Old 11-12-2017, 03:45 PM   #31
Revhappy86
Revhappy86 is an unknown quantity at this point
Yes be careful with the crank bolt! Do it right so youre not creating bigger issues for yourself.
Revhappy86 is offline   Reply With Quote
Old 11-30-2018, 01:17 PM   #32
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
Bumping this from the dead.
Somehow I stripped my left upper tensioner guide hole. Anyone know what size thread that hole is? Could I just retap the hole or would I need to use a helicoil??
Please help!
dreaMervaj is offline   Reply With Quote
Old 11-30-2018, 02:20 PM   #33
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
Please help!
the tensioners are m6x1.00, the guides are m8x1.25.
@adamcs14
NiSilS14 is offline   Reply With Quote
Old 11-30-2018, 06:13 PM   #34
dreaMervaj
Trader Rating: (18)
So left upper tensioner guide bolt holes are m6x1.00 or m8x1.25?
Old 11-30-2018, 09:23 PM   #35
NiSilS14
The tensioners are m6x1.00
these guides are m8x1.25
@adamcs14
Old 12-01-2018, 09:57 AM   #36
dreaMervaj
Trader Rating: (18)
Thanks man! Hopefully I have that tap and can just rethread the hole.
Old 12-01-2018, 10:17 AM   #37
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
good/excellent thread!!!
supersayianjim is offline   Reply With Quote
Old 06-11-2019, 01:08 AM   #38
dreaMervaj
Trader Rating: (18)
Bumping this up as I am at a complete lost right now.
All timing components were installed exactly how it should be - colored links matched dots on gears/cams/cans are both facing outwards also. The problem is when I install my ATI damper with the way the motor is TDC and the position of the crank key the ATI pulley isn't reading 0/TDC position. How will I be able to time the motor in the future if the pulley doesn't line at 0/TDC now?
Old 06-11-2019, 02:28 PM   #39
TheBlackHand
TheBlackHand's Avatar
TheBlackHand is an unknown quantity at this point
About how many degrees BTDC/ATDC is your pully off? Do you mean way off
like 20* or so or only like 1* or 2* off from TDC?
The woodruff key on your crank is pointed straight up at 12 o'clock when #1 piston is at TDC on compression stroke right?
TheBlackHand is offline   Reply With Quote
Old 06-11-2019, 03:07 PM   #40
cnichols
cnichols's Avatar
cnichols is an unknown quantity at this point
Believe the ATI I attempted to put on my 2JZ was the same way. I hate their junk. I pulled it off and went with a Fluidampr. With that said, is it a two piece that can be clocked and put back together?
I say if you're sure everything is correct, then etch the true marks you need on the balancer and call it a day or send it back and go with stock or another brand.
11.0 @ 131 | LS1 | T56 Magnum
cnichols is offline   Reply With Quote
Old 06-12-2019, 12:23 AM   #41
dreaMervaj
Trader Rating: (18)
I am unsure how many degrees. I can take a photo tomorrow but my woodruff key was more at like 11 o'clock...
Old 06-12-2019, 12:26 AM   #42
dreaMervaj
Trader Rating: (18)
This was my initial thought. That the inner AC pulley and the other pulleys were two piece and I could split the pulleys and arrange them to match tdc but according to the ATI instructions there is a offset hole so I am unsure if it will even make a difference. I removed all the bolts from the pulley but it's not coming apart... I really wanted to use this instead of the stocker..
Old 06-12-2019, 09:27 AM   #43
TheBlackHand
It should be pointed straight up at 12 o'clock when #1 piston is at TDC on the compression stroke. Sounds like your timing chain is off a couple teeth.
I don't think this is the ATI pulleys fault. Put the stock pulley back on and see if it has the same problem as the ATI does. If so you know your timing is off.
Old 06-29-2019, 11:54 AM   #44
dreaMervaj
Trader Rating: (18)
Thanks for the help guys. Figured it out with TheBlackHand's advice.
Old 08-08-2019, 02:01 PM   #45
TheBlackHand
Originally Posted by Kamuten View Post
Not running a long shaft, tach says 6300-6500 and sounds like it. Feel free to catch a plane from the UK to watch it go, boat runs 57-58.5mph on gps. Need a pic of the gpsd speed? Got no problem doing that
What? Are you saying there's a problem with your tachometer and speedometer?
Your question may belong in this thread https://zilvia.net/f/showthread.php?t=297481
Old 02-17-2021, 07:58 AM   #46
t3hranger
t3hranger's Avatar
t3hranger is an unknown quantity at this point
Just wanted to say thanks for this write-up! I recently rebuilt my motor and following your guide. It so nice to have the pics and detailed info.
t3hranger is offline   Reply With Quote
