Old 04-04-2016, 01:25 PM   #1
brian2323
brian2323 is an unknown quantity at this point
s14 Illinois kouki 240sx S14 kouki with RB26
12065729_891860750848990_2744030617224422321_n.jpgPrice 21k obo
Pictures can be found at
http://s947.photobucket.com/user/tru...?sort=3&page=1
Stickers have been removed
Price is "or best offer" ALL offers are considered.
This is a perfectly working and ready to race machine, this is ideal for someone wanting to get into a racing/time attack series for pennies on the dollar.
The Car was built following the nasa rule book to run in HPDE, TT, and Global Time Attack unlimited rwd.
Cage is FD Legal as well, can easily be converted into drift car
Here are the specs:
Chassis:
1997 Nissan 240sx SE
Horsepower/Torque: It was detuned to 450 to run pump gas
old hp was
606rwhp @8000RPM 466rwtq @6446RPM @ 22psi (want more power? Just turn up the boost! We felt 600 was balanced)
Weight:
3030lbs With driver and Full Tank
Engine:
R32 rb26dett
Jun crank collar
Tomei oil restrictor
Tomei oil pan baffle
Greddy oil pump
Greddy clear timing belt cover
Greddy intake manifold
HKS 272 in/ex cams
HKS adjustible cam gears
HKS timing belt
HKS fuel rail
Wiseco 86.5mm pistons
Eagle H beam rods
Cometic head gasket
ACL Race rod bearings
ACL Race main bearings
ARP head studs
ARP main studs
Twin Garrett gt2871r-10's
TSI Ported OEM exhaust manifolds
TSI Ported ITB runners
TSI -3an SS braided turbo oil and water lines
TSI Divided OEM twin turbo pipe
TSI Ported and polished head
TSI Custom intake pipes
TSI -6an SS braided power steering lines and power steering cooler
TSI -10an SS braided oil filter relocation kit and oil cooler kit using
Greddy thermostatic filter relocator
ATI race crank damper and water pump pulley
Dual synapse blow off valves
Aem air filters
Mckinney Motorsports touge downpipe
Mckinney Motorsports fmic kit
NGK bkr7e spark plugs
Isis Performance blast pipe exhaust with 4" tips
FabWorks custom oil catch can
FabWorks -AN valve cover adaptors
Cooling:
Koyo aluminum radiator
Flex-a-lite 340 series dual electric pusher fans
Raw Brokerage radiator hoses
N1 OEM water pump
Nismo thermostat
NRG radiator diversion panel
DIF PWM fan controller
Fuel:
Injector Dynamics ID1000 injectors
walbro 385 fuel pump
Aeromotive FPR
Powerhouse Racing billet fuel hat
TSI fuel pump direct-wire relay kit
TSI -8an feed lines with inline fuel filter & -6an return lines
Drivetrain:
Rb25det transmission
Spec Super Twin clutch
Isis Performance Short shifter
Mckinney Motorsports engine and transmission mounts with solid isolators
Driveshaft Shop 4.5" aluminum "1000hp" driveshaft
S15 helical differential
Suspension:
Fortune Auto 510 Series coilovers with Swift Springs upgrade 12k front /10k rear
Fortune Auto tension rods
Fortune Auto ruca’s
Fortune Auto traction arms
Fortune Auto toe arms
Stance solid Subframe bushings
Stance solid Differential bushings
SPL Eccentric lockout kit
Sikky 32mm front sway bar
Oem rear sway bar
Brakes:
Z32 front calipers
Z32 rear calipers
Z32 rear e-brake assembly
R33 e-brake cables
Carbotech xp20 front pads
Carbotech xp10 rear pads
Powerslot rotors
Exterior:
Shine Auto front bumper
Shine Auto side skirts
Shine Auto rear valences
Shine Auto carbon fiber rear diffuser
OEM JDM s14 kouki rear bumper
OEM 180sx type-x turn signals
B-Magic 30mm front fenders widened even more
Origin type2 50mm rear over fenders
Seibon vented carbon fiber hood
Kognition chassis mount 72" wing
Euro spec oem kouki headlights
Sonar l.e.d. tail lights
Nagisa Auto GT front tow hook
TSI Custom Rear tow hook
Interior:
Sparco eve seat less then one year old
passenger is old junk seat
Nrg short hub
Nrg 2.5 quick release
Nardi 360mm deep corn steering wheel
Nismo Shift Knob
Battery relocation kit
Firecharger dual nozzle fire suppression system
Rjs racing harness
Rjs racing window net
Custom 8point D.O.M. rollcage with "Nascar" door bars
Electronics:
AEM v2 ems
Racepak iq3 digital dash with AEM interface
Dual AEM uego wideband gauges
AEM serial datastream gauge
Stri oil temperature gauge
Stri oil pressure gauge Stri water temperature gauge
Hotlap v2 laptimer
Wheels/Tires:
XXR 527 17x9.75 +25 wheels
Nitto nt01 275/40/17 tires
Project kics r40 neo chrome lug nuts
Project kics 10mm spacers all around
Nismo 60mm Extended Wheel Studs
brian2323 is offline   Reply With Quote
Old 04-04-2016, 01:28 PM   #2
brian2323
having trouble with pictures copy and paste the link i put in the body or pm me your email or phone number and i can send them
Old 04-21-2016, 12:15 AM   #3
brn2slid
brn2slid has made poor choicesbrn2slid has made poor choicesbrn2slid has made poor choicesbrn2slid has made poor choicesbrn2slid has made poor choicesbrn2slid has made poor choices
Where is the car located? Seen the shop is in El Paso, Texas, and many pictures of the car there.
brn2slid is offline   Reply With Quote
Old 04-21-2016, 12:17 AM   #4
brian2323
Car was previously a Texas car now located in Il.
Old 04-21-2016, 12:17 PM   #5
brn2slid
Did you buy it from the original builder/owner? What's new with it? Any updates on how it runs now vs how it did? Or could you post a current video of it starting and running? Interested but a little far to go look at all of this
Old 04-21-2016, 05:18 PM   #6
sleek6mt
sleek6mt is an unknown quantity at this point
Great build
sleek6mt is offline   Reply With Quote
Old 04-25-2016, 08:55 AM   #7
usrocket
usrocket is an unknown quantity at this point
If I had an S14, it would be this!
usrocket is offline   Reply With Quote
Old 04-26-2016, 08:32 AM   #8
2JZGTEILL
2JZGTEILL is an unknown quantity at this point
sorry didnt see a price, how much?
2JZGTEILL is offline   Reply With Quote
Old 04-26-2016, 10:25 AM   #9
EJ8 944
EJ8 944's Avatar
EJ8 944 is an unknown quantity at this point
^ are you high? It's literally the first line of the ad.
EJ8 944 is offline   Reply With Quote
Old 04-26-2016, 10:35 AM   #10
2JZGTEILL
Sorry bro it was early in the morning no coffee didn't see it. Lol
Old 04-26-2016, 10:53 AM   #11
christianos13
christianos13 is an unknown quantity at this point
Car is sick saw it when it was in EL PASO, as it was being built.
christianos13 is offline   Reply With Quote
Old 05-11-2016, 09:30 PM   #12
brian2323
Bump anyone interested
Old 05-11-2016, 09:52 PM   #13
MikeisNissan
MikeisNissan's Avatar
Why xxr doe
因果関係の流れ
MikeisNissan is offline   Reply With Quote
Old 07-06-2016, 06:20 PM   #14
Heflin_93
Heflin_93 is an unknown quantity at this point
interested in trading?
Heflin_93 is offline   Reply With Quote
Old 07-06-2016, 07:32 PM   #15
brian2323
Possibly,
What do you have to offer?
Old 07-30-2016, 07:07 AM   #16
ZeroZero
ZeroZero is an unknown quantity at this point
I have an Evo x final edition with some bolts ons in east pa
ZeroZero is offline   Reply With Quote
Old 07-30-2016, 07:17 AM   #17
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
Bump for a fellow IL'ian
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 07-30-2016, 01:13 PM   #18
brian2323
Zero zero
Pm'd
Old 08-12-2016, 07:38 PM   #19
Bkarpster
Bkarpster is an unknown quantity at this point
Still for sale?
Bkarpster is offline   Reply With Quote
Old 08-13-2016, 04:57 AM   #20
brian2323
Yes it is still forsale
Old 11-29-2016, 12:33 AM   #21
KenzieGreen
KenzieGreen is an unknown quantity at this point
Is it still for sale Brian?
KenzieGreen is offline   Reply With Quote
Old 11-29-2016, 09:19 AM   #22
Skrwylewy
Skrwylewy is an unknown quantity at this point
Trade off
I have a 2006 STI with 80k for trade
Skrwylewy is offline   Reply With Quote
Old 11-30-2016, 10:01 AM   #23
brian2323
Still for sale text me info about trade or to purchase to both of you guys. Number is (312) 806-9500
Old 11-30-2016, 10:45 PM   #24
Skrwylewy
Trade
I texted you details
Old 12-01-2016, 12:38 AM   #25
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
Dude very nice ride i love it. Only minor quick for ur own self benefit is saying anything conforms to something shity like FD is NOT a perk or benefit to the potential buyer
turboshoebox is offline   Reply With Quote
Old 01-18-2017, 08:46 PM   #26
brian2323
Bump
Still forsale
Old 01-19-2017, 01:54 AM   #27
Aflak4u
Aflak4u is an unknown quantity at this point
Nice build. Good luck with the sale man.
Aflak4u is offline   Reply With Quote
Old 01-21-2017, 11:12 PM   #28
patrick33l
patrick33l is an unknown quantity at this point
This thing is a monster on the track!!!!
patrick33l is offline   Reply With Quote
Old 02-14-2017, 01:09 PM   #29
brian2323
bump still forsale
Old 07-12-2017, 01:22 AM   #30
CandyRaid
CandyRaid is an unknown quantity at this point
This is a perfectly working steroids that can help gain muscle https://legalsteroids.best/ and without any side effects and ready to race machine, this is ideal for someone wanting to get into a racing/time attack series for pennies on the dollar.
Here are the specs:
Chassis:
bump still forsale
I am interested too, lemme know if its still available.
Thanks
CandyRaid is offline   Reply With Quote
240sx, kouki, racecar, rb26, track car
