03-30-2008, 09:13 AM | #1 |
sr20det manifold/exhaust leak help
well ive got an exhaust leak and its coming from right below the manifold as illustrated in the pic below.... but when i put a jack up under the downpipe to see if that stopped the leak the car started idleing higher. i raised the jack 3 pumps and with each pump the idle increased.
help.... is this something like a vacuum leak? and how do i fix this etc.... thanks in advance |
03-30-2008, 11:52 AM | #3 | |
would i start from the bottom (unbolting DP and working my way up.....) or start from the top? (move I/C piping out the way, etc...)
1990 240sx hatchback.... SR20.... new projekt/track whore |
03-30-2008, 12:03 PM | #4 |
Go to Zeroyon.com or anyother site that has a FSM you can download and it explains it all. Trust me that spot is not hard to work with compared to other cars. Plenty of room just ask Z owners
So easy a cave man can do it. |
03-30-2008, 10:51 PM | #5 | |
haha thanks. im going to tackle it tomorrow. its leaking pretty badly...
03-31-2008, 03:45 AM | #6 |
i had that leak on me a few times. do it once right and get new locking tabs under the nuts from nissan. its not fun ripping it out 3 weeks later for the same exact problem. start with disconnecting o2, oil + coolant lines, hot pipe, intake filter tube, and the rest of the easy stuff. take off the downpipe from the elbow and then the manifold and pull the whole thing (mani,turbo,elbow,w/ lines still on turbo) and take off the 2 nuts on the brake master and slide it to the side for room.
