Old 03-22-2008, 08:11 PM   #1
buku_points
buku_points's Avatar
buku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfection
oil light on?????
earlier today i was driving on the 5 south to irvine i was doing about 70 mph and hit a dip on the freeway. Right after the oil light came on and i pulled over right away. i checked the oil pan and there was no leaks so i ran the car with the oil cap on and it was still getting oil pressure. so my question is could it just be a bad oil press. sensor? or am i gonna run ionto some serious problems? theres no knocking or unusual noises coming from under the hood. thanks for all info!
buku_points is offline   Reply With Quote
Old 03-22-2008, 08:14 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
first of all i'd check for corrosion at the connector for the sensor/sending unit. next i'd get a mechanical oil pressure gauge and check for pressure.
Old 03-22-2008, 09:07 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Dont even think of starting it till you're sure its the sensor....
CLICK HERE!!!
Old 03-22-2008, 10:02 PM   #4
916S14
916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known
Did you dent the oil pan when you hit that dip? Like the othes said install a mechanical oil pressure gauge and check.
916S14 is offline   Reply With Quote
Old 03-22-2008, 10:25 PM   #5
buku_points
i got under the car and saw no visual dents or scrapes on the bottom of the oil pan. no leaking either. tomorrow i will get an mech oil press gauge and make sure its safe.
