantity at this point
sr is going to be the cheapest way rb is going to be more expensive but give you more reliability IMO
my car burns gas and rubber thats a real hybrid
slidewaysS15R is offline   Reply With Quote
Old 10-06-2010, 09:57 PM   #3004
bnadeau73
bnadeau73's Avatar
bnadeau73 is an unknown quantity at this point
Get the SR
I went through the dilemma of gts-t vs. 180SX and the 180SX was less expensive to upgrade and provided what seemed like better hp and torque gains for like upgrades. You can definitely get 300 whp and 300ft-lb torque out of a stock-internal SR motor.
-Brandon
bnadeau73 is offline   Reply With Quote
Old 10-07-2010, 01:53 AM   #3005
enigmadsm
enigmadsm is an unknown quantity at this point
looked all over, not sure where to find the answer...
how many MM effectively does an 18x10.5 +15 sit farther out than an 18x9.5 +15? Is it as simple as 1/2" or ~13mm or is there a way to calculate this?
Trying to figure out what size spacer to run in the rear of my Kouki...18x9.5 +15...I'm thinking a 15mm spacer but i don't want ridiculous poke, just flush
enigmadsm is offline   Reply With Quote
Old 10-07-2010, 03:54 AM   #3006
brandn3w
brandn3w is an unknown quantity at this point
Great thread!
Should I buy this car and besides rust what else should I look for?
Car: 1991 Nissan 240SX
brandn3w is offline   Reply With Quote
Old 10-07-2010, 06:03 AM   #3007
gerbil is sik
gerbil is sik is an unknown quantity at this point
Originally Posted by Team DET View Post
thats where the stock oil catchcan hose hooks up to
yes they do same size
I can't find one..............
I think that's what caused my turbo to go bye bye.
gerbil is sik is offline   Reply With Quote
Old 10-07-2010, 06:07 AM   #3008
240sx123$
240sx123$ is an unknown quantity at this point
Depends on the tire size... 18x9.5 +15 will be basically flush with a 255 tire, if that helps. As far as just the wheel itself, you are correct- a 10.5 +15 will stick out 13mm or so farther than a 9.5 +15.
Im running 18x9.5 +22, no spacer, 255/40 tire with just a roll. I could probably get a 5mm slip on in there, but Im not looking for a super aggressive setup.
240sx123$ is offline   Reply With Quote
Old 10-07-2010, 07:49 AM   #3009
nathanong87
nathanong87's Avatar
I want a boost controller and i imagine boosting like...10-11psi? Do i need single or dual solenoid? does it matter?
use this app
http://www.1010tires.com/WheelOffsetCalculator.asp
natelife.tumblr.com
Old 10-07-2010, 08:32 AM   #3010
bnadeau73
bnadeau73's Avatar
When analyzing this one also needs to consider the amount of camber. I am running a 17X9 +35 offset with 3 degrees of camber and I had to roll the inner lip (till it was flush with the inside of the fender) otherwise I rubbed. But this is on a s13. Nevertheless a person should consider the camber that they want when calculating the clearance.
-Brandon
Old 10-07-2010, 01:09 PM   #3011
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
has anyone bought a full set of varrstoen 18x10.5 0 offset? if so, can you post fitment on a stock body s14? I don't mind rolling the fenders because I am trying not to go widebody.
what size tires? i was thinking of running 225/40 all around
instagram
1on1 is offline   Reply With Quote
Old 10-07-2010, 01:21 PM   #3012
Rancimo322
Rancimo322's Avatar
Rancimo322 is an unknown quantity at this point
hey i need help ! i switch my stock cluster for the jdm on my 90.s13 but i need to know witch wires to repin to make the od/spd and temp gauge work ? anything o help !!
Rancimo322 is offline   Reply With Quote
Old 10-07-2010, 01:23 PM   #3013
nathanong87
only person i know of that has bought the 18x10.5+0 is a friend with a r32 skyline =\
but i'm at 10.5J+14 so, u can CERTAINLY make up for the +14 mm through tire size and slight camber. Im using 235/40-18 fattyerals. if u used 225/40, u'd probably only need a 8-10mm more roll/pull, which is not too bad...
natelife.tumblr.com
Old 10-07-2010, 02:40 PM   #3014
1on1
1on1's Avatar
yea, i've seen yours and ob's roll/pull, not bad of a stance. I wonder if that size would clear z32 brakes.
instagram
Old 10-07-2010, 04:29 PM   #3015
Melo_speed
Melo_speed's Avatar
Melo_speed is an unknown quantity at this point
I want to get 17x9 +0 and 17x10 +0 and want to get over fenders but im not sure if what i have in mind is to much.
I want 30mm front 50mm back will it be to much for it or should i go less also a beefy tire is a must in the back.
What would be a good combo for the wheel sizes i want?
It will be my dd/track car and love the wide stance on it.
Someone help me out please.
s14 grip monster=2011-2012
Melo_speed is offline   Reply With Quote
Old 10-07-2010, 04:55 PM   #3016
Corbic
Corbic's Avatar
RB20DETs are garbage. Parts are also hard to come by and aftermarket is limited. Any initial savings ($1k vs $2k) is lost in the added cost to mount, wire and mod it.
Old 10-07-2010, 05:54 PM   #3017
Nelson_sndm
Nelson_sndm is an unknown quantity at this point
I been looking all over for s13 1989-90 passenger side fender localy and cant find none. what i wanted to know is if i use a 1991-93 fender would it fit decent without a front bumper? Or would it not even be worth it, and i should just wait til i find a 1989-90 fender?
Nelson_sndm is offline   Reply With Quote
Old 10-07-2010, 06:34 PM   #3018
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Is the bumper here at the bottom (the K's aero bumper) a true legit bumper or is it some wannabe knock off?
MyNismo.com - NISSAN JDM S13 Silvia Conversion
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 10-08-2010, 03:21 AM   #3019
enigmadsm
Would you happen to have any pics?? I'm looking at running 225/40 up front and 245/40 out back...I wouldn't object to different sizes or running 225 all around so that I can rotate them if need be.
-Brandon
excellent point i forgot to mention. I would be fine running ~2-3 deg neg camber out back...preferrebly as close to factory as i can up front
Old 10-08-2010, 07:12 AM   #3020
Corbic
Corbic's Avatar
Anyone one make Berber (coupe style) black carpet for the S13 hatch?
In fact anyone make the Berber style carpet for any cars?
Old 10-08-2010, 07:22 AM   #3021
Corbic
Corbic's Avatar
use this app
Wheel Offset Calculator
Make one from Parker fittings, ~$20, it will never break, leak or loose accuracy.
Old 10-08-2010, 07:42 AM   #3022
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
"genuine nissan" is nissan so I'd say it's not a knock off.
VNG704 is offline   Reply With Quote
Old 10-08-2010, 10:58 AM   #3023
axiomatik
axiomatik's Avatar
Most likely it is a genuine Nissan part, but I am willing to bet that it is not the Aero bumper. I was told 4 years ago that the Aero bumper was discontinued.
Old 10-08-2010, 12:02 PM   #3024
240sx123$
Car isnt very low, but I have plenty of clearance now that the fenders are rolled. 18x9.5 +22 all around, 235/40 up front, 255/35 rear.
The third picture is a 225/40 front. I thought it looked goofy, and after smashing one of my wheels on a pothole, I went to 235/40 and am much happier. The 225 looks AWESOME on a 9.5 wheel, but the car needed to be lower for it to look good. Super low, super aggressive stance was never my goal, and seeing as this is a daily driven street car, I care more about protecting my wheels than anything else.
Plus the ride is much better with the 235 fronts. It doesnt seem like a big difference (10mm), but theres a LOT more sidewall available now. And yes, I know.. None of my body panels match.
Edit.. the third picture is also a 255/40 rear, (first and second pics are a 255/35)
Old 10-08-2010, 12:56 PM   #3025
7evil
7evil's Avatar
7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough
Stupid question: i want to put the 17 inch rims on my S14. I would like to have 9/9.5 front and 10/10.5 on the rear, without have too much camber and roll the fender. What is the right ET? I want a FLUSH style, not HELLAFLUSH!
七転び八起き
7evil is offline   Reply With Quote
Old 10-08-2010, 12:57 PM   #3026
240sx123$
If you want flush, you will need to roll the fender.
Old 10-08-2010, 01:02 PM   #3027
7evil
7evil's Avatar
Ok but what about the ET ?
七転び八起き
Old 10-08-2010, 01:09 PM   #3028
240sx123$
There is no "right or wrong" ET.. Its one of several factors you need to consider when purchasing wheels. You could go with a very low offset for a more aggressive look, but that would limit your tire options. Or you could go with a more mild offset, so you have the option of running some more rubber under there. Until you understand WHAT offset is and how it works, any wheel buying will simply be guesswork. Check this guy out: Wheel Offset Calculator
Old 10-08-2010, 01:26 PM   #3029
7evil
7evil's Avatar
Thank you so much!
七転び八起き
Old 10-08-2010, 03:10 PM   #3030
fckillerbee
have you put the wheel on your car yet? just put it on, and if you want more poke, measure how much you want, and put that spacer on it. pretty simple.
different between two wheels with the same offset is half an inch. offset is measured by the mounting point compared to the middle of the rim. if the rim is an inch wider, that would leave half an inch on each side of the mounting point....if that at all makes sense...it does in my head....should be right.
