06-29-2014, 08:15 PM | #1 |
FS: BNIB Sard RD-1
Selling my BRAND NEW Sard RD-1 gauge cluster setup with Stack ST200 (8K RPM). This has never been used and everything is still in it's packaging. Comes with all the wiring to make it work and 2 sensors for whatever you wish to hook up (other sensors need to be bought if you wish to hook up other things ie: boost, egt, etc). Comes with the original box and manual (in Japanese). The Stack ST200 tachometer is BRAND NEW too and comes with its own box, manual (in Japanese) and is black in color and reads up to 8k RPM.
Here's a quick rundown of what the cluster does: Simple layout and combined body - Unit allows you to make the best use of limited dashboard space by displaying various input digital. Combine Stack ST200 analogue tachometer as standard equipment - RD-1 display features high precision and reliable analogue tachometer STACK ST200. Dial face color and scale is selectable. Multiple channel display - RD-1 displays various information to convey the clear picture of the vehicle conditions Selectable display pattern - Variation of display pattern is selectable. Correspond to sport and street driving condition. 1. Normal Mode - The unit assumes street driving and mainly displays speed, water temp., fuel level, and travel distance. 2. Racing Mode - the unit assumes sport driving and mainly displays speed, water temp., oil temp., oil pres., and lap-time. 3. Setting mode - The unit assumes engine or computer setting and mainly displays RPM, boost pres., injector duty, and fuel pres,. Also, able to make effective use of the unit by entering air-fuel ratio and throttle divergence in to universal input channel (VOLT-1 and 2). * Air-fuel ratio meter is not included. Function to analyze driving data - Data analyzing functions can be used after circuit or test driving. 1. Peak-hold - Displays memorized peak value. 2. Data display - Displays loads mass-storage maximum of 30 minutes data recording. Replay speed can be adjusted such as slow-motion and fast-forward. 3. Lap-time - Times laps manually during circuit driving. External stop watch switch is connect-able to input 4. Lap chart - Memorizes and displays up to 99 laps on the chart screen. Easy search jog dial - Jog dial simplifies the operation of display search and function setting. Indicator lamp - RD-1 display is supplied with indicator lamp as standard. This allows you to replace dashboard instruments without hindering functions and visibility. 1. Indicators - Engine check, turn signals, parking, high beam, fuel warning. RD-1 Display data / Other function RD-1 displays - Speed / RPM / Fuel level / Fuel consumption / Travel distance (odo and trip) / Boost pres. / Water temp. / Oil temp. / Oil pres. / Fuel pres. / Injector duty / Volt-1 (universal input) / Volt-1 (universal input) / Time / Lap-time. RD-1 other function - Unlocking speed limiter / Shift timing light / Maintenance warning ASKING $7O0 OBO. LOWBALLERS WILL BE IGNORED. BUYER PAYS FOR SHIPPING AND PAYPAL FEES PM if interested. Serious inquires only. Last edited by Sarky; 07-03-2014 at 06:59 PM.. |
